Pull valve covers and look for loose/bent pushrod.
No it will move backwards. I'm debating on what to tear into next...if I remove the valve covers and see a bent/loose rod, then what? Honestly, I don't know what that means for me. lol There is only so much I'll be able to do myself before I have to take my truck somewhere and have them tear it down.
I'm wondering if I should try to go in and remove the plenums again and get another look. Maybe that's just a waste of time.
Yes sir! Heavy duty nitrile gloves over the openings immediately after setting the intake Y-pipe down.
I guess I was thinking of other images I had seen on here before. I wanted to set the record straight though, as I always do if/when I make a mistake or misstate something I thought to be a true when in fact it was not.
I hope @clineco comes back soon with a VICTORY update.
