2017-2019 Super Duty FORScan Spreadsheet
Old Oct 24, 2016 | 07:59 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
NOTICE: Most of the links below are to online resources outside of the servers and control of Ford Trucks Enthusiasts (FTE). Examples of outside resources include Google Docs and FORscan.org. Please understand that neither FTE nor Internet Brands is responsible for the content contained in outside resources. While the list of links below is provided for the convenience of FTE readers, the provision of these links does not constitute an endorsement, nor any guarantee that the content contained in outside resources is suitable and/or absent of malware.
LINK to FORScan Spreadsheet for 2017-2019 Super Duty trucks:
2017-19 Super Duty (maintained by EpicCowlick)
FORScan SPREADSHEETS
Dynamically maintained and hosted by the Authors listed
Links to FORScan SPREADSHEETS on Google Docs:
FORScan DISCUSSION THREADS
Search for answers and ask your questions here
Links to FORScan DISCUSSION THREADS on Ford Truck Enthusiasts Forums:
FORScan TUTORIALS
Read FAQ's and Tutorials FIRST before asking questions.
Links to FORScan TUTORIALS on various sites:
NEW! FORScan HELPING HANDS
A Directory of FTE Members Experienced with FORScan who may be willing to help you!
Links to a spreadsheet of FORScan Helping Hands on Google Docs:
What is FORScan?
General description of SOFTWARE that bidirectionally reads codes, modules, and As Built Data of Fords
  • FORScan is software synthesized from proprietary code for bi-directional communication with electronic modules in Ford, Lincoln, Mercury, and a limited number of Mazda vehicles.
  • As the name implies, FORScan only works on Ford's family of vehicle lines.
  • At the basic level, FORScan can read and clear legislated Diagnostic Trouble Codes of emissions related components that illuminate the Malfunction Indicator Lamp.
  • FORScan can also read and clear DTCs stored in memory for non emissions related Ford proprietary chassis modules that are not legislated and that basic OBDII readers cannot detect.
  • Beyond DTCs, FORScan can also monitor Parameter IDs (PIDS) in real time as the vehicle is operating, providing diagnostic information similar to an OEM scan tool.
  • More versatile than pro scan tools, FORScan works with Windows laptops, iOS devices, Android devices, and Android stereo head units for portability and even full time vehicle integration
  • In concert with a tablet or aftermarket head unit, FORScan can facilitate another "gauge panel" displaying PIDS and vehicle data not available to be seen in the instrument panel.
  • The monitored data captured by FORScan can be downloaded onto a spreadsheet or graph, synchronized in time to create data recordings of notable performance changes during driving events.
  • However, the ULTIMATE in utilizing FORScan in 2011 and newer Ford trucks is vehicle personalization, enabling and customizing factory features hidden in trucks network of modules.
Why is FORScan such a BIG DEAL?
What are people doing with FORScan on their brand new warrantied vehicles?
  • In a nutshell, new vehicle features and functions can be customized using FORScan.
  • People have capitalized on FORScan's ability to read, write, and change As Built data in vehicle system modules.
  • For manufacturing efficiencies, the same component module might be installed in multiple vehicles and trim levels, yet function differently based solely on software settings, per the options ordered.
  • Many "options/features" are ENABLED on higher trim levels, but are DISABLED or not available on lower trim levels.
  • By changing the data in the As Built area of the modules, these "options/features" can become available and activated on vehicles not originally equipped with the option.
What kinds of COOL CHANGES can be made with FORScan?
