2018 General Chat
Old Mar 12, 2018 | 12:04 AM
  #841
892504x4's Avatar
892504x4
Good Evening Evan, Jim and....
Evan the stock looks good.
Jim good luck with the washer.
Old Mar 12, 2018 | 07:05 AM
  #842
67nukeford's Avatar
67nukeford
Veteran: Navy
Good morning Oregon, hope everyone had a fine weekend! Now just have to deal with being half asleep from the time change.
Old Mar 12, 2018 | 07:24 AM
  #843
abusek's Avatar
abusek
Morning Pat and all to follow. 40 at the compound as I left.
Old Mar 12, 2018 | 08:39 AM
  #844
892504x4's Avatar
892504x4
Morning Pat, Andy and those to follow.
44.4° here.
I don't care for daylight savings time, I have to share the road with too many sleepy driver's.
Old Mar 12, 2018 | 09:11 AM
  #845
Brown Falcon's Avatar
Brown Falcon
Good morning everyone. 35° and foggy here.
Old Mar 12, 2018 | 09:30 AM
  #846
67nukeford's Avatar
67nukeford
Veteran: Navy
Morning Andy, Chris, Evan. They just need to keep it the way it is now, and call it good!
Old Mar 12, 2018 | 09:57 AM
  #847
Seabiscuit-P3's Avatar
Seabiscuit-P3
Veteran: Navy
Veteran: National Guard
Good morning Oregon and everyone everywhere else. 34 and clear. Sthickly goes to the Vet in a few minutes. The antibiotic seems to have worked quite well, now to get to the root of the problem.
Old Mar 12, 2018 | 10:30 AM
  #848
River Wild's Avatar
River Wild
Happy Monday! Nice weekend to get some things done outside. Contractor finished the new roof on Saturday while I put 15 gallons of kill everything down in preparation for some tree planting. Mowed the yard for the first time yesterday, smoked a small brisket, and most importantly, spent much of the day cleaning and prepping the boat! Need to hit the river for a systems check and hopefully will be ready to go fishin once the fish show up. New onboard charger is due today so will need to get that installed soon. Managed to find a new tach on Amazon for cheap which should arrive this week also. I'll find out if it's the tach is busted or if it's actually the ECM that has lost part of it's brain.
Boat - a hole in the water in which one throws money into.
Old Mar 12, 2018 | 10:45 AM
  #849
Seabiscuit-P3
Veteran: Navy
And, the bigger the boat the bigger that hole in the water is!
Should be able to use the multi meter to see if you are getting the tach signal through the harness. That's how I ultimately found that the tach I had, had a grounded short that was causing a no start condition. New tach to replace that 'new' tach solved the problem. The OEM tach had quit reading out RPM's but didn't keep the boat from starting. The new tach with the short actually would show RPM's while the engine was turning over, but kept it from firing and caused extreme low voltage in the signal wire at the coil.
Old Mar 12, 2018 | 02:40 PM
  #850
River Wild's Avatar
River Wild
I'll have to find a place I can run the tub and do some testing. When I was at the boat show I asked someone who used to be the regional Marine Power Rep for umpteen years about it, he smiled and immediately said it was the ECM. He said the MP(GM) 6.0's were notorious for losing the part of the brain that runs the tach. When I asked for the fix he said new ECM...to the tune of about $1600. I figure the $46 I spent on a tach is a cheap start. The ECM....not so much.... sigh... crossing my fingers.
Old Mar 12, 2018 | 04:47 PM
  #851
Seabiscuit-P3
Veteran: Navy
Wow! $1600 for an ECM! If you get unlucky you might check with Jim out in Grand Ronde with Jim's Boat Parts. I have his phone number if you need it.
I guess I'm lucky to still have a coil for it to run off of. $52.00 at Amazon - no shipping cost with Prime.
Old Mar 12, 2018 | 10:09 PM
  #852
892504x4's Avatar
892504x4
Good evening Ford Fans.
Monday another Monday is done!!
Old Mar 13, 2018 | 01:28 AM
  #853
Seabiscuit-P3
Veteran: Navy
On late night kitty cat post surgery duty. Feel like I'm back out on the farm again.
Old Mar 13, 2018 | 06:26 AM
  #854
67nukeford's Avatar
67nukeford
Veteran: Navy
Good morning Oregon, welcome to Tuesday. My body is still questioning why I'm getting up an hour early....
Old Mar 13, 2018 | 07:12 AM
  #855
abusek's Avatar
abusek
Morning Pat, and all to follow. 50 out at the compound when I left.
