Offroad & 4x4
Dillins Build Thread
Old Mar 18, 2010 | 07:43 PM
  #211
dillinewton's Avatar
dillinewton
Well i got my axles mocked up for the first time tonight. now im sending off my front axle to get the c's rotated. but im not happy with my rear. i dont think i have a good shackle angle. i think my axle is an inch or so foward to much.
center of the axle should be in the center of that little piece on the frame that i have a yellow square around right?
heres a pic of my shackle angle.
and here is the whole thing, the front is barely put together, just so i could tell that guy what i wanted my pinion angle to be so he could set my outer c's to the right caster but im glad to finally see something happen. I still dont have enough lift in the year yet either.
Old Mar 18, 2010 | 07:49 PM
  #212
kjett's Avatar
kjett
Your rear angle will fix itself when you put weight on the rear, like the additon of the body. You may have to wait until you put the body on to ge the rear finished up.
Old Mar 18, 2010 | 07:50 PM
  #213
fatdan460's Avatar
fatdan460
i agree wait till there's some weight on there
Old Mar 18, 2010 | 07:53 PM
  #214
fatdan460's Avatar
fatdan460
are you gonna brace up the front perch on the rear springs? i'd damn well hope so
Old Mar 18, 2010 | 07:59 PM
  #215
captain p4's Avatar
captain p4
no way weight is going to fix that angle.. its going to fold the wrong way with weight on it you chicken ****ers
Old Mar 18, 2010 | 08:00 PM
  #216
crazyredneckanyhow's Avatar
crazyredneckanyhow
Iunno guys. That shackle is so far forward that when he gets weight on it im afraid itll just keep goin in the direction it is now. I could be wrong but thats what it looks like. From most ive seen with no weight the shackle should pretty much be pointing strait down.
Also if your keeping the factory shackle hanger flipped i would gusset it. Ive seen a few like that bend.
Old Mar 18, 2010 | 08:02 PM
  #217
captain p4's Avatar
captain p4
^what cheeto said
Old Mar 18, 2010 | 08:06 PM
  #218
fatdan460's Avatar
fatdan460
but is the frame's weight even resting on it or is it just bolted on and supported? i can't tell from the pics
Old Mar 18, 2010 | 08:10 PM
  #219
crazyredneckanyhow
With the arch those springs have and the negative angle of those shackles i just cant see anything good happening
Old Mar 18, 2010 | 08:17 PM
  #220
dillinewton
ya the frame weight is on it. im going to make a sky flip, and when i do that im going to move it to where the eye of my leafs are about a half inch behind the eye of the hanger so that should take care about that, but i dont wanna dril holes in the back until i get the front hanger where i want it, i think i need to move it back about an inch because i think the axle is just too far foward, but im not at the amount of lift i need yet, so its being a pain in the butt, because there are 3 different thing that need adjusted and all need to work together, so im just focusin on the front right now and the rear is on the back burner, but ill see what happens this weekend. just thought i would post some pics of the project.
Old Mar 18, 2010 | 08:19 PM
  #221
dillinewton
easy now, im going to fix it, im not wanting it to flex alot just about the normal amount. someday way down the road i think i might want to 4 link the rear, but i think that might be a smaller setup. i just thought i would put some pics on here and see what you all think and see if there were any suggestions
Old Mar 18, 2010 | 09:29 PM
  #222
alpha/omega's Avatar
alpha/omega
the rear frame hanger needs to be moved forward or the front frame hanger needs to be moved backwards AT LEAST 2". The shackle should be pretty close to straight up with no weight and at roughly a 20* angle once finished.
Old Mar 18, 2010 | 09:45 PM
  #223
dillinewton
ok sounds good? 20* like straight up and down almost or like almost flat? and is the little piece of metal on the frame that i have the yellow box around, should the center of that be straight up from the center of the axle? thanks
Old Mar 18, 2010 | 09:48 PM
  #224
kjett's Avatar
kjett
Just move the front hangers rearward. You already said the axle is farther forward than it was, so moving the front will put it back to where you wanted it and help fix that angle.
Edit: Kris is saying straight up and down now, and the bottom should be about 20* behind the upper when it's done.
Old Mar 18, 2010 | 09:53 PM
  #225
dillinewton
ok sounds good, well i gotta run the front to that shop tomorrow, but while its getting worked on i would like to get the rear finished up or close enough where its minor stuff, but i still need to make my sky hanger flip. but thanks i enjoy how you(karl) and kris acaully give me the answer im looking for, not a bunch of nonsense thanks.
