Testing fuel pressure
Old Sep 16, 2015 | 08:14 PM
Az_Green_Machine's Avatar
Az_Green_Machine
Ok guys so it looking like I may be replacing my fuel pump. I do want to test it for pressure before I order parts and start tearing it apart, main concern is there's no access ports on my bowl like I have seen in other pictures. I've seen several post about the two access ports that you can screw an adaptor into and a shrader valve on and test it. But they are non existent. Is there anything I can do? Also if I do end up having to replace the pump are their orings I should.replace at the same time? Are they included with the pump or ordered separately?
Old Sep 16, 2015 | 08:20 PM
Action4478's Avatar
Action4478
Most Fuel pumps fail by leaking . What are your symptoms ?
Old Sep 16, 2015 | 10:17 PM
fordpride's Avatar
fordpride
Those ports are on the e99 to 01 7.3
On the 94.5-97 7.3 you test at the schreader valve. Looks like a valve steam on your wheels. You can use a stick style tire pressure gauge
Old Sep 16, 2015 | 11:12 PM
Az_Green_Machine
Crank no start, oil pressure is fine, no lights on the dash, truck just died after entering the freeway. I've done a few other things to check it, blew out the lines, dropped both tanks, checked the crank sensor and I tried unplugging the icp.
Old Sep 17, 2015 | 05:47 AM
fordpride's Avatar
fordpride
There is no way to check the cps.
Sounds like a bad cps
Old Sep 17, 2015 | 06:35 AM
Az_Green_Machine
I replaced it with a known working one from another truck with no changes. It's not a CPS
Old Sep 17, 2015 | 07:24 AM
fordpride's Avatar
fordpride
Do you have a wait to start light ?
Smoke form tailpipe while cranking?
Old Sep 17, 2015 | 12:03 PM
BBslider001's Avatar
BBslider001
Hope this helps
Old Sep 17, 2015 | 03:39 PM
dclack's Avatar
dclack
I've got money on the fuel heater! Check the fuses under the hood; I can't remember which one off the top of my head but it's a big 30 amp maxi fuse. The fuel heater shorts to the filter housing and blows that fuse.
Old Sep 17, 2015 | 05:01 PM
Az_Green_Machine
Well I'm about to get home I'll report back
Old Sep 17, 2015 | 05:20 PM
Action4478's Avatar
Action4478
Open the fuel filter , open the fuel drain. Empty the fuel res . Close the drain & crank the motor over . If the bowl fills the pump is ok.BTW FP if they do fail they do so over a period of time rather than suddenly. Mine leaked for quite a while but still worked .
Old Sep 17, 2015 | 05:27 PM
Action4478's Avatar
Action4478
9 & 22 .............
Old Sep 17, 2015 | 05:39 PM
Az_Green_Machine
I have a wait to start light and smoke comes out, I'm charging the battery's now, I can't really make out what that chart says about the GPR.
Old Sep 17, 2015 | 06:01 PM
dclack's Avatar
dclack
Yep. #22 was the one that blew, leaving me stranded a few blocks from home. Did you check those fuses?
Old Sep 17, 2015 | 06:15 PM
Az_Green_Machine
Fuses are fine, GPR tested fine on both sides, and the pins. I'm kinda stumped, I put on a new CPS just to check it and still the same. It cranks, huffs and puffs but won't start. It sounds like it is on the verge of starting but never does.