A list of some, but not all, of the features and personalizations folks have tweaked in their trucks:
  • Exterior Light Control
    • Bambi Mode (High Beams with Fogs On)
    • Remember Fog Lights on Start Up
    • Daytime Running Lights with Headlights
    • Daytime Running LIghts with Turn Signal (Switchback)
    • Parking Lams on with Low Beams for DRL
    • Halogen to LED Turn Signal Conversion
    • Outer Halo C Clamp Lights as DRLs
    • Turn Signal Flash Count
    • Bed Lamp Install
  • Interior Light Control
    • Courtesy Lamp Fade In / Fade Out
    • Ambient LED Lighting on Entry
    • Ambient LED Lighting when Door Ajar
    • Ambient Light Sensor Speed
    • Puddle Lamp Illumination Time
    • Dark Mode - Disable Illuminated Entry / Exit
  • Horn Control
    • Double Horn on Lock with truck running and without key FOB
    • Double Honk without KEY
    • Disable Panic Alarm Horn
    • Determine # of Fob Button Presses to Engage Panic Alarm Horn
  • Chime Control
    • Disable Door Ajar Chimes
    • Disable Key in Ignition Chime
    • Disable Triple Ding at Start Up
    • Disable Driver's Seat Belt Chime
    • Disable All Seat Belt Chimes
  • Instrument Panel Control
    • Numerical Temperature values on Gauges
    • DPF % Remaining on Screen
    • Fuel Tank Size
    • Boot Screen Animation - Change to different theme, or eliminate for faster boot up
    • Sync 3 Theme
    • Bluetooth Name
    • Heated / Vented Seats Icons on Home Screen
    • Add Average Speed to Trip / Fuel Menu
    • Add Climate Screen to XL / XLT
  • Radio / Navigation Head Unit Control
    • Navigation in Motion
    • View Text Messages in Motion
    • Turn by Turn Navigation
    • Remove XM / Sirius Radio from Source
    • Remove CD Option from Sync
    • Bluetooth Pairing Name
    • Extend Radio On Time after Engine Off
  • Tire / Wheel / Traction Control
    • Hill Descent
    • Traction Control
    • TPMS
    • Axle Ratio
    • Tire Size / Speedometer recalibration
  • Glass Control
    • Global Window Close / Open
    • Auto Fold / Unfold Outside Rearview Mirrors with Lock / Unlock on key fob
    • Auto Fold / Unfold Outside Rearview Mirrors Lincoln Style
  • Engine Control
    • Remote Start Enable / Disable
    • Secure Engine Idle ( Police Mode )
    • Auto Engine Shutdown Disable
    • Enable Auto Regen Checkbox
  • Electrical Control
    • Battery Monitoring System (BMS) Disable
    • Power Point Time Out Disable
    • Power Point Time Out 4 Hours
  • Comfort Control
    • Timeouts for Heated Steering Wheel
    • Switch Steering Wheel Button Functions
    • Massage Seats
How do I find my vehicle's As Built data?
DOWNLOAD your vehicle's original As Built data from Ford. Here's how:
  • Go to https://www.motorcraftservice.com/AsBuilt
  • (You may or may not need to enter your country first) See sequence of Motorcraft Service screenshots
  • Enter your full 17 character VIN (Vehicle Identification Number)
  • Press Submit. Do so only once, as doing so again will cancel the first request, increasing wait times.
  • [During peak usage hours, wait times can take up to 5 minutes.
  • Download your AsBuilt (.ab) file and store in a safe place.
What Platforms / Operating Systems does FORScan support?
Compare FORScan apps and OS/device dependent functionality at https://forscan.org/comparsion.html
  • Windows - 10/8.1/8/7/Vista/XP/2000 (ELM327 / ELS27 / STNxxxx adapters with COM, USB, Bluetooth & WiFi interfaces)
  • NOTE: Only x86 hardware architecture supported. ARM architecture is not supported.
  • Windows is the only platform that supports ALL features and functions of FORScan
  • (Including module configuration and programming, and SAE J2534 Pass Thru Interface communication adapters)
  • Apple Mac OS - Use a Windows Emulator/Shell - (such as Boot Camp, then use FORScan for Windows)
  • Apple iOS - v7.0 & higher (using OBDLink MX+, ELM327 Bluetooth and WiFi adapters)
  • Android - v4.0 & higher (using ELM327 Bluetooth and WiFi adapters)
How do I OBTAIN FORScan?
The FORScan application can be downloaded from https://forscan.org/download.html
  • Windows - Standard License (Free, includes all diagnostic functionality, but NO module programming abilities)
  • Windows - Extended License (REQUIRED for module configuration and programming, and servicing PATS)
  • Windows - Wine Build (See FORScan Forums and FORScan Home Page with site index for details.)
  • Apple MacOS - Use Windows Emulator/Shell - (Then download Windows licensing version of choice)
  • Apple iOS - FORScan Viewer for iOS (Free, use first to check for app compatibility with iOS device)
  • Apple iOS - FORScan LITE for iOS(Limited functionality, see Comparison Chart for details)
  • Android - FORScan Demo for Android (Free, use first to check for compatibility with Android device)
  • Android - FORScan LITE for Android (Limited functionality, see Comparison Chart for details)
Is an Extended License REQUIRED in order to use FORScan?
