Sponsored by: Real Truck
Gas vs PSD
Old Sep 16, 2009 | 02:11 AM
  #1531
preppypyro's Avatar
preppypyro
Just make sure that civic has more then 365 horsepower, and install 4.30 gears in it and you can out pull a superduty v 10!
Old Sep 16, 2009 | 02:21 AM
  #1532
Quick444's Avatar
Quick444
Thank god I don't need any torque! Even the most souped up of Civics only push out like 40lbs of torque!
Old Sep 16, 2009 | 04:04 AM
  #1533
95_Dually's Avatar
95_Dually
Torque is what is needed to get that load moving from a dead stop. That is probably why the uphill test in the magazine article showed the diesel making it to the top quicker. It had more grunt from a dead stop than the V10 had. If you could hold the rpm's of the gas motor at the peak horsepower during takeoff than it might be able to beat the diesel using the HP formula. However, the V10 does not come stock with a 4000 stall converter in it. Besides it wouldn't last pulling 12,000 lb loads. I do not believe that feathering a clutch at 4000 rpm's while the truck is trying to get up the speed to match the rpm's would be that great of an idea either.
Again, both trucks are good trucks. I think a G2G would be a great idea. There are diesel drags happening in Redding Ca on Sept. 19. How about a meeting there?
Old Sep 16, 2009 | 04:10 AM
  #1534
95_Dually's Avatar
95_Dually
Originally Posted by Krewat
Then talk to my machinist who was redoing one of those motors just about every month. Totally stock, they were good for about 30K miles, and that's if you babied it.
I knew someone personally who had one. His lasted 12K before major engine repairs. And those "repairs" included head gaskets going south.
Compared to the T-bird SC (and it's related XR7), they were garbage.
I also new somebody that had one and it was very dependable. He also sent many a V8 home after he spanked him at a street race. I was one of them and my car turned 12's in the quarter.
I never saw a Super Coupe at the strip, are the quick?
Maybe the V10's could install a small shot of Nitrous on their trucks. Say a 100 shot. Then you could race your modified truck against our modified truck.
Old Sep 16, 2009 | 08:40 AM
  #1535
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
I'll be there - there's a sled pull also
Old Sep 16, 2009 | 08:58 AM
  #1536
Broncoholic1's Avatar
Broncoholic1
Originally Posted by Johnny Langton
Exactly.
Some of us are working on a turbocharger setup for our V10's. That'll even the playing field a bit and close up that "running away from" issue.
JL
LMK how the V10 turbo set up is going lots of happy 6.8
Edit:
Now that looks more like it Fords Green Engine:
http://www.drivingenthusiast.net/sec...ogen/index.htm
Old Sep 16, 2009 | 09:38 AM
  #1537
Kwikkordead's Avatar
Kwikkordead
Looks like they have to delete that second alternator if you want to run a blower.
Or make the blower belt extra long.
Edit: On second thought, just add a second fan pulley and route the belt around it, then to the alternator.
Old Sep 16, 2009 | 09:50 AM
  #1538
bill11012's Avatar
bill11012
Modular motor junkie
My 98 has 1 240 amp alternator. why does that one need 2?
Old Sep 16, 2009 | 09:58 AM
  #1539
Johnny Langton's Avatar
Johnny Langton
OEM alternators are between 105 and 130 amps-do you have an aftermarket?
JL
Old Sep 16, 2009 | 09:59 AM
  #1540
KelVarnson's Avatar
KelVarnson
In short, torque measures how much work can be done
That is incorrect. Torque is not a measure of work, it is a measure of force. You can have 500 ft.lbs. of torque, and zero motion, in which case, zero work is done. When you check your lug nuts, you're applying 140 ft.lbs. of force, but because the nut is not moving, you are doing zero work. You could hang a weight on the end of the torque wrench and walk away, and that force would be applied all day long, but would require zero energy, because zero work is being done. But the force (torque) is still there.
Power is force times motion, and the unit horsepower is a measure of work being done. In my examples with the two trucks, they are producing a certain amount of horsepower in each condition. If their engines are not capable of making those horsepower levels, it ain't gonna happen, no matter how much torque they are capable of generating.
Originally Posted by Quick444
So according to this, torque isn't relevant at all?
Now, did I say that? NO! Of course not. Don't put words in my mouth.
An engine that produces high torque (in other words, a diesel) will:
Be able to start a load easier.
Be able to transport that load while turning at a lower RPM, thus saving fuel and enhancing operator comfort.
So yes, it could be argued that a diesel is better for towing. *I* would, and have made that argument in this thread. I actually tow with my lower-horsepower diesel, because it is more comfortable and economical that my higher-horsepower/lower- torque gasser, which will tow cirles around it.
Old Sep 16, 2009 | 10:05 AM
  #1541
bill11012's Avatar
bill11012
double post
  #1542
bill11012's Avatar
bill11012
JL
after market from O'Riellys.
They said the factory had a 200 or 240, which did i want.
Old Sep 16, 2009 | 10:09 AM
  #1543
Johnny Langton
The O'Reilly's monkey behind the counter doesn't know what he's talking about.
130amp is the largest you'll see in an OEM alternator on a modular.
JL
Old Sep 16, 2009 | 10:14 AM
  #1544
bill11012's Avatar
bill11012
What about the cop cars?
They have one.
Do they really just put out 130?
  #1545
bill11012's Avatar
bill11012
double post
