Well now comes electrical issues
Old Aug 25, 2012 | 07:15 PM
TAT2DUP81's Avatar
TAT2DUP81
So first of all I found out alternator is bad. So gotta get that replaced. But does the charging system have any effect with fuel mileage? So is there any tips with replacing alternator? And since taking that out gonna replace belt also. But other question I have is bought some replacement led taillight bulbs. When I installed em they started smoking. But don't smoke with regular bulb. Any thoughts on that?
Old Aug 25, 2012 | 07:45 PM
Crash16's Avatar
Crash16
Not sure, but aren't you suppose to have a ballast or resister or something to run let's?
Crash16's Avatar
Crash16
Not sure, but aren't you suppose to have a ballast or resister or something to run led's?
Old Aug 25, 2012 | 07:46 PM
karlsdash's Avatar
karlsdash
Where is it smoking from? and did you install a resistor along with the leds? I know that some wiring in older vehicles needs the resistor otherwise cel/wiring issues can occur do to the lack of a resistor in the led.(i could be wrong on all of this, but remember a rather large issue about wiring and leds without resistors)
Old Aug 25, 2012 | 09:24 PM
TAT2DUP81's Avatar
TAT2DUP81
No I plugged in to see if they'd just turn on. I'll hook up resistors Monday. Kinda figured not having those hooked up coulda been problem
19fifty4
May 25, 2012 11:18 PM
56effiex
Aug 21, 2004 01:02 AM
billbrox
Electrical Systems/Wiring
Jun 22, 2003 03:49 AM
big4294x4
Jul 9, 2001 04:28 PM
big4294x4
Jul 8, 2001 09:03 PM
