Sponsored by: Real Truck
Gas vs PSD
Old Jun 10, 2011 | 08:41 AM
  #12046
william_04_x's Avatar
william_04_x
Turbos operate off of pressure differential. Heat is the greatest contributor to the pressure differential. They are thermodynamic machines.
Old Jun 10, 2011 | 08:56 AM
  #12047
Super08's Avatar
Super08
When it all comes to rest, in the end an engine is a giant air pump. A turbo or a supercharger just fools it into thinking it is a larger pump than it is by increasing the volume of air entering the engine than would be entering the engine at ambient air pressure.
Old Jun 10, 2011 | 11:10 AM
  #12048
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by colo_dually
Take the pressure off the trubo, and just apply heat. The turbo will not spin. The force of pressure upon the exhaust vanes, creates the motion that drives the compressor wheel. Be that exhaust gas, compressed air, the wind, air flow simply drives that wheel. Thermal Transfer of heat does not build boost, you can heat that compressor housing all day.
You are right - my point is, that the pressure comes from the temperature increase during combustion. The Turbocharger is an additional device that capitalizes of energy that would typically be radiated out to the environment.
If you take a turbo engine, and rotate it - without igniting fuel. How much boost will it make?
Originally Posted by Krewat
On a naturally aspirated engine, rev it to 2000RPM and try to put your hand over the exhaust pipe. You're telling me that there's no pressure when you do this?
I know that's not what you're saying, but it would certainly seem based on a previous comment you made, that exhaust pressure in a naturally-aspirated engine is at atmospheric pressure, ie delta of zero. But put a restriction in there, and pressure rises. Even a muffler does given enough RPM.
Sure, but WHY can it build pressure?
Because of the temperature of the air.
2) It might SEEM they are feeding on the exhaust heat. What is happening is the same principal used in air conditioners and refrigerators. Physical energy is used to create a pressure drop that lowers the temp of the coolant (exhaust gas).
Its similar, but only its the opposite way around.
In a refrigerator you impose a pressure change in the gas (compress it) which creates a temperature change.
In this - its the other way around. You invoke a temp change, (combustion) which creates pressure.
3) Gas turbine - Wikipedia, the free encyclopedia
I've used this exact example as a reason why a turbo is NOT running on heat energy.
And, to be honest, it doesn't directly correlate to a turbo'd piston engine.
They are both combustion engines, a gas turbine is just a turbo and is an external combustion engine.
Compress air, introduce fuel, ignite - use the temperature invoked on the air/fuel mixture to create a pressure change and drive the turbine.
Old Jun 10, 2011 | 11:35 AM
  #12049
PorchFarms's Avatar
PorchFarms
alright if heat does not play a role in a turbo then how come this morning i started up and left my driveway and as soon as i hit pavement i stomped on my truck (not that i do that all the time) and the most boost i made was 19 pounds. then after truck warmed up i did it again and then made 27 pounds of boost. i know oil was cooler at first but it still should have been at least 80 degrees when i started up.
Old Jun 10, 2011 | 11:54 AM
  #12050
colo_dually's Avatar
colo_dually
This situation of a cold-engine boost, has a number of different variables to it. If you're running aftermarket tuning, most don't allow for full fueling unless the engine is at or near OT. The viscosity of the oil, and coolant for that matter at 80* is much different than at the 180*+ the engine is designed to run at. An 8psi difference in boost pressure on the 6.0L could be attributed to the electrical programming, preventing a lack of lubrication from causing excessive engine wear.
Again here's the point I'm making. Take a turbo off the motor, apply whatever heat source you feel will mimic the BTU's of radiated heat and see if it spins. Its not physically possible to spin a turbo off heat. Take that turbo and put air flow through and pressure (ambient temps), and it will create boost. It say heat has nothing to do with the equation is closed minded, as the pressure is created initially but fuel combustion, but the gasses are not longer expanding and once they leave the engine.
Old Jun 10, 2011 | 12:12 PM
  #12051
plgebbia's Avatar
plgebbia
The point I believe Porchfarms is making is this: the hotter air is much more effective at spinning the turbo than "cold" air. Which is 100 percent correct.
