No start
Old Aug 25, 2007 | 11:41 AM
  #136
c00nhunterjoe's Avatar
c00nhunterjoe
well, 300 is better than 38, but you are still shy, you still have an icp issue, still no codes in the pcm i assume? your ipr may be bad as well, do you have a function that you can command the ipr? if so you can check for a possible air leak in the system by removing the icp sensor and screwing a airhose chuck into it and hooking your shop air hose up,(you have to make an adapter) tehn close th ipr valve and listen for air leaks, if you dont hear anything then the ipr is bad
Old Aug 25, 2007 | 11:44 AM
  #137
F0rdF0rever's Avatar
F0rdF0rever
This software doesnt have that Joe. IS there another way?
Old Aug 25, 2007 | 11:46 AM
  #138
c00nhunterjoe
yes, you can remove 1 high pressure oil line at a time, your choice left or right, get a fitting that will block that line off, this will isolate a bank of injectors\rails, try to start, if nothing reconnect and do the other side, if still no start then block both lines and crank while watching the icp if it is still below 500 you have an ipr or pump problem
Old Aug 25, 2007 | 11:48 AM
  #139
c00nhunterjoe
i just rechecked the book to cover myself here as its been a while, the book says if you get to the point that you block both lines and crank then you need to see a minimum of 1000 psi, thats rigth 1000, if you dont get that then replace the ipr valve and retest
Old Aug 25, 2007 | 11:49 AM
  #140
c00nhunterjoe
oh and also according to the book, 54% is max ipr for a 94-97 7.3 no start condiotion so the scanner may be a little off
and cranking ipr is less then 30 on a normal engine
key on engine off is 14%
Old Aug 25, 2007 | 11:57 AM
  #141
F0rdF0rever
I need to get a plug I dont have anything here. Do you know what size ill need? Also, what are the odds of two of my iprs being bad?
Old Aug 25, 2007 | 12:06 PM
  #142
c00nhunterjoe
dont know the size, you put a new ipr in?
Old Aug 25, 2007 | 12:07 PM
  #143
c00nhunterjoe
if thats a brand new ipr then i'd say pull a whole line off and take it with you, get 2 plugs and try blocking things off
Old Aug 25, 2007 | 12:11 PM
  #144
F0rdF0rever
Well its not new but it and the hpop came of my truck it was working. I had to replace the hpop due to a stripping fitting. The one I bought came with a ipr in it.
Old Aug 25, 2007 | 12:14 PM
  #145
c00nhunterjoe
i'd isolate the heads first then the pump, go from there, you definatly improved your oil pressure but ther is something else preventing it from building, whether its the new ipr, a leak or a bad pump
Old Aug 25, 2007 | 12:15 PM
  #146
c00nhunterjoe
for dhas no way to physicaly test the pump other than isolate it and then replace the ipr, only then do they say to replace the pump
Old Aug 25, 2007 | 02:05 PM
  #147
F0rdF0rever
It started! But only on one bank, the drivers side. I plugged the passenger side and it started up. While cranking I saw 1300 on the icp. Now when I plugged the drivers side I got 0 on the passenger side. With both plugged I got the same as when they arent plugged, about 300. What does this mean?
Old Aug 25, 2007 | 02:07 PM
  #148
c00nhunterjoe
you need to pull the valve cover on the passenger side and inpect the injector dumps while cranking, odds are one of them will be pouring oil out compared to the others, you probably have an injector bad...oh and unplug all of the valve cover harnesses, there should be no oil at all from the injector spouts while cranking, just rechecked the book,
Old Aug 25, 2007 | 02:12 PM
  #149
Action4478's Avatar
Action4478
Wonderfull, now you are getting somewhere....
Old Aug 25, 2007 | 02:15 PM
  #150
F0rdF0rever
So when im cranking the engine the only injector that has oil coming from it will be the bad one? And I crank it with the valve harnesses off?
