engine misses
Old Apr 14, 2007 | 08:41 PM
davef's Avatar
davef
engine misses
I have a 77 f250 4x4 with a 400 with around 15000 miles on a rebuild. The engine misses throughout driving speed. I did a complete tune up, helped a little. So I did a compression test, all cylinders showed around 130 psi, except #2 showed around 40psi. I did a wet test, no change in the readings.Does anyone have any ideas as to what could be wrong? Thanks!
Old Apr 14, 2007 | 10:04 PM
kilog55's Avatar
kilog55
#2 is very low, could be a sticky valve, leaky head gasket, could be anything really
Old Apr 14, 2007 | 10:05 PM
Torque1st's Avatar
Torque1st
Posting Legend
Time to tear it apart.
Old Apr 16, 2007 | 09:43 AM
beartracks's Avatar
beartracks
I'd check under the valve cover for that cylinder first. You might have a stuck valve or a push rod setting on the edge of the lifter etc.