Detailed licensing levels and requirements can be reviewed at https://forscan.org/faq.html#licensing
  • No license needed with Windows FORScan for diagnostics (retrieving & clearing DTCs, monitoring PIDS)
  • License always required for ANY function with FORScan LITE for mobile Android / iOS platforms
  • If you wish to donate to FORScan development, then obtain an Extended License for Windows
  • Available Extended License Periods include 2 month (free), 1 year, 3 year, 5 year, and Lifetime
  • If you want to perform the following functions with Windows FORScan, then an Extended License is required:
    • Module Configuration
    • Module Configuration (AS BUILT Data)
    • Central Configuration[
    • Module Reset/Configuration
    • PATS Programming[
What is DIFFERENCE between Free versus Paid Extended Licenses?
Paid Extended Licenses last longer, and are much easier to set up with Activation Code
  • FORScan instructions use words "Activation Code" and "License Key" interchangeably
  • However, a difference exists between what Activation Code vs License Key really mean
  • This difference is an important factor that distinguishes a paid license from a free license
  • All Extended Licenses require a key for each hardware device FORScan is enabled on
  • Free License Keys must be manually prepared, generated, downloaded, and installed
  • Activation Codes automate and simplify the manual process of setting up license key
  • Activation Codes are only issued for Paid licenses, and are valid for license duration
  • Free licenses require manual generation and installation of License Key (No Activation Code)
  • Free licenses must be renewed every 2 months, and require FORScan Forum membership
  • There are no other functional differences between free versus paid Extended Licenses.
How do I ACQUIRE an Extended License for FORScan?
LITE users see App / Play store. Windows users read Standard and Extended Licenses for Windows
  • To acquire a Free 2 Months Trial Extended License for Windows:
    • One must first Register to become member of FORSCan.org forum to log in to Extend License
    • After registering, open FORScan and select the Steering Wheel Icon in bottom left corner of screen
    • The FORScan About page will show the Standard License Hardware ID. Click Copy To Clipboard.
    • IMPORTANT NOTE: Look up Hardware ID on the computer used to directly connect with vehicle. If FORScan is loaded on both a desktop (to review logs) as well as a laptop (to connect to vehicle), then it is essential to use the Hardware ID from the laptop to register for any type of Extended License, because the laptop is the computer used to connect to vehicle. However, the laptop does not have to be actually connected to the vehicle in order to get the Hardware ID.
    • Generate Trial Extended License using this link on FORScan's website: Generate Trial License
    • (FORScan requests First & Last Name, Contact Phone Number, and Hardware ID as derived above)
    • After license key is successfully generated, click on the Download link in the Action row of the table presented and download the license key to any file on computer that you can locate later for install.
    • It is not necessary to immediately "install" the license directly from the link where license key was obtained.
  • To acquire a Paid 1yr, 3yr, 5yr or Lifelong Extended License for Windows:
    • Visit FORScan.org Downloads. Buy Extended License (Click length of term desired)
    • Transaction executes through "ShareIt/MyCommerce" (linked via terms clicked above)
    • Once payment is processed, an Order Confirmation page presents an Activation Code
    • Confirmation Email also contains Activation Code, along with Installation Instructions
    • The email may contain an attachment to download. Note where you download this file!
How do I INSTALL / ACTIVATE the Extended License Key?
See FORScan.org FAQ and Standard and Extended Licenses for Windows
  • General Notes on installing Extended License Key / Activation Code
    • An internet connection is required on device to be licensed at the moment of activation
    • Once activated, FORScan no longer requires any internet connection on device to use the software
    • The Activation Code / License Key file should be kept safe, in the event FORScan needs re-activating again
    • One License Key per single PC. Another way in which "License Key" and "Activation Code" terms are distinguished:
    • Multiple License Keys can be ordered at once for each PC, to be conveniently linked by using the same Activation Code.
    • Choose any one of the Four Methods described below to Install License. Only one method need be used, not all Four, but if one method doesn't work, try another.
  • Method 1 to Install Paid License: (This method works for Paid licenses)
    • Double click directly on the file downloaded from the MyCommerce email (paid license), as described in section above.