Pressure is a part of making the turbo function, but heat is what accelerates (very rapidly) the process.
Old Jun 10, 2011 | 12:14 PM
  #12052
parkland's Avatar
parkland
agreed and agreed.
Old Jun 10, 2011 | 05:17 PM
  #12053
parkland's Avatar
parkland
In a jet engine configuration it is, I think this is why all sorts of facts and figures are getting thrown around here.
Technically it is an "engine" but I think that is such a far stretch in this truck configuration.
Think of it as an air powered air pump.
Old Jun 10, 2011 | 05:25 PM
  #12054
colo_dually
The turbo in a diesel does not function the same as a Jet Turbine. Similar, however a jet turbine creates its own power from fuel. A turbocharger does not create its own power, that power must come from a source of air. Diesel exhaust is that airflow in these trucks.
Old Jun 10, 2011 | 06:20 PM
  #12055
PorchFarms's Avatar
PorchFarms
thank you, you nailed my point. i guess this arguement can also relate to tires. check your pressure when the tires are cold then check them after driving a while, same amount of air but different pressures.
Old Jun 10, 2011 | 07:37 PM
  #12056
ScottyDsntKnow's Avatar
ScottyDsntKnow
Wrong, a jet engine makes most of its power from compression via low pressure and high pressure turbines. Yes there is an igniter and afterburners do add a ton of thrust (at the expense of a ridiculous amount of fuel that is not sustainable for more than a few seconds at a time) but most of it is pressure. Hell, a ramjet operates on ONLY pressure and those things can make it all the way to Ludicrous speed.
From just reading the last few pages of this thread, there are a few people who really need to learn how a turbocharger actually works and how different one turbo app can be from another even with similarly sized motors. It isn't like an actual coal/nuclear powerplant where steam (exhaust) heats up and drives a turbine to turn at a fixed rate. There is a LOT to do with AR selection, housings, compressor blades, turbine blades etc...
Old Jun 10, 2011 | 08:13 PM
  #12057
parkland's Avatar
parkland
Uhh yeah, but a jet engine runs from a heat source.
It draws it's own air in, and expels exhaust but it does not require external forces to run.
The combustion is ongoing and causes the machine to run from heat.
In a jet engine, it is possible to run it exclusively from heat, and I stand by what I said. All you need to do is heat the air with whatever method you choose, and as long as you can get the BTU to the air, it will do the same job as any fuel.
Old Jun 11, 2011 | 07:20 AM
  #12058
ScottyDsntKnow
Doesn't suprise me that a 7.3 has gone over 1 million miles seeing as how they are made by International. Most big diesels in semis made by International and others are designed to go that long with just routine maintenance.
Old Jun 11, 2011 | 10:51 AM
  #12059
exiled's Avatar
exiled
Hey porch, I'm not sure what ur saying here. I think I've missed a page. I've been tied up w/ our wheat harvest.we're cutting 90-110bu an acre so I don't have much time to keep up.I've never seen 67 lb TW wheat before.
Anyway, cooler air outside should help you. When you compress air it gets hot. So you need the CAC to cool the compressed air because warmer or hotter air's molacules are spread out. You want dinser air going into the combustion champer. The closer the molacules the more the air. A tire has a higher pressure when hot because the air expaned its not anymore air.
The thing about the wheel turning above candles happen because as the air heats up it rises. So it moves. Ots still air its just that the mocules start moving around. If you have a surface that can catch the moving air you can harness the energy.
There pressure from the combustion. This pressure can be built by anything put in the exhuast system. Wiether its an exhaust brake, turbo, cats, or a muffler. An exhaust brake works by using and increasing this pressure. Heat its self isn't turning the turbine its the pressureized spent gasses coming from the engine. Turbos are built w/ materials to displace the heat. Heat actually is a enemy of the charger system.
Old Jun 11, 2011 | 12:50 PM
  #12060
parkland's Avatar
parkland
Engines in pickup trucks have it hard.
