2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
2020-2022 Super Duty FORScan Spreadsheet
Old 04-28-2020, 05:35 PM
4Seams's Avatar
4Seams
4Seams is offline
Originally Posted by Sharkhunt
I did, and I had the same p0160 issue :/ I have 3.55s and I tried 3.31.
That said, the guys that did my Carli say they have had good luck with the hypertech unit in-line in the IPC harness. The truck goes in Monday to put that in.
Well, shoot. Thanks for replying with your results. I guess I'll be looking into the Hypertech or Rough Country inline as well when I pull the trigger on 37s. Let us know how it goes/what you think, etc!
  #182
Old 04-28-2020, 06:38 PM
Sluke's Avatar
Sluke
Sluke is offline
Is there a code option yet for the open door chime? The chiming with no key in the ignition makes no sense to me. I’ve done other changes w/ the program, but this one bothers me the most. thanks!
Stephen
  #183
Old 04-28-2020, 08:30 PM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
Originally Posted by longhaultransport
Idle control with cruise control possible?
The high idle controller is available through Ford in the "Ambulance Package".
Any chance this is something that Forscan can enable?
No, thats controled though the pcm/ecm
https://www.ford-trucks.com/forums/1...-idle-mod.html
https://www.thoroughbreddiesel.com/1...SABEgJIQPD_BwE
  #184
Old 04-28-2020, 10:00 PM
Sharkhunt's Avatar
Sharkhunt
Sharkhunt is offline
Stephen
I got it to work on mine. I’m sorry but I don’t remember which I used. I believe I used the door chime disable from the 17-19 sheet. Don’t forget to backup your current BCM config. I keep the original saved and I keep a second one called current when I make individual changes.
  #185
Old 04-29-2020, 05:55 AM
Sluke's Avatar
Sluke
Sluke is offline
Shark hunt, do you have a key or a fob? I believe guys w/ the fob don’t have this issue.
  #186
Old 04-29-2020, 10:20 AM
fieldspondlm's Avatar
fieldspondlm
fieldspondlm is offline
I am looking for info on the door lock key pad install on an 2020 F550 XL. I went by a post from another member to make this needed addition..... The changes that were posted in another thread listed the 2017+ instructions. But the values to change were not working (one was already set at the new value and the other I changed). I am guessing the 2020 has changes to it from the 17 to 19 models. I need to activate the door keypad unit I installed on this brand new XL truck. The last thread said it worked on 17+, so I installed it, but it does not. If you have any updates to the spreadsheet that will help, please let me know.
Thanks Tim
  #187
Old 04-29-2020, 10:35 AM
ZooDad's Avatar
ZooDad
ZooDad is online now
Thanks Tim
Tim
Let me take a look and see what I can find
Keith
  #188
Old 04-29-2020, 12:49 PM
ZooDad's Avatar
ZooDad
Thanks Tim
Tim,
You did not list what data set you tried, but try this:
KeyPad 726-31-01 xxxx xxx* xxxx 0=Disable 1=Enable
Let us know.
Keith
  #189
Old 04-29-2020, 01:37 PM
longhaultransport's Avatar
longhaultransport
longhaultransport is online now
Thanks Tim
I just did that on my 2020 F350.
It was in the plain english section.
Is the 550 Forscan different than the 350?
  #190
Old 04-29-2020, 10:42 PM
pugslyyy's Avatar
pugslyyy
pugslyyy is offline
Originally Posted by ZooDad
I want to thank LivnItUp, EpicCowLick and all the other members who have tested and contributed to the ForScan sheet efforts
Since there are some differences (and similarities) in the 2020MY I am starting a new ForScan sheet.
As of now the info is "somewhat limited", but I'm sure there is additional info out there.
If you are new to ForScan please take the time to read and watch LivnItUp tutorial. LivItUp ForScan Info It will answer over 90% of the basic questions.
If you have info you would like to share, please do so.
I am hopeful that we will be able to continue drilling into each module.
Enjoy
2020 Super Duty ForScan Sheet
ZooDad
Just want to say thanks for doing the work to organize this. I'm looking forward to seeing the spreadsheet grow.
My big wish right now - enabling the extra Tremor offroad mode on my 2020 F350!
  #191
Old 05-01-2020, 12:03 AM
fieldspondlm
I will update you with the answer..... I have a few 2019 F550's on the lot that I can experiment with... but only one 2020 right now.
thanks again for your help.
  #192
Old 05-05-2020, 07:45 PM
4Seams's Avatar
4Seams
4Seams is offline
I haven't seen this one yet so I'll ask...Anybody get the enable auto regen check box to show up and be usable on the 2020s? While in Forscan and connected to the truck today I looked for something that looked like it in the IPC plain english side (per the 2017+ Forscan sheet) and didn't see anything. The 2020 sheet doesn't have it listed, so maybe its not been found yet. Thanks!
  #193
Old 05-05-2020, 08:10 PM
longhaultransport
I did it in Forscan plain English, but I don't remember the section, and the check box appears in the display.
  #194
Old 05-05-2020, 09:29 PM
fieldspondlm
Keith- I got it to go, just as they said... it was available to change in the BCM plain english module. I changed the value, confirmed it and cycled the keys. I got the door code and the keypad is now activated. thanks for your help on this 2020 F550XL 4x4 crew cab chassis
  #195
Old 05-06-2020, 12:07 PM
ZooDad's Avatar
ZooDad
Awesome, glad to hear it worked out.
Keith
The following users liked this post:
Quick Reply: 2020-2022 Super Duty FORScan Spreadsheet
