2018 General Chat
Old Feb 26, 2018 | 09:02 AM
  #706
Brown Falcon's Avatar
Brown Falcon
Good morning everyone.
Old Feb 26, 2018 | 09:57 AM
  #707
Seabiscuit-P3's Avatar
Seabiscuit-P3
Veteran: Navy
Veteran: National Guard
Good frosty, foggy, soggy morning Oregon and everyone everywhere else. 28.1 and low visibility at the moment.
Guess we need to start looking at what it is going to take to re-plumb the bathtub. Minimal water flow, while everything else has good flow. Seems to be just the feed to the bathtub only. Put new valves in last night, but it didn't help. Old ones were in pretty bad shape, but obviously no the problem.
This could get interesting.
Old Feb 26, 2018 | 11:56 AM
  #708
56panelford's Avatar
56panelford
Wife has been complaining about very little pressure on the hot water side of the laundry tub. I discovered a ball of lead was lodged in the tube leading to the faucet..lots of pressure now..
Old Feb 26, 2018 | 01:07 PM
  #709
Seabiscuit-P3
Veteran: Navy
I'm thinking there is a problem with the diverter in the cross over valve set up. Started out when you shut the shower off, the shower would shut down, but water didn't return in any volume to the tub spout for a second or two. Then you would hear a clunk and the water would start to flow normal. This applies to both hot and cold water. Hot and cold water everyplace else in the house is just fine.
Now, instead of doing that, we only have about 5% normal flow out of the tub spout and we can't even get enough pressure to divert to the shower. Yesterday, it took 30+ minutes to run enough water for a bath.
Got the wall 'removed' so I can get to the plumbing and got the spout removed. Can't fit my fat head in where I need to go to see up inside the cross over valve, but I was able to take a picture. Looks like a plastic piece is out of place and jammed up.
Just got back from Lowe's and picked up a new valve body. Seems to be a major difference in the way that plastic diverter valve in there looks. So, I'll try to get that put on and see what difference it makes. The retired plumber running the plumbing section at Lowe's is betting that is the problem.
Old Feb 26, 2018 | 04:10 PM
  #710
Brown Falcon
Pat, you don’t happen to have a bad FICM from a 6.0 laying around, do you?
Old Feb 26, 2018 | 08:43 PM
  #711
Seabiscuit-P3
Veteran: Navy
Good evening Oregon and everyone everywhere else. Got the new main valve body in, everything reconnected, turned the water on, then turned the water off, tightened a couple of connection a little more than what they were, turned the water back on and we are in business. So much pressure to the massage shower head that it is like a water hammer.
The only thing that really worried me was after I got it in and turned on, the cold water would not shut off. I just a little perturbed thinking I was going to have that valve body out and take it back. Dissected the Cold water valve and discovered it had been inserted in the valve body incorrectly at the factory. Rotated it 180°, put it back together and it works like a charm.
Old Feb 26, 2018 | 08:54 PM
  #712
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
"If I can't fix it....It ain't broke"
Old Feb 26, 2018 | 09:05 PM
  #713
Seabiscuit-P3
Veteran: Navy
But with me, it usually is not broken until after I have fixed it....
Old Feb 26, 2018 | 09:41 PM
  #714
892504x4's Avatar
892504x4
Evening Ford Fans.
Old Feb 26, 2018 | 11:10 PM
  #715
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
.....Naww... I don't believe that......
Old Feb 27, 2018 | 07:28 AM
  #716
abusek's Avatar
abusek
Morning all 29 and frosty.
Old Feb 27, 2018 | 08:14 AM
  #717
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Good morning to the Oregon Patriots........
Enjoy a fine mug of cowboy coffee on this fine Saturday #2......
Old Feb 27, 2018 | 08:35 AM
  #718
892504x4's Avatar
892504x4
Morning Andy, Roy and...
41.1° and rain.
Old Feb 27, 2018 | 08:59 AM
  #719
Brown Falcon
Good morning y’all.
Old Feb 27, 2018 | 09:15 AM
  #720
56panelford
Good morning ...
