Sponsored by: Real Truck
Gas vs PSD
Old Sep 17, 2009 | 09:06 PM
  #1696
phillips91's Avatar
phillips91
Originally Posted by bill11012
sorry, when you said silverado, I forgot about the 8.1.
I know next to nothing about it.
apparently i dont either lol. i was wrong on my hp and tq numbers i posted. i had to look it up to make sure. from an old gm website
"The base Vortec 8100 V-8 engine offers a maximum of 375 hp at 4600 rpm. Maximum torque, which is 490 lbs-ft, is at 3200 rpm, a popular cruising speed. The high-performance version offers a maximum 420 hp at 5000 rpm, and maximum torque is 505 lbs-ft at 4000 rpm."
thats not too shabby of an engine there. comparing the high performance to the base also shows you the problem with building a gas engine. as you increase hp and tq you also increase the rpms it takes to make those numbers. it may not be as fast as the high performance version, but i will take 490 tq at 3200 rpms over 505 tq at 4k rpms any day of the week when it comes to towing. i want power where im cruising, not where i have to downshift and run it harder.
Old Sep 17, 2009 | 09:16 PM
  #1697
phillips91's Avatar
phillips91
also, here are some numbers comparing the 8.1 vs a 3v v10 in identical motorhomes. this site uses the same numbers as the first post i made. 340 hp and 455 tq. so not sure where that other site got their numbers. either way, its right there with the v10.
Independent testing of 2005 Chevy 8.1 vs 2006 Ford v10, using identical motor homes down to the fabrics, showed the following:
<table class="normal" id="Table1" width="500" border="0" cellpadding="1" cellspacing="1"><tbody><tr> <td width="100">
</td> <td class="subsubhead" width="100">Chevy (sec.)</td> <td class="subsubhead" width="100">Ford
</td></tr> <tr> <td>0-60 Towing</td> <td>31.5</td> <td>34.1</td> <td>
</td></tr> <tr> <td>40-60 Towing</td> <td>14.3</td> <td>16.0</td> <td>
</td></tr> <tr> <td>50-70 passing</td> <td>20.2</td> <td>22.8</td> <td>
</td></tr></tbody></table>
Old Sep 17, 2009 | 09:31 PM
  #1698
Rush117's Avatar
Rush117
Originally Posted by KelVarnson
OK, I understand. But you do have to look at the whole picture. If you put 4:30's in a PSD, it will for sure out-accelerate the V10, but it will also top out at a pretty low speed, won't it?
The psd would theoretically top out at a lower speed. The question is whether that speed is higher than the limit within the PCM.
According to a quick calculation, a psd in 5th gear, 33 in tires, and 3.73 gears is turning 1,888 rpm. With everything the same except 4.30 gears, it is turning 2,176.
At 93 mph: 3.73 - 2,508, 4.30 - 2,891.
I'd like to note that larger tires will reduce the rpm numbers as well as the fact that these rpm numbers are below the max hp rpm of 3,000 for a 6.4. I wouldn't want 4.30's in my truck, but if I had them, it would pull even better and I would have no operational limitations...at least the way I would drive it.
Old Sep 17, 2009 | 09:39 PM
  #1699
Smokin''s Avatar
Smokin'
Smokin
Originally Posted by dwilliamsceg
I will be out enjoying my truck and you guys can sit in here and circle jerk each other on why your v10s are better than my 6.4 at pulling stuff across the country.
D.
Hey...I have nothin to jerk...
I hate being left out.
Have fun in UT. Post pictures.
Old Sep 17, 2009 | 09:52 PM
  #1700
KelVarnson's Avatar
KelVarnson
Originally Posted by phillips91
i have 4.10's in my 7.3 and i am doing about 2500 rpms at 70 mph. with 4.30s i would probably be doing about 2800 rpm. it redlines at 3600, so it would still have plenty of pedal left. it would probably top out at about 85-90 with the 4.30's. faster than i have any reason to drive a truck.
What about hitting the top of the diesel powerband too early, do you'se think that could be a problem? I don't know, just wondering. I think it could be part of the reason they stick with 3.73's mostly.
If this were the Club forum, I would have an appropriate response.
Old Sep 17, 2009 | 09:54 PM
  #1701
bill11012's Avatar
bill11012
Modular motor junkie
wow, so Chevy makes a gasser that will out pull the V10?
