Rethread a bolt
Old Nov 30, 2013 | 09:14 PM
DieHardChief's Avatar
DieHardChief
Lightbulb Rethread a bolt
Im going to attempt to rethread a bolt. I got a thread restorer kit.
the bolt I need to rethread is the left side of the thermostat housing.
Ive never had to do this before, seems simple, anyone got any advice for me?
if this doesnt work what else can I do?
I was thinking I may have to cut the the bolt off, drill it, thread the new hole and use a bolt to tighten it down, I hope I dont have to do all that. PIA!
Old Nov 30, 2013 | 09:22 PM
devino246's Avatar
devino246
Wait, are you chasing the threads on a stud, or what? Your wording is just confusing.
Old Nov 30, 2013 | 09:27 PM
JWC 3's Avatar
JWC 3
^ Yes ... Is a stud stripped , bolt stripped . bolt/stud broke off in hole ? What is going on ?
Old Nov 30, 2013 | 09:31 PM
Old93junk's Avatar
Old93junk
Sounds like he is chasing the threads on a stud............hope there is enough room to turn the thread die with the stud in place on the truck.
Old Nov 30, 2013 | 10:00 PM
devino246's Avatar
devino246
If it is indeed a stud, it'd be easier to clamp a pair of channel locks on the stud and back the whole thing out. Soak with penetrating oil for a few hours and wiggle it back and forth to free it up.
Old Nov 30, 2013 | 10:13 PM
DieHardChief
Thanks guys, you got it, Im chasing threads.
Old Nov 30, 2013 | 10:15 PM
DieHardChief
Thanks man, this makes more sense if I cant fix the threads properly.
Old Nov 30, 2013 | 10:27 PM
JWC 3's Avatar
JWC 3
I find gentle heat with a propane torch and penetrating oil ,alternating after cooling , works good to free frozen fasteners . Devino's sudgestion of vice grips helps sometimes !
Old Dec 1, 2013 | 11:51 AM
DieHardChief
THanks everyone, I was able to fix the thread, worked perfectly. I used the 5/16 rethread tool bolt and it cleaned and cut them right.
pvatki
1983 - 2012 Ranger & B-Series
Sep 29, 2009 05:38 AM
Fordy Four
May 7, 2008 11:07 PM
scottie2hottie
Garage & Workshop
19
Jun 5, 2007 12:07 AM
ranger714
Mar 23, 2007 05:24 AM