    • Confirm / authorize the file to make changes to the Windows registry
    • After the foregoing is complete, Restart FORScan application
    • Must be online, and firewall must not have FORScan outgoing connections blocked
    • After restart, the Extended License is installed and application is ready to use
  • Method 2 to Install Paid License: (Copy & Paste Activation Code provided for Paid license)
    • Start FORScan & click Steering Wheel "?" Icon (About Section) at bottom left of screen
    • Click "Load License Key" (in some versions called "Enter Activation Code") button
    • Dialog box will open, where Activation Code from email can be copied & pasted into
    • Wait for Activation result (can be very short), then agree to restart application
  • Method 3 to Install Free License: (Navigate to Download from within FORScan application dialog directory)
    • Start FORScan & click Steering Wheel "?" Icon (About section) at bottom left of screen
    • Dialog box will open, displaying FORScan directory which may not be where License is
    • Using mouse, navigate to the directory where file downloaded from either the FORScan forum link (free), or the MyCommerce email (paid) was stored, as made note of earlier.
    • Once FORScan Key file is located, select it and press OK in dialog box.
    • Affirm prompt requesting to restart FORScan by clicking OK.
  • Method 4 to Install Free License: (Especially helpful for Windows 10 users, as suggested by F-Wolf)
    • When downloading Extended License, make a new folder and name it FORScan License
    • If Windows asks what type of file the Download is, select the .key file extension
    • Find the FORScan Program folder. (example C:/ Program Files (x86) / FORScan)
    • Copy & paste the "FORScan License" folder created in the first step above (which has the .key file download) into the FORScan Program folder found in the Program Files on the C drive
    • Start FORScan and click Steering Wheel "?" Icon (About Section) at bottom left of screen
    • Click "Load License Key" button (in earlier versions called "Enter Activation Code")
    • Dialog box opens, displaying FORScan directory where the "FORScan License" file
    • In example directory below, FORScan Forum member F-Wolf named his file "Licence"
    • Once FORScan License Key file is located, select it and press OK in dialog box.
  • Image Credits: F-Wolf of FORScan.org for images illustrating Method 4. KELLSDAD22 at FORScan.org for images illustrating Method 3. YOUR PROGRAM FILE LISTS WILL LIKELY DIFFER FROM THOSE ILLUSTRATED.
All About ADAPTERS. Which one to choose?
See FORScan.org subforum on Adapters and ELM327 Compatible Adapters - How To Choose
  • Known Good and Recommended Adapters Tested by FORScan developers and super users:
    • Windows for programming, complex module configuration, changing settings, all diagnostics
      • OBDLink EX USB (verified for all programming functions except pass through)
      • Viaken STN1170 USB (No longer recommended for new designs)
      • ELS27 v3 (Russian)
      • OBDLink SX (if modified for MS-CAN Support)
      • OBDLink LX (if MS-CAN Support not required)
      • OBDLink MX+ (no programming, no complex configuration, no calibration updates)
    • Android w/ FORScan LITE Diagnostics only, read/clear DTC, monitor PID, some service
      • OBDLink MX+
      • OBDLink MX BT (Discontinued by OBDLink)
    • Apple iOS w/ FORScan LITE Diagnostics only, read/clear DTC, monitor PID, some service
      • OBDLink MX+
  • OBDLink ELM327 Compatible OBD to UART Interpreter Integrated Circuit Device IDs:
    • STN1110 - STN1110 - Not recommended for newer designs, active but outdated
    • STN1130 - OBDLink SX USB - Low Cost - Can be hacked with manual switch
    • STN1151 - OBDLink MX BT v2 - Even Version 2 is discontinued. Use MX+ or LX
    • STN1152 - OBDLink MX WiFi - Native iOS Support, but discontinued. Now use MX+
    • STN1155 - OBDLink LX BT - Supercedes MX BT, but does not support Apple iOS
    • STN1170 - STN1170 - Not recommended for newer designs. Consider STN2120
    • STN2100 - STN2100 - Not recommended for Fords newer than 2003. See STN2120
    • STN2120 - STN2120 - Supports Ford MS CAN and GM SW CAN
    • STN2230 - OBDLink EX USB - Low Cost - Auto switching - Supports Ford MS CAN
    • STN2255 - OBDLink MX+ BT - Supports iOS, Ford MS CAN, SW CAN, Auto switch
  • Cheap Chinese Clone ELM327 Compatible Adapters: Use at own risk; then report what happened... or didn't.
