Offroad & 4x4
Dillins Build Thread
Old Mar 9, 2010 | 07:19 PM
  #151
dillinewton's Avatar
dillinewton
nice thanks, ill just have to make drill the holes an inch wider in the gap right, and what about on my coil when i bolted them up to my upper buckets only, they could move all the over the place, is that right, i tighten them down as much as possible, just didnt seem right?
Old Mar 9, 2010 | 07:23 PM
  #152
alpha/omega's Avatar
alpha/omega
$50 for some spacers and bolts? hmmmm
Where do you live Dillin?
Yeah your coil springs can move when you only have the top bolted in.
Old Mar 9, 2010 | 07:24 PM
  #153
kjett's Avatar
kjett
The tube on your 60 should only be 1/2" wider than the mount of the 44 c's. Don't know why Paul said 1". Don't drill the lower bucket until you have the c's on and all bolted up, then measure it right the 1st time for drilling the new hole.
Old Mar 9, 2010 | 07:26 PM
  #154
dillinewton
indiana why?
Old Mar 9, 2010 | 07:30 PM
  #155
kjett's Avatar
kjett
Cause youd be a total idiot with a fat wallet and no sense if you paid $49 for 4 pieces of steel plate and 8 grade 8 bolts. If you want the spacer's I'll make you some and sell them to you for $45, better deal?
Old Mar 9, 2010 | 07:32 PM
  #156
captain p4's Avatar
captain p4
Was thinking radius instead of diamter, Karl is right. 1/2".
Old Mar 9, 2010 | 07:34 PM
  #157
dillinewton
haha ok, well the only reason i would buy them is it would be very easy. if i make them i would have to track down some .5" steel cut that shape out, buy the bolt which i went to the farm store today and couldnt find any the right thread. then i woud have to mark them and drill them with and i have no drill press soi would spend 5 hours making them and running around town finding stuff for 30-35 bucks or shipped to my door for 50
Old Mar 9, 2010 | 07:36 PM
  #158
dillinewton
and when im spending the kinda money i am on this thing, 20 bucks isnt going to kill me make sense at all to you guys
Old Mar 9, 2010 | 07:38 PM
  #159
kjett's Avatar
kjett
just gut your c's before you weld them on. Worst case, you need to make an 1/8 to 1/4" spacer like we did for Pauls. Easy enough.
Old Mar 9, 2010 | 07:40 PM
  #160
dillinewton
gut? is this a spelling error
Old Mar 9, 2010 | 07:43 PM
  #161
kjett's Avatar
kjett
yes, typo from my blackberry. CUT them
Old Mar 9, 2010 | 07:45 PM
  #162
dillinewton
o gosh if i could get internet on my phone i would be on here 24/7, gring off from the inside right?
Old Mar 9, 2010 | 08:13 PM
  #163
kjett's Avatar
kjett
yep. Measure 1st! you can quickly tack them to the tube, then measure edge to edge on the 44, then measure edge to edge on the 60. Take the difference, divide by 2 and that's how much you need to cut from the inside of the c's.
Old Mar 9, 2010 | 08:25 PM
  #164
dillinewton
ok thanks alot guys, thanks i know i ask a bunch of ridonkulous questions, but defiantly dont wanna screw this up. thanks alot
Old Mar 9, 2010 | 08:43 PM
  #165
quadzjr's Avatar
quadzjr
just another Rockwell looser
Originally Posted by mark a.
Don't the super duty springs, shackles and hangers use a metric bolt size ? If they do they might not do you any good with the '79 spring's sae through bolt size. There could be a hole size mismatch.
the shackles i bought didn't....
