Sponsored by: Real Truck
Gas vs PSD
Old Jun 13, 2011 | 07:32 PM
  #12106
'89F2urd's Avatar
'89F2urd
A turbo IS a thermodynamic device. To understand the fluid and thermodynamics of a turbo, its as simple as googling just that. I've put it in laymen terms just about every way i can think of.
Old Jun 13, 2011 | 08:02 PM
  #12107
monsterbaby's Avatar
monsterbaby
Originally Posted by '89F2urd
Moving air is not spooling a turbo. Making the turbine move and spooling are two different things. A turbo will not spool without heat unless its mated to an air pump so large that it would be pointless to hook it up cuz the intake side of the turbo would move less air than the source pump is giving it. . . .in other words turbos,like every other machine on earth, is not 100% efficient. If turbos move air. . .the movement of air cannot be the source of energy spooling it. They cannot run without heat. Period.
To put this in more understandable means. . .
Anyone competant individual who's ever owned or perhaps even driven a turbo vehicle without a throttle body (turbos can actually create vacuum with throttle body equipped motors, like gassers) knows the turbo wont build boost without load on the motor. I.e. heat production. . . . .you can downshift all the way to redline (max airflow from motor) and it wont build boost. The turbos rpm is increased (can hear it increase) but no boost is made. There is no boost, and there is no heat (no combustion on downshifts).
Another example is free revving the motor. I can build 2-3 psi with a free rev (more can be achived with twins but its still a fraction of max boost). This is a little boost, with only a small amount of heat.
As load increases, egts increase not only in their max possible temp. . .but also the acceleration to the max temp. This is why turbo vehicles love the highway. The high load/high heat makes for a fast spooling turbo.
It would take a miracle for a turbo to spool without heat. It just wont.
absolutely 100% wrong all the way around.
You uncork the turbo and you can put all the heat you want through it and it won't build an bit of boost. Boost like vacuum is built by a restriction. You CAN build boost if you use a big enough air pump to spin the turbine side of it and put a smaller motor on the compressor side and it will build boost.
The act of compressing air does build heat which is why intercoolers are used but it's NOT a requirement of the turbo in order to build boost to have heat.
Your confusing the fact that under load an engine produces more heated exhaust gases that are expanding with needing that heat to spin the turbo. the turbo needs air flow plain and simple. you put the turbo off of my 7.3 onto a 3.0L 4cylinder and it will hardly build any boost even tho you might get a large amount of heat. The reason is the smaller displacment engine won't produce enough volume of air to spin the turbine fast enough to let the compressor actually pump more air then the engine can use (which is what builds boost)
Old Jun 13, 2011 | 08:13 PM
  #12108
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by Krewat
However, I still fail to see where exhaust flow is "radiated out to the environment". It's a purely physical action. The turbo is not consuming BTUs to produce energy, it's consuming velocity which happens to cool off the exhaust gas AFTER the turbo, yet also heats up the gas BEFORE the turbo because of compression.
It does.
Go back to the PV=nRT.
I know that part is hard to get your head around - its a mechanical device, how does it consume thermal energy? It does it the same way that the engine does it to begin with.
Now, I would also say "there ain't no such thing as a free lunch" - TANSTAAFL
Any mechanic energy that the turbo uses to drive it's shaft, is lost exhaust gas velocity. The effect of that lost velocity is a pressure build-up before the turbo, acting back on the head of the piston as it rises on the exhaust stroke (backpressure).
I agree - it adds backpressure, but the pressures in the exhaust manifold are relatively insignificant in comparison to combustion pressures which want to escape.
A good example of this is the thickness of an engine block to a turbo manifold that needs to support their respective pressures.
So yes, it does add backpressure - but the backpressure doesn't have as big of an impact on the exhaust gas flowing out of the engine. Most turbo's run most efficiently on the turbine side run at a 2-2.5:1 pressure ratio. Meaning about a 30-37psi gauge pressure.
Bearing in mind that combustion pressure (even at BDC) is around 1000 gauge psi, its influence is in the order of a few percentage points.
It's not FREE energy driving that turbo. It's a positive-feedback in terms of putting more O2 into the cylinder that far exceeds the loss to exhaust backpressure, but it's still there.
I agree that the benefit isn't 100% i.e. the Turbo makes the engine direct some energy to driving the damn thing, but its a distinct net positive.
The engine's ability to extract power from what is a relatively low pressure differential (20 odd gauge psi) is minimal, but a turbine type device like a turbo is very efficient at the high flow/low pressure environments.
Old Jun 13, 2011 | 08:19 PM
  #12109
BigF350's Avatar
BigF350
FTE Emeritus
Robb - I think the point '89F2urd is attempting to make is that the heat and pressure are 100% dependent on each other.
Yes, you can create a restriction and it will build pressure, but in the case of your 7.3, if you didn't have the temperature in the exhaust gases to begin with - the turbo on your 7.3 would be way too big as well, and it is VERY dependent on heat being there to build the pressure.