  • Common Connection Interface Options for adapter to computer / hand held device connection:
    • USB - Most stable & reliable connection, & the fastest. Required for programming
    • BlueTooth (BT) - Most common connection, used on Android devices running FORScan LITE
    • WiFi - Not recommended by FORScan. Used on Apple iOS 8+ devices running FORScan LITE
  • OBDII and Vehicle Module Network Communication Bus Protocols:
    • MS-CAN Medium Speed CAN (Proprietary Ford body, chassis, & interior modules)
    • HS-CAN High Speed CAN (Emissions regulated Ford engine & drivetrain modules)
    • ISO 9141-2 (older Ford secondary network, up to 2009. Primary on Mazda to 2003)
    • ISO 11898 CAN (Raw CAN standard set, encompassing physical layers)
    • ISO 14230-4 (also known as KeyWord Protocol 2000, aka KWP, aka KWP2K)
    • ISO 15765-4 CAN (Worldwide harmonized and regulated transportation CAN standard)
    • SAE J1850 PWM (older Ford Standard Corporate Protocol, up to 2003 and up to 2009)
    • SAE J1850 VPW (older GM Class 2 vehicles)
    • SAE J1939 CAN (Medium and Heavy Duty Truck adaptation of ISO 15765 CAN)
    • SAE J2411 SW-CAN (Single Wire CAN, GMLAN, GMW3089)
    • SAE J2534 Pass-Thru (Calibration ReFlash through OEM supplied server connection)
    • SAE J2818 (also known as KeyWord Protocol 1281, aka KWP1281)
    • UBP - (Universal Bus Protocol, an older UART based protocol used prior to Ford SCP)
Having now selected a device platform, downloaded FORScan, acquired a license, activated the license, and chosen an adapter...
It's now time to get your FORScan party started!
Old Nov 3, 2016 | 09:21 PM
EpicCowlick's Avatar
EpicCowlick
MODERATOR'S NOTE:
AS OF DECEMBER 2019, OWNERS OF 2020 MODEL YEAR SUPER DUTY VEHICLES BEGAN REPORTING SIGNIFICANT DIFFERENCES IN FORSCAN BEHAVIOR AND/OR PARAMETERS WHEN COMPARED TO 2017-2019.
IF YOU HAVE A 2020 MODEL YEAR SUPERDUTY, IT IS STRONGLY SUGGESTED THAT YOU USE CAUTION AND RESEARCH BEFORE APPLYING ANY OF THE INFORMATION FOUND ON ANY PAGE OF THIS THREAD.
DISCUSSION OF 2020 MODEL YEAR SUPER DUTY DIFFERENCES FROM 2017-2019 BEGAN ON DECEMBER 14, 2019 , WITH WHAT HAS NOW EVOLVED INTO A SEPARATE STICKY THREAD FOR 2020-2021 SUPER DUTY MODELS, LINKED HERE AND ALSO FOUND ON THE STICKY LIST AT THE TOP OF THE 2017+ SUPER DUTY FORUM.
Below is a link to a spreadsheet to record features that can be modified in the Super Duty via the FORScan software. Each row provides information on what can be changed and how to change it. The spreadsheet is read-only and will be updated with new features as they are discovered. This thread can be used to discuss and test new mods.
DISCLAIMER: This information is provided for enthusiasts who are willing to experiment and test on their personal vehicles. There is no guarantee that any of these items will work in any particular truck and may have negative or unintended consequences. If you choose to make any modifications to your truck you do so at your own risk.
https://docs.google.com/spreadsheets...it?usp=sharing
Three steps for downloading, installing and activating the FORScan software:
1. Register on the Forum: FORScan forum ? User Control Panel ? Register
2. Download and install FORScan for Windows. Must be run on a Microsoft Windows PC or tablet that has Bluetooth connectivity. This can be run on an Apple computer if run in Bootcamp mode. Copy the Hardware ID (found in FORScan software under the steering wheel with a question mark icon). Download FORScan
3. Generate the Extended License (free) using the previously copied Hardware ID. FORScan forum ? Login
At this point you are registered on the forum and your copy of the FORScan software is activated.