Old Sep 17, 2009 | 09:58 PM
  #1702
bill11012's Avatar
bill11012
well, I don't know about 4.30s, but I know with stock size tires the 6.4 with 4.88s has a top speed of 85, so I do not see why 4.30s would be a problem.
I said before that 4.30s, would limit it to 85 and I was wrong. I ment 4.88s and mistyped.
Old Sep 17, 2009 | 10:01 PM
  #1703
bill11012's Avatar
bill11012
well, I think with a circle jerk, you would have something to jerk, the person to the right of you would not.
Old Sep 17, 2009 | 10:07 PM
  #1704
Rush117's Avatar
Rush117
That is a good question. Without a chart, it's pure speculation. However, when you follow the hp logic, the peak hp is at 3,000 rpm so it shouldn't be a problem.
I think they stick with 3.73's for fuel economy. The psd can produce enough power to handle most towing applications while keeping fuel economy as a relative priority. If you went with steeper gears, you'd have a better towing rig but you'd take a hit at the pump. Although I don't think the hit would be a whole lot.
Old Sep 17, 2009 | 10:17 PM
  #1705
mudmaker's Avatar
mudmaker
The OBS psd offered 3.55 or 4.10 and the mileage difference was quite noticeable. The 95 my dad had and the 94 I had both had 3.55's and made much better mileage than the guys with 4.10's, but they would out pull us with ease. The 4.10 is a great pulling ratio for a 7.3, but the 3.73 is a great compromise.
Old Sep 17, 2009 | 10:21 PM
  #1706
bill11012's Avatar
bill11012
The 3.73s are the lowest you can get with a V10, and they really bog it down.
Old Sep 17, 2009 | 11:58 PM
  #1707
preppypyro's Avatar
preppypyro
That doesn't mean the V10 is a better motor, or that it's better for towing than the Cat (I'm sure it's not!), but the V10 will do more work.
Funniest thing Ive read all day! I hope your joking that you think a v10 engine would do more work then a cat c9.
I mean why do you guys think they make them with all that torque, and not have 800 hp low torque engines.
Some of ya fellas just gotta get behind the seat of a few of the lower horsepower higher torque 3406 cats, 350 cummins with a 13ish speed and 4.11 rear diffs, and tell me that a v10 truck could outpull it. Its insane to even think that.
Old Sep 18, 2009 | 12:10 AM
  #1708
95_Dually's Avatar
95_Dually
That is what I posted awhile ago. Ford has to make good milage numbers to compete with the Duramax. A lower gear will always make towing easier. The problem is running out of transmission gears for top speed.
I hope they do not close this thread because of a few HOT tempers. This is quite enjoyable. I am certain that a V10 and a PSD from this site will eventually meet and then they will see the results first hand.
Parts of this thread remind me of racing against Chevy guys. LOL
First they complain if you have slicks. Then they complain if you have nitrous. Then the complain your car is lighter. Sounds just like the V10 guys here. But you have a turbo, or you have a couple of mods. Whatever.
The real funny thing is they will have plenty of time to think of their excuses as they are trying to catch up to the PSD.
Old Sep 18, 2009 | 12:13 AM
  #1709
95_Dually's Avatar
95_Dually
it doesnt matter if its stock vs stock or even vs even. no matter what the competition, the v10 will always win. against every engine from every manufacturer. period.
v10 vs psd? v10 wins because it has more hp, and hp is what gets the job done when towing. v10 vs tundra? v10 wins because it has more torque, and torque is what gets the job done when towing. v10 vs psd? v10 wins because its faster. v10 vs tundra? who cares if the tundra is faster, towing isnt about drag racing. v10 vs 460? v10 wins because it gets better gas mileage. v10 vs psd? who cares about gas mileage, these are trucks, not 4 cylinders. v10 vs silverado? v10 wins because you have to run the chevy wide open to make any power, and you want power at low rpms for towing. v10 vs psd? v10 wins because it makes more power at higher rpms. and on and on and on......
When I read this, I could not stop laughing. Yep, the V10 is better alright. Just ask an owner. But don't ask him to compete against you, he would rather complain that it is not fair.
Old Sep 18, 2009 | 12:17 AM
  #1710
bill11012's Avatar
bill11012
Who has been making complaints that it is not fair?
