Bolt dropped down the plenum...
Old May 4, 2021 | 08:17 PM
  #196
RA101725's Avatar
RA101725
Banned
Originally Posted by Sous
A friend of mine in NC traded in his 5.9L Cummins Dodge for a 2018 6.7L Cummins RAM. Despite the fact that the 2018 is more power and comfort, he claims he would like the 5.9L back. His 2018 has the CP3, so he is in the clear regarding that mess, but he misses the old diesel.
Since he bought the 2018 new, it has been in the shop 5 times for sensor failures and various other things. Now that it is out of warranty, he is skeptical about how long they will keep it to tow their Airstream cross country. If anyone thinks Ford is immune to these issues that cost hundreds if not thousands of dollars, jump over to the 6.7L forum. Same goes for gasoline engines like some of the 3.5L's or the new 7.3L.
I follow a Ford tech on YouTube simply for education sake and he had a sub 1000 mile new 7.3L gasoline truck in for a front cover replacement. Maybe this is 1 in 1,000,000 bad luck, but maybe not.
I sincerely hope my truck is with me the day I am no longer able to drive because paying $40,000 - $60,000 for a "reliable" new to me (used, new are too expensive) truck is not a possibility based on budget or desire.
Here's one to lighten the mood and put things in perspective...nice older guy with a fun story.
Gets real scary when you contemplate actually trying to make a living running a truck.
Old May 4, 2021 | 09:28 PM
  #197
bigb56's Avatar
bigb56
Yes they all have issues. There is one over on the Sprinter forum right now with a failed engine at 1,300 miles, barely off the lot. From what I have read the Bluetec engines have more than their share of emissions related issues. A relative has always drove Cummins, he had one get a stuck injector and melted a piston. Even though he was out of warranty the dealership took care of it, probably with help from Dodge. Out of my 3 diesels the PSD is by far the oldest and highest mileage of the three but I have a certain trust in it that I don't have with the 2 newer diesels.
Old May 5, 2021 | 07:12 AM
  #198
Walleye Hunter's Avatar
Walleye Hunter
How TF did that thing get all the way back to #7???? That bolt was impersonating a roulette ball to make it past the easy holes!!
I hate that this happened, but glad you have the right attitude. You know we are all rooting for you and still hoping for the best outcome given the circumstances.
Thanks for the update!!!
C'mon man, haven't you ever lost a bolt, screw, spring, pin, etc in your shop, only to find it across the world at some later time when you were looking for something else that you dropped? That stuff all has wings.
Old May 5, 2021 | 07:19 AM
  #199
FordTruckNoob's Avatar
FordTruckNoob
Gremlins are real. That's all I've got to say.
Old May 5, 2021 | 07:42 AM
  #200
Listor's Avatar
Listor
Oh boy do i agree with that! LMAO
Old May 5, 2021 | 08:21 AM
  #201
RA101725's Avatar
RA101725
Banned
I recently found a small drift punch that I thought I'd lost a long time ago sitting on top of my fuel tank. Found it when it took the catwalk decking off to have a bolt repaired on the receiver hitch. Why I put it there I have no idea...I normally use it to tap a hole in the oil filter at oil change time. It had been back there for 6 months I bet lol.
Old May 5, 2021 | 01:11 PM
  #202
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Great video Brandon, thanks for sharing that with us. 30,000 mile oil changes, that is great! 120,000 miles on the front tires...
Seems like a nice fella to chat with.
Originally Posted by bigb56
Yes they all have issues. ... Out of my 3 diesels the PSD is by far the oldest and highest mileage of the three but I have a certain trust in it that I don't have with the 2 newer diesels.
Yes they do. I am a firm believer in anything designed or made by humans can and will fail at some point.
I trust my truck, but that is most likely because the dealer being involved is not a requirement when something needs attention. I read the other day that injectors for the new 6.7L PSD have serial numbers that need to be programmed into one of the modules in order to work.
Don't know the validity of the statement, but it wouldn't surprise me. I can only assume RAM has a similar requirement for essential parts on their trucks.
Old May 5, 2021 | 02:05 PM
  #203
SkySkiJason's Avatar
SkySkiJason
Not only do most new cars need ‘programmed’, they connect via WiFi at the stealership .
They have the option to review your stored data and see top speed, he type of braking events that have occurred and the times of day the vehicle is used. Ask Tiger how this data can affect you.
Old May 5, 2021 | 04:43 PM
  #204
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
most new cars connect via WiFi at the stealership .
They have the option to review your stored data and see top speed, the type of braking events that have occurred, and the times of day the vehicle is used.
Oh, that's just great.
Old May 5, 2021 | 04:56 PM
  #205
SkySkiJason
That what he always says. The promiscuous golfer sounds like he’s saying something else about this.
Old May 6, 2021 | 05:52 AM
  #206
FordTruckNoob
Wait until they start putting these into personal vehicles.
CharlyG
All Things Towing
Oct 11, 2016 04:32 AM
Bierisch
Feb 18, 2014 11:43 AM
DieHardChief
Dec 1, 2013 11:51 AM
ranger714
1983 - 2012 Ranger & B-Series
Mar 23, 2007 05:24 AM
Skandocious
Feb 23, 2007 09:19 PM