Connecting FORScan to the truck:
The FORScan software connects to the truck's computer modules via a Bluetooth OBDII connector. There are many connectors available and some work properly and others don't. The following is proven to work in all cases. Search "OBDLink MX Bluetooth" on Amazon. OBDLink MX Bluetooth
The final step is to plug in the adapter into the truck's OBDII port and select the OBDII adapter in the FORScan software under Settings (the gear icon) and the Connection tab. Once selected, press the Vehicle Interface and Information icon (the auto with the exclamation point) button and FORScan will begin scanning all available modules. Wait until complete and you're ready to go.
Last edited by Y2KW57; Jul 10, 2020 at 05:18 PM. Reason: Changed title to 2017-2019. Separating out 2020+ Model Years to new sticky.
Old Nov 5, 2016 | 01:18 AM
PSM 6.4's Avatar
PSM 6.4
Originally Posted by EpicCowlick
I've created a spreadsheet to record features that can be modified in the Super Duty via the FORScan software. Each row provides information on what can be changed and how to change it. The spreadsheet is read-only and will be updated with new features as they are discovered. This thread can be used to discuss and test new mods.
Glad to see, you created a spreadsheet. Hopefully in the future we can add more to the list, looking forward to what we all can find.
Old Nov 5, 2016 | 06:15 AM
System's Avatar
System
Prolocutor
Great idea Epic. Reps intended. I'm curious though. On my 2012, you don't modify the "as built" BdyCM. You modify the the BdyCM. I see you have modifications to "as built BdyCM" in your sheet. Is this how folks are doing it on the 17's?
Old Nov 5, 2016 | 06:24 AM
Kampn's Avatar
Kampn
GREAT idea Epic, this is going to be gold!
Old Nov 5, 2016 | 08:04 AM
EpicCowlick
I tried both modules. I changed the BdyCM first and it didn't have any affect. So I reset it and changed the "as built" and it worked. Like you, I expected that the BdyCM would be the actual deployment module and the "as built" would be the backup but it appears to be the opposite. As we learn more I can always go back and update the important points in the first post. Right now nothing much has changed so it's easy to put everything back to stock at any point. We'll establish best practices and standards as we go.
Old Nov 5, 2016 | 10:31 AM
screwy's Avatar
screwy
This is a spreadsheet I found over at the F150 forums: http://redirect.viglink.com/?format=...Fusp%3Dsharing
Old Nov 5, 2016 | 11:06 AM
wb6anp's Avatar
wb6anp
same codes for the horn honk, if we could get the IPC codes off an xl-xlt that has commanded regen, maybe we could activate that, try to compare the differences.
Old Nov 6, 2016 | 01:22 PM
EpicCowlick
That is awesome. It looks like they've already done most of the work for us. I think all we need to do is test and confirm what works on the Super Duty and then indicate that. I'm heading to Mexico City for 11 days (ugh) and will be away from the truck.
Originally Posted by wb6anp
same codes for the horn honk, if we could get the IPC codes off an xl-xlt that has commanded regen, maybe we could activate that, try to campare the diferences.
Agreed.
Old Nov 8, 2016 | 11:55 AM
porthole's Avatar
porthole
Hopefully fake engine noise disabling will not be required .
Old Nov 8, 2016 | 12:19 PM
System's Avatar
System
Prolocutor
I just figured out that an operator command regen is possible from the DPF % screen on my 2012. Hopefully you guys will figure out a way to turn on a DPF % screen on the 17s and maybe the OCR will be enabled with it again?
Old Nov 8, 2016 | 12:42 PM
tuclai's Avatar
tuclai
Is it just me that thinks its cool to be able to have fog lights on without the main lights? Is there an option to change this?
Old Nov 8, 2016 | 12:43 PM
System's Avatar
System
Prolocutor
I'm hoping so. I run this way a lot in my current truck.
Old Nov 8, 2016 | 12:47 PM
tuclai's Avatar
tuclai
[QUOTE=Karl4Cat;16707455]I'm hoping so. I run this way a lot in my current truck.[/QUOTE
Did you mod something? I thought by default the fogs only turn on when you turn on the headlights?
Old Nov 8, 2016 | 12:48 PM
System's Avatar
System
Prolocutor
I run them with the parking lights only is what I meant. Sorry, I didn't mean the fog lights completely stand alone. I never really thought about that actually...
