2020-2022 Super Duty FORScan Spreadsheet
#1682
Sorry if this has been asked and answered but the thread is 113 pages and I couldn't find the answer. Do the forscan codes from the older trucks (2017 - 2019) work on the 2022's? For example, I desperately want to disable the horn honk when locking with the key fob. In the 2017 spreadsheet here is the line: <!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->
Disable Door Lock Horn Honk BCM 726-38-02 xxx1 xxxx xxxx xxx0 xxxx xxxx 1 (Enabled - Default), 0 (Disabled).
Does anyone know if this will work on the 2022 (my guess is no). Is there a way to do this on the 2022? I don't see this in the spreadsheet for the 2020-2022 models!
Thanks!
Thanks!
#1683
Thanks!
Thanks!
ZooDad
#1684
Thanks but I see that as ‘double honk w/o key in truck’…I’ve done that already and that is another one I love which is disabling that double honk if I get out of the truck with the key in my pocket. I’m looking to disable the honk one the second press of the key fob lock button which I don’t think is the same thing???
#1685
ZooDad
#1686
#1687
I'm getting the prompt below when I plug the Forscan into my New 2022. Any advice on this issue?
Warning
If PCM has a custom tune installed, please enter strategy/calibration name or part number FACTORY PCM (ex. xxxx-xxxxxx-xxx) It is asking me to enter a code?
Any advice?
Warning
Any advice?
#1690
Audio Control Module - Line Out
I was researching how to wire aftermarket speakers into a F250. I was certain that the factory radio (aka Audio Control Module) does not have line level outputs, to use with an aftermarket amplifier. Then I came across the following post, where for Ford Fusions, FORScan can be used to change the factory radio from speaker level outputs to line level outputs. Would that be possible on new F-250's also?
Variable Line Level Preamp Outputs From ACM (Factory Radio) For Amplifier Upgrades
This mod can be done with FORScan w/ODBLink MX Adapter:
727-01-01 xx59 F8x8 xxxx - Enables Line Level with Optional Subwoofer (Aux 1) and Front Center (Aux 2) Outputs Enabled*
#1691
ZooDad
#1693