I hope that makes cents
Old Jun 13, 2011 | 08:28 PM
  #12110
'89F2urd's Avatar
'89F2urd
I NEVER said air was not necessary for the spooling of a turbo. . .and im not confused. An engine can't operate without airflow. Are they not thermodynamic devices? All of my examples are "real world" examples validating the point im trying to make. In fact, your example using a large turbo on a small motor is misguiding. A particular egt doesn't mean an equal amount of thermal energy. The higher the rpm, (and the bigger the motor) tuhe "greater" the opportunity to evacuate thermal energy. The faster you evac the thermal energy, or the more thermal energy that is released altogether, the faster a turbo will spool. A 3.0l engine and a 6.0l engine (assuming they are of the same design) can spool the same size.turbo. the 3.0l will spool it just as quickly but will require twice the rpm to spool it at the same rate as the larger motor. Why? Because the absolute amount of thermal energy would be near identical in this example. Neither motor would spool the turbo at no load, and no heat (max airflow, minimal fuel/heat/thermal energy). This isn't that difficult to understand. . .
Old Jun 13, 2011 | 08:40 PM
  #12111
parkland's Avatar
parkland
It would take you're "3.0" L motor twice the RPM's to spool the turbo because it is now flowing and burning the same fuel / air of the 6.0 at half RPMs.
Old Jun 13, 2011 | 08:46 PM
  #12112
'89F2urd's Avatar
'89F2urd
Was this a response to my post? Cuz that's exactly what i said. . .the thermal energy being released by the 3.0 (@ 2x the rpm of the 6.0) is near identical to the 6.0.
The airflow comes from the mechanical motion of the pistons, which i've already proved isn't enough to spool a turbo with my free rev/downshift examples. The massive amounts of thermal energy released through the turbo comes.from the"leftovers" of combustion. That thermal energy is what operates the turbo (not just moving the wheels, but actually spooling turb)o. The airflow is just the vessel that carries the energy. And. . .it would be impossible for drive/boost pressure to be 1:1 if airflow from motor spooled turbo by itself.
Old Jun 13, 2011 | 09:08 PM
  #12113
parkland's Avatar
parkland
This is a turbocharger jet engine:
YouTube - ‪Beer+old turbo=home made jet engine‬‏
In this setup, a flame tube in the system burns fuel, causing rapid expansion of gasses, and causes the turbocharger to run like a jet engine.
While our trucks make heat during combustion, you can't deny that the engine itself is an air pump, and this drastically changes a few key operating facts about the turbocharger, which in my mind rule out calling it an "engine"
1. It will spin using any exhaust temperature, using proper vanes and sizing. It will because the airflow force can still be exerted on the vanes at any temperature.
2. You could rip a chunk of IC tube out and the turbo still spins. In this instance, it is easy to see that it is being "powered" by exhaust, rather than acting as an engine.
3. In a jet engine configuration, the more heat you add, the faster it spools and the more combustion happens - which is almost the same as our trucks, except that our combustion takes place in a positive displacement pump.
This is my thinking on why we're all disagreeing so much. This is not a jet engine. While science and laws of thermodynamics are all present, just remember that theres a twist put into the system, being a positive displacement pump, and it will operate slightly different.
Old Jun 13, 2011 | 09:20 PM
  #12114
Super08's Avatar
Super08
Kind of looks like a 6.4 during a regen to me
Old Jun 13, 2011 | 09:26 PM
  #12115
'89F2urd's Avatar
'89F2urd
Tthe airflow created by the motor is only enough to move the wheels at a low speed. Its enough to perhaps generate 1-3 lbs. Most of the time its less.
Old Jun 13, 2011 | 09:30 PM
  #12116
'89F2urd's Avatar
'89F2urd
Haha good 1.
Old Jun 13, 2011 | 10:44 PM
  #12117
parkland's Avatar
parkland
Yes you are mostly correct. (Although you can make boost without heat with the right turbo).
The turbo is running from air pressure, which is the air pumped through the engine and expelled at high temperatures. In this configuration, it is being powered 100% by exhaust pressure / flow.
If you wanted to get a turbocharger spinning from heat alone, I think you could, you'd need to set it up like a jet engine and replace the combustion tube with an air-air heat exchanger which the exhaust would flow through.
Old Jun 13, 2011 | 10:55 PM
  #12118
Kajtek1's Avatar
Kajtek1
I think the idea with making turbo into jet engine inside your garage would be great for checking with "Myth Busters"
The clip might be titled like "Can I take the whole neighborhood with my danger projects, or only my own house?"
Old Jun 13, 2011 | 11:07 PM
  #12119
Super08's Avatar
Super08
Their is a clip on youtube or something that shows a guy with one attached to his bicycle. Nuts!
Old Jun 13, 2011 | 11:30 PM
  #12120
Kajtek1's Avatar
Kajtek1
I've been playing with miniature engines in my teens and have seen miniature jet engines operating safely on flying models.
But having that red hot pipe working inside garage 3 feet above gas can with bunch of people observing FROM INSIDE
