NP 435 question
Old Nov 22, 2001 | 05:41 PM
1ole4d's Avatar
1ole4d
NP 435 question
Will this transmission bolt up to a 429 V8?
Old Nov 23, 2001 | 12:35 AM
telesqrt's Avatar
telesqrt
NP 435 question
Depends on the bell housing. The NP 435 had the bell housing bolted to it, so it could be put behind different engines. The 429 is the same engine block as a 460 which has the same bolt pattern as the 351M/400 Ford engines. If the NP435 was behind any of these engines, I believe it will bolt up to the 429.
Old Nov 24, 2001 | 01:51 PM
Nod's Avatar
Nod
NP 435 question
Try Advance Adapters, they make adapters for most any conversion, If anyone would know they would. Good luck.
"bowties in the rearview mirror"
Old Nov 24, 2001 | 05:37 PM
Eddie's Avatar
Eddie
NP 435 question
That first post was right on the money: Find a 351M/400 B/H from a '78/'79 Bronco/F or a '80-'84(?) Bronco same engines.
So was the second: AA is a lot of help, go to their website and get a free "Buyer's Guide" for sure, but I don't think you need to buy anything from them with this one.
The keys here are:
(1), mechanical, not hydraulic, clutch actuation (if you have mech. now--if hyd., post; it gets weirder but I've been there and can help);
(2), 6-1/4" x 8-1/2" bolt centers (smaller measurement sides, larger top and bottom;
(3), 6-1/2" input shaft stickout, 10-spline x 1-1/16" o.d., w/7/8" dia. x 1" L. pilot shaft;
(4), 6" bellhousing depth;
(6), correct throwout bearing pivot arm to go w/B/H.
Eddie
Old Nov 24, 2001 | 05:43 PM
Eddie's Avatar
Eddie
NP 435 question
