Crewcab Only Thread.
Old Oct 29, 2010 | 06:05 PM
  #1231
mytybug's Avatar
mytybug
crummy that is a nice truck. Are those 35's
Old Oct 29, 2010 | 06:16 PM
  #1232
crummy's Avatar
crummy
Yes there, 35x12.5x16.5
Old Oct 29, 2010 | 06:20 PM
  #1233
mytybug's Avatar
mytybug
I have a set of 35 bfg ta's on 16" 8 lug spokes when I get this truck going, at the moment she has a set of widow maker split rim's on.
Old Oct 29, 2010 | 07:21 PM
  #1234
fordtrucknut's Avatar
fordtrucknut
No frame mods required at all on the setup up I did...only mod is having to cut a notch in core support/radiator mounting (Depending which radiator you are running)...and shortening steering shaft or replacing it with a shorter one.
Old Oct 29, 2010 | 09:47 PM
  #1235
mytybug's Avatar
mytybug
truck nut what did you do for a pitman arm and drag link, and do you have any pic's of your conversion in progress and done?
Old Oct 30, 2010 | 12:11 AM
  #1236
fordtrucknut
78/79 F-250 4x4 Pitman arm...ES380R and ES380L Tie Rod ends (No Reaming required...they are the same as a 69 to 72ish F-250 4x4)..Custom made DOM sleeve (6.5 inches long) Local 4x4 shop did the one I use...But I was planning on selling my kit at some point...so I bought the Left hand die (7/8 x 18tpi)..Custom designed plates to bolt box to frame using original bolt holes and a support bracket...factory 2wd hoses work...and the steering shaft I used was from (IF I remember correctly) about a 73 F-100 4x4..(Shorter)...and had to adjust column back towards seat about an inch...somewhere I have polaroids of it...not sure exactly where....and it is on a truck...test drove and everything...worked wonderful.
Old Oct 30, 2010 | 02:47 AM
  #1237
78_f150's Avatar
78_f150
crew cab body on a 78 2wd std cab lwb chassis. dana 60 diffs. still need to install my np205 and drivelines. its a work in progress.
Old Oct 30, 2010 | 09:22 AM
  #1238
teds74ford's Avatar
teds74ford
That's looking really nice!
Old Nov 2, 2010 | 12:29 AM
  #1239
76Hauler's Avatar
76Hauler
One more vote for Ol' Yeller, what a badd-a$$ rig. This aint for haulin' wood, it's for haulin' A$$! Purpose built trucks are just plain ol' awsesome. No, wait, I know, I know, maybe if we jacked up the rear real-real high and threw a plow on it, it would get respect!
Originally Posted by ChaseTruck754
Some inspiration for my crew...
I believe it belongs to one of the employees at autofab.
Old Nov 2, 2010 | 10:00 AM
  #1240
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I'm diggin it and am looking into fabing up my own sort of race back/cab over rack based of the idea I got from here, always handy when you own a short bed. IMO
That truck is cool in so many ways, I'd own it! All it takes is an open mind to see its possibilities.
Old Nov 3, 2010 | 01:17 PM
  #1241
ChaseTruck754's Avatar
ChaseTruck754
Not mine and not a solid axle (makes it even cooler!), but still 4wd and one of my favorites
Old Nov 3, 2010 | 02:21 PM
  #1242
Skip1970's Avatar
Skip1970
i think i seen this one at ecology auto wrecking in phoenix az in the late 90's
Old Nov 3, 2010 | 02:23 PM
  #1243
ChaseTruck754
It's quite possible. Truck was built in AZ and he might have gotten the cab and frame from there to start the build.
Old Nov 3, 2010 | 02:27 PM
  #1244
Skip1970's Avatar
Skip1970
no it was a customers in the parkinglot, on one of their 50% off days.. unless there is more then one dent side with a TTB frontend
Old Nov 3, 2010 | 02:30 PM
  #1245
ChaseTruck754
Don't think this thing was done being built in the late 90's. I was thinknig it was more like a 2002ish timeline. It has been a while though so I could be off, and yes I highly doubt there are 2 with TTBs out there... I do know of a 78/79 bronco with a d44 TTB front though. Got a couple pics of that one as well.
