No start
Old Aug 25, 2007 | 10:06 AM
  #106
F0rdF0rever's Avatar
F0rdF0rever
Looks like im going to have to run to sears. I dont have a socket deep enough for the ipr. I just removed the spare ipr from the old hpop and had to use a wrench. Thats not going to happen with the hpop in the truck.
Old Aug 25, 2007 | 10:08 AM
  #107
tjbeggs's Avatar
tjbeggs
they don't make sockets deep enough. you need to use a wrench anyway. hope you haven't left yet!
Old Aug 25, 2007 | 10:09 AM
  #108
F0rdF0rever
I havent left yet TJ. You saved me a trip. So does this mean the hpop has to come out?
Old Aug 25, 2007 | 10:11 AM
  #109
tjbeggs's Avatar
tjbeggs
no but the fuel filter housing is in the way. The last one I did was on my 95 and I was able to remove the FPR and get enough room. may need to unbolt the fuel filter housing just so you can push it aside.
Old Aug 25, 2007 | 10:21 AM
  #110
c00nhunterjoe's Avatar
c00nhunterjoe
oh god no! it will come out, you can get in there it just takes some finegeling, i have never pulled anything other than the top plastic cover off, and they do make an ipr socket but its more of a pain than the wrench.
Old Aug 25, 2007 | 10:24 AM
  #111
MagKarl's Avatar
MagKarl
I just want to say as an outsider with zero technical input to add here, that I'm amazed at the time, effort, and commitment you guys are putting in to help FordForever out. I cruise the other forums and rarely see the kind of help being shared like happens here. That's why I'm here.
Old Aug 25, 2007 | 10:44 AM
  #112
c00nhunterjoe
i'm just here to try to help you guys out, i got so disgusted at ford for the way we had to deal with repairs and flat out lie to customers that i am going to reach out as far as possible to keep you from having to ever go there for a problem. i appreciate the comment it makes it all worth it
- fordforever, sorry for the delay the page wouldnt load it said technicla diffuculties and an email has bean sent off, or some crap like that, it happens alot lately to me but i'm back finaly after 15 minutes of clicking refresh
Old Aug 25, 2007 | 10:45 AM
  #113
Action4478's Avatar
Action4478
A socket & some vice grips worked for me...
Old Aug 25, 2007 | 10:46 AM
  #114
Action4478's Avatar
Action4478
Has the IPR been isolated from the Injector O rings?....
Old Aug 25, 2007 | 10:50 AM
  #115
tjbeggs's Avatar
tjbeggs
that may work on a sueprduty but every OBS I have done you can't even get the coil off with out moving the filter housing.
  #116
c00nhunterjoe
he doent really have the equipment for that, the ipr is easy enough to pull out. i dont know if his scanner has active comand functions, if it did he could do an airleak test by closing the ipr and removing the icp then instal a homemade adapter in the head with an airchuck fitting and slap your house compresser line on, then all you do is follow your ears for the leak
Old Aug 25, 2007 | 10:51 AM
  #117
c00nhunterjoe
i just replaced the one on my truck not 6 months ago as preventitive maintance
and have you had any problems getting on in the last half hour?
Old Aug 25, 2007 | 10:53 AM
  #118
Action4478's Avatar
Action4478
We moved a couple small lines out of the way & it took about 10 minutes to do this...At least that is how it went on the 97...Does he have the pics of the R & I yet?....
Old Aug 25, 2007 | 10:55 AM
  #119
tjbeggs's Avatar
tjbeggs
I haven't had any site problems. That little blue box is the key. Plus I was away unloading my truck for a half hour.
  #120
F0rdF0rever
That was easy to change. All I had to do was get the fpr out of the way. Tried cranking it but wouldnt turn over. Im going to let the batteries charge and run the pid again.
