Sponsored by: Real Truck
Gas vs PSD
Old Aug 12, 2010 | 01:23 PM
  #7126
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by Lead Head
And that was a 2V Pi V10 with less power then the 6.0 and 6.4. But it had more power then the 7.3, and look what truck it beat?
Sshh... you're lying, making stuff up and editting the video tapes.
Old Aug 12, 2010 | 03:19 PM
  #7127
monsterbaby's Avatar
monsterbaby
Originally Posted by Krewat
Where are you getting 1450ft/lbs for the diesel? That's incorrect.
Hey Art you might want ot look again, the one I currently drive has 1675 and some of the Cat's (before cat stopped building on road diesels ) had 2100lbs/ft tq. 1450 is actually a low powered unit.
BTW here is the current smallest Detriot offered for on road use (DD13) note the LOW end of the torque numbers is 1250
http://www.detroitdiesel.com/engines/dd13/
Their big engine produces 2050
oh and BTW hp is NOT a good way to compare anything when it comes to pulling. Now if your talking drag racing yes but pulling no. did you know that rotary mazda engines can be made to produce over 500hp. Dang I bet that sucker would pull your and my trucks up a hill backwards. Of coarse that's only producing 150lb/ft of tq which is what actually MOVES things but it does spin 18000 rpm. there is a bunch of guys that have Briggs and Stratton motors that will dyno at 70+hp bet if you hook 10 of them up ot equal the cylinders on a V10 they would pull a freight train. of coarse they only have 20lb/ft of tq.
But of coarse you CAN make comparisons where by coming up with gear ratio's that have no bearing on reality that the V10 hp will make all the difference. That does nothing for the discussion other then prove you can create a situation where the engine of your choice given the right conditions will be better. Like I said I have a 7.3 and you know if I gear it just right, put it into a 4x4 F750 chassis with floater tires and hook up against a F250 with street tires I could pull several trucks across a muddy field all at once.
but trying to make the comparison to electric engines is even worse apples to orangers then a gas to diesel comparison. you can NOT compare any internal combustion engine to a electric motor. There is a reason that trains are not actually powered by the diesel engine, they are electric. the diesel just runs a huge generator. Electric motors produce HUGE amounts of torque ALL the time. (they don't actually have a torque curve, they have a straight line, it's on or off but you adjust the HP rating by adjusting the rpms)
Old Aug 12, 2010 | 03:25 PM
  #7128
krewat's Avatar
krewat
Oh, you're not talking about a Powerstroke
Old Aug 12, 2010 | 03:37 PM
  #7129
monsterbaby
No, I thought I said I was talking about the Semi I drive, or in th ecase I mentioned it was one of the first ones I owned.
I have no illusions that my 7.3PSD is going to outpull the 3v V10s. I just like it cause it doesn't have the issues of the 6.0, it doesn't have a bunch of expensive emission controls (it didn't from the factory), it's paid for (which I think trumps ALL arguments here) and I can make my own fuel to run it.
Old Aug 12, 2010 | 03:42 PM
  #7130
Lead Head's Avatar
Lead Head
Detroit Diesel - The Detroit Diesel DD13<sup></sup> Engine
If you gave that rotary engine gearing so it could turn that 18,000 RPM at 60MPH it WOULD pull your rig backwards!
500 x 5252 / 18,000 = 146 lb-ft of torque. Using that same theoretical semi mentioned earlier (3.73 rear end, 40" tires) it would require a 9.6:1 ratio in the transmission to do 60 at 18,000 RPM. 146 x 9.6 x 3.73 = 5228 lb-ft of torque to the wheels.
Also, traction motors in locomotives are usually constant power motors. They put out the same horsepower regardless of RPM, which means torque has to go down as speed increases.
Old Aug 12, 2010 | 03:45 PM
  #7131
monsterbaby
and with the right gearing a lawn mower engine will out do all our engines.
This proves what again?
Old Aug 12, 2010 | 04:38 PM
  #7132
bill11012's Avatar
bill11012
Modular motor junkie
Thats why I drive an old 2V.
Old Aug 12, 2010 | 04:44 PM
  #7133
BigPigDaddy's Avatar
BigPigDaddy
Times Two
Old Aug 12, 2010 | 04:50 PM
  #7134
krewat's Avatar
krewat
Actually, it wouldn't, if you figure speed into it. You COULD gear a lawn mower engine down to where the torque would exceed the PSD or V10, but it would never EVER do it at 60MPH.
  #7135
2001400ex's Avatar
2001400ex
Okay kids, for the 40th time, here is what I am getting at. LOL
The 2V V10 is 310/425. The 6.0 is 325/560. In that last video that was just reposted, I think everyon can agree the 6.0 DESTROYED the v10, despite a small 15 hp advantage. The V10 was even programmed so I would imagine the V10 even had a hp advantage.
Okay, the 7.3 was obviously not running properly and was running hot with a 200k transmission. Even so, it is 250/505, so at least a 60 hp disadvantage.
Now tell me one thing, was the v10 closer to the 7.3 or closer to the 6.0? It was clearly a lot closer to the 7.3, so again, please try to tell me how hp is more important than torque? Or how the 12 hp advantage the 3V V10 has means it will outpull a 6.4?
Keep in mind, when engine makers design engines for trucks, they detune the hp for a gain in torque. One example of this, the Chevy 5.3 in 2006 was 295/335 while the Impala SS my wife has is 303/323. I can find other examples of when they use the same engine in trucks as the car, where almost always the truck has less horsepower and more torque than the car. Why do they do that? LOL
Old Aug 12, 2010 | 04:54 PM
  #7136
monsterbaby
Well then your 2v is every bit as good as my 7.3 and we beat the 6.4 and 3v guys all to heck
Ok beyond that factor.
i have a simple question, not just for the v10 guys but anybody here.
Which rpm is the 3v V10 going to pull better? 3250rpm or 4750rpm?
how about those with a 6.4 psd? 2000rpm or 3000rpm
and the 6.0 drivers? 2000rpm or 3300rpm
And lets not forget the 7.3 guys. 1600rpm or 2600rpm.... I will answer that mine pulls a lot better and holds a lot better as well as gets a LOT better fuel economy between 1600-1900 then it does anything north of 2000rpm.
OOPS almost forgot the 2v guys sorry. But I think yours is the same rpm rangers of 3250 and 4750
Old Aug 12, 2010 | 04:58 PM
  #7137
monsterbaby
That's the point, you can make up numbers and gear ratio's that have nothing to do with real life and it proves NOTHING. in an attempt to prove that the V10 will out pull a semi tractor trailer engine someone made up some gear ratio's that give a mathematical advantage to a higher rpm engine. But reality is much different.
Old Aug 12, 2010 | 05:05 PM
  #7138
2001400ex's Avatar
2001400ex
Monster, just wait until Josh comes back to the discussion! LOL
Old Aug 12, 2010 | 05:27 PM
  #7139
Scratcher's Avatar
Scratcher
The trick is who can swim when the river rises.
Ah................ well for that you need one of these. Both the PSD and the V10 will sink
******** style="height: 344px; width: 425px"><param name="movie" value="http://www.youtube.com/v/t0NJpUvS2R8"><param name="allowFullScreen" value="true"><param name="allowScriptAccess" value="always"><embed src="http://www.youtube.com/v/t0NJpUvS2R8" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="425" height="344">*********>
Old Aug 12, 2010 | 05:34 PM
  #7140
monsterbaby
What's really bad is even in Aug that isn't really that far removed. We are having major flooding issues around the state lately. I think there is something like 500 homes flooded out.
this picture was taken this week.
