I Do Believe its Turbo Time
Old Jan 13, 2010 | 07:36 PM
origcharger's Avatar
origcharger
Red face I Do Believe its Turbo Time
The unit in my signature line was making some rattling like noises when returning to idle, took it for a spin and some brief noise followed by a considerable drop in power and a big smoke show Now it starts and idles fine, won't rev past 2,000 or so, no more rattling noise, plenty of smoke and we have oil running out of the condensate drain hole in the muffler
Whats the going price on a turbo? Any special tools or tricks to replacement? Its in an E-450
Old Jan 13, 2010 | 08:28 PM
lakewood's Avatar
lakewood
i believe a stock turbo is around 1000 bucks, go to [url]www.partsguysed.com, you can buy oem parts for alot less, the 1000 dollar price is at this website, and installation should be a couple hundred
Old Jan 14, 2010 | 04:33 PM
hott-rodd's Avatar
hott-rodd
I replaced my turbo with one from Ebay $400 used and it doing well.
Old Jan 14, 2010 | 07:16 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Check with Cartmanea, I think he had 2 for sale not too awful long ago.
Old Jan 14, 2010 | 07:57 PM
origcharger
Thanks for the suggestions. This is on a school bus, its got to go and I need to get r done and move on to the next project so I don't think I will fool around with a used one.
Local sources quoted $1050 for reman. and $1300 for new, my gut tells me for $250 differance to go new, decisions, decisions.
Old Jan 15, 2010 | 02:53 PM
Frankenbiker's Avatar
Frankenbiker
Reman is fine. I put a Reman turbo on the Series-60 5 years ago with no problems since.
At least turbo problems, anyway.
-blaine
Old Jan 15, 2010 | 10:28 PM
origcharger
Of course this is one of them hydraulically actuated variable pitch impeller units. Just thinking the new one may have some desireable design updates and the condition of my core would be a non issue.
Old Jan 15, 2010 | 10:35 PM
06silvercrew's Avatar
06silvercrew
Not hydraulic actuated, electric pwm and its on the exhaust side not the impeller
Old Jan 15, 2010 | 10:43 PM
william_04_x's Avatar
william_04_x
a little of both actually..
Old Jan 16, 2010 | 01:37 AM
dc3655's Avatar
dc3655
I know that this is for an E-450 bus, but when I see $1300 for a new turbo I instantly think that $1400 for an Industrial Injection Stage I would be in my future. Especially for only $100 more. Now again, that would be the route I'd go in my F-250.
Decisions, decisions.....
Old Jan 16, 2010 | 07:33 AM
origcharger
I disconnected the exhaust outlet pipe this morning just to see what I could see or feel. Shaft is apparently broke as I can flop the exhaust side turbine wheel all around inside the housing with my finger, so its time to get a turbo of some sort on order.
Tell me about this "Industrial Injection Stage I" turbo?
Old Jan 18, 2010 | 03:07 AM
dc3655's Avatar
dc3655
You could probably find quite a few other threads about this turbo, but those who have used this turbo really like them. If my memory serves me right, the stage 1 turbo has some modifications to help the oil reach all the necessary internals. I also remember reading that this helps minimize coking of the turbo. It has a larger compressor so it flows more air which helps drop EGTs (about 150-200 degrees). It is still a VGT turbo, and I think it is a modified 6L turbo. I would call or email Eric at Innovative Diesel and I'm sure that he could answer some questions because he sells them. It's been a while since I researched this turbo, but I remember making a mental note that this will be the turbo that I go with when mine goes out again after the warranty is expired.
Old Jan 18, 2010 | 08:17 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
User 'adambomb' has had an II stage 1 for a little while. I'm sure he'd give you his impressions if you pm 'ed him.
Old Jan 18, 2010 | 09:24 AM
Maxium4x4's Avatar
Maxium4x4
That is allowable tolerance ..... There are a couple of turbos listed for sale in the Market Place
Old Jan 21, 2010 | 08:54 PM
origcharger
Got the turbo swapped out today, because its in a cutaway van chassis the exhaust hookups and the backside wasn't too bad at all. The front side.....well my hands sorta look like I was trying to give the cat a bath
As I rolled the old turbo around it looked like there was a part of the hydraulic actator valve rolling around in there which led to the bent vanes and broken shaft, don't know where else that part would have come from.
