Bolt dropped down the plenum...
Old Mar 21, 2021 | 09:53 PM
  #121
clineco's Avatar
clineco
Originally Posted by Listor
Here too , i was sick to my stomach when i started reading this, You are handling this quite well , look behind all the pulleys!
I'll have another look in the morning. If it was behind a pulley, I wouldn't have gotten a hard stop when I turned it over by hand would I?
Old Mar 21, 2021 | 10:03 PM
  #122
Walleye Hunter's Avatar
Walleye Hunter
If you were real lucky and it got spun in a way that jammed it, it could happen.
Old Mar 21, 2021 | 11:32 PM
  #123
b00stleak's Avatar
b00stleak
Not trying to be a smart butt, but have you listened to the video? No way this is something that was missed before.
I just listened again with headphones on. Yep definitely not missable. I also didn't listen to the whole thing before.
Old Mar 22, 2021 | 02:41 AM
  #124
Shovelheadrob's Avatar
Shovelheadrob
@SkySkiJason as you're the only person here with a head on the bench, did you try the bolt past the valve with the thread towards the port? Not trying to be a smartass, but if that's not a possibility either we can pretty much eliminate the likelihood of the bolt entering the combustion chamber.
Old Mar 22, 2021 | 02:57 AM
  #125
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Originally Posted by Shovelheadrob
@SkySkiJason as you're the only person here with a head on the bench.
It's one thing being the only person here with a head on their shoulders...
It's quite another being the only person here with a head on the bench.
That's next level.
And to think, this is neither a judiciary nor a brain surgeon's forum.
Old Mar 22, 2021 | 03:03 AM
  #126
Shovelheadrob
That's next level.
Haha, you're really trying for a new career these days, don't give up the day job just yet though, your serious input is invaluable too
Old Mar 22, 2021 | 03:24 AM
  #127
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Wink
Nah it's FTE, and what normally follows is a posse of folks from all over chiming in with a delightful combo of lived experience, internet lore and camaraderie. Maybe right, maybe wrong.
At the moment my best advice is pull the VCs and the GPs and stick your borescope in each GP hole. I expect you will find that damnable bolt imbedded in the piston where it can slam into the head with each stroke. Would explain why you had a hard stop on barring it over by hand.
Additional advice is.... do no crank it further. If the worst case scenario is correct we need to lessen the cost of rebuilding.
Old Mar 22, 2021 | 06:52 AM
  #128
SkySkiJason's Avatar
SkySkiJason
I opened valves to ‘about’ 1/2” using my fat max tape measure...
I was able to get bolt way down in valve, but not through it.
This pic is like a kick in the gut.
This represents the worst case scenario and may not be possible with actual valve lift (I think the valve is open more here than it really opens).
Old Mar 22, 2021 | 07:57 AM
  #129
brokestroke's Avatar
brokestroke
If the bolt lodged the valve open and it made contact with the piston. It could bend the valve enough allowing the bolt to fall right in.
Old Mar 22, 2021 | 08:13 AM
  #130
F350towing's Avatar
F350towing
If this was the case, when in the video it went from intermittent to steady wouldn’t there be a corespondent misfire. If there was a bent valve not sealing wouldn’t that quickly become evident.
I wasn’t there, but have watched the video a few times now and it didn’t appear that the motor even skipped a beat.
Old Mar 22, 2021 | 09:25 AM
  #131
SkySkiJason
I have a tendency to agree with this logic.
I expect a piston striking this bolt or a valve stuck open because of bolt would be more than a ‘ticking’ and produce a difference in the way the engine runs.
There is barely the thickness of valve before it strikes the piston and there is basically no space between flat part of piston and head.
Could we be hearing the bolt bouncing around above the valve??
Still hoping removing the belt allows engine to rotate and bolt is behind water pump pulley. (I’ve ‘lost’ more than one bolt or socket there...,)
Old Mar 22, 2021 | 12:26 PM
  #132
RacinJasonWV's Avatar
RacinJasonWV
I also agree with this logic.
If the valve was stuck open hitting the piston then the compression stroke should be sending the air back up the intake since the valve is not sealing. This should be easily heard and show a misfire.
If the bolt were somewhat hiding in the bowl then I would expect the injector to be destroyed almost immediately resulting in a misfire.
There is not room for a bolt on top of the flat of the piston. Back in the day I had a glow plug tip get lodged in the piston. It had a solid tick tick tick with nothing more than a piece of sheet metal imbedded in there. There was also a piece of debris under the exhaust valve resulting in a “misfire” due to no compression and resulting white smoke from I burnt fuel. Of course the OP didn’t have time to check smoke situation in this case.
It seems reasonable that it could be smacking around inside the intake port.
I’m hoping for the best. Hopefully you find it nestled around the pulleys.
Old Mar 22, 2021 | 02:26 PM
  #133
BA86f250's Avatar
BA86f250
Gooogle-fu says cam lift is 0.43 inches.
Which is good because bolt easily hides in the piston bowl.
Is that actual cam lift or valve lift after the rocker? Not sure what the rocker ratio is on these. If that number is actual lobe lift then it might make it through since valve lift will be a bit more after the rocker. I know you're well aware of how a pushrod v8 functions, mostly just asking so I know for future reference.
Edit: looks like you talked a bit more about this while I was typing
Old Mar 22, 2021 | 05:40 PM
  #134
SkySkiJason
This says .400” valve lift and 1.6:1 rocker is stock if I read it right.
http://swampsmotorsports.com/files/7.3L_Stage2.pdf
Old Mar 22, 2021 | 08:19 PM
  #135
BA86f250's Avatar
BA86f250
Thanks, for some reason the link won't work for me. Is it working for everyone else?
