Broken FUEL guage
Old Sep 30, 2007 | 03:57 PM
pntblr03's Avatar
pntblr03
Broken FUEL guage
Has anyone esle had the fuel guage stick. My truck just started reading full at all times. I reset the mpg tracker on the ceiling, and the trip odometer; neither did anything helpfull.
I would appreciate any advice.
Mullins
'04-f-250-6.0
Old Sep 30, 2007 | 03:59 PM
Todder's Avatar
Todder
My '04 gauge broke it was the sending unit or something like that.
Old Oct 1, 2007 | 05:43 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Mullins
'04-f-250-6.0
Old Oct 1, 2007 | 05:53 AM
rchouser's Avatar
rchouser
I just had my fuel sending unit replaced on 06 f350 PSD 36,200 miles. Filled the tank, turned on the ignition and mine slammed to bottom and stayed there. Get a code reader and check for fuel sending unit codes. thanks rc
Old Oct 1, 2007 | 11:49 AM
EZ-Ford's Avatar
EZ-Ford
You can also put the ODO into its test mode and it will display fuel levels. Here is a link to that thread. There are a couple of ways to get into the mode depending on the year and options on your truck. This should help to isolate to the sending unit or the gauge. If the ODO fuel level shows OK then its your gauge, if not then sending unit.
https://www.ford-trucks.com/forums/6...new-today.html
Old Oct 1, 2007 | 02:17 PM
pntblr03's Avatar
pntblr03
Thanks. The display for mine reads -F 232- which i believe would be fuel level and -FP 252- Fuel pressure????
Old Oct 1, 2007 | 02:27 PM
EZ-Ford's Avatar
EZ-Ford
Nobody has really answered for sure, but I believe the FP is actual fuel level (Fuel Present??), in gallons. For your reading of FP 252, that would mean 25.2 gallons in the tank.
Old Oct 5, 2007 | 10:28 AM
karynzoo's Avatar
karynzoo
I've had problems with my fuel gage. Had the sending unit replaced and cluster. Ever since this started I have no idea what's in my tank and it appears I'm only getting 10mpg and less than 300 miles per tank.
My current FP is 038 which I guess means 3.8 gallons...meaning the gage is right and the truck has a new problem...less fuel economy. I'm sick of this truck already.
joe f350
Mar 13, 2011 07:51 PM
Bookman
Nov 8, 2007 10:23 AM
biohazardbill
Sep 30, 2007 04:03 PM
cbfomoco
Oct 22, 2005 04:05 PM
manimal_fla
1983 - 2012 Ranger & B-Series
Dec 28, 2004 01:01 AM
