2020-2022 Super Duty FORScan Spreadsheet
#1771
#1772
I'm sure this has been asked a million times in this thread being 100 and some pages long but since the name isn't correct with this being a 20-21 thread is there a spreadsheet for the 2022 sync4 changes? I've found the 2022 one on the tremor site but still doesn't have as many changes as the 2020 and 2021s have. Thanks
#1773
21+ F150 ForScan Spreadsheet
ZooDad
#1774
#1775
https://www.fordtremor.com/threads/f...for-2022.5886/
#1776
2022 F350: Was able to make several mods via ForScan without any problem using the 2020 - 2022 Superduty spreadsheet. However, when it came to adding temps to the gauges, I'm wondering if there is an update missing from the sheet? For the other changes, the "labels" of what I wanted to change matched between the spreadsheet and what I found in ForScan. But for adding temps, there isn't an item called "Temps on Gauges" in the IPC list. Below is the line item from the spreadsheet:
Temps on Gauges IPC 720-07-01 xxxx x**x xx-- E5-Brake Controller 65-No Brake Controller A5-Adds Temp w/o Boost and menus
Since there isn't a match for that "label", I looked at the individual gauges in the list such as transmission temperature, but that was already listed as enabled. But no temp displays. There is only an enable or disable option, no other options as listed on the spreadsheet. Anyone have any ideas on this one? Thanks.
#1777
Originally Posted by personanongrada;[url=tel:20665425
20665425]2022 F350: Was able to make several mods via ForScan without any problem using the 2020 - 2022 Superduty spreadsheet. However, when it came to adding temps to the gauges, I'm wondering if there is an update missing from the sheet? For the other changes, the "labels" of what I wanted to change matched between the spreadsheet and what I found in ForScan. But for adding temps, there isn't an item called "Temps on Gauges" in the IPC list. Below is the line item from the spreadsheet:
The following users liked this post:
#1778
Where did you enter E5? When you go to IPC in the menu, are you using the As Built option and changing it there, or the other not As Built (simplified) option? I'm guessing the more complicated option, maybe I'll have to take a look at that. I used the easy option for all the other changes.
#1779
ZooDad
#1780
Good morning
I changed the power mirrors originally in the regular dash options to auto fold at lock and unlock when I first bought the truck. Then last week I went into the as built module and changed the mirrors to the Lincoln mod. So now what happens is. I unlock the doors and I can open all other doors and close. Mirrors stay in closed mode. When I open the drivers side door, at that time the mirrors open. Then again when I lock doors, mirrors fold back in. I'm okay with this but I thought that they would only open with ignition on and close when off. What is the correct answer ? 2022 F-350 Thanks
#1781
Hello all,
First time post, long time lurker. Recently started to work with Forscan on my rig (2022 F450 Limited), two questions;
1. What changes are applied to BCM with Ford SSM 51140 service bulletin to reflash BCM for Deep Sleep issue on June and later 2022 Superduties? I am hopeful I can do this with forscan vs. taking into stealership and having to rewrite all BCM items.
2. I seen a couple members showing >21 MPG with the 6.7, how are these numbers possible? I have had 3 6.7's starting with first year release in 2017, all with mods and none able to reach these numbers.
Thanks ahead of time for the feedback.
DDD
DDD
#1782
Hello all,
DDD
DDD
#1783
I have a '22 450 and I can get 17 mpg with a tailwind, cruise set at 70 mph, level ground maybe. I don't know how you guys get such high numbers. I never do.
This is technically 3rd 6.7 PSD. 1st was first gen with a 6 speed, and tow third gens with 10 speeds. My results have been better with the 10 speed, but still not anywhere near 20 mpg unloaded.
#1784
Thanks. I was finally able to take the time to try it and it worked. No big deal. I was afraid to go in and change any of the As Built items but now that I see how it's done it was pretty easy. Thanks again!
#1785
always remember to back up the module(s) before you make changes for the just in case. Ask me how I know this !!🤦♂️
ZooDad
