Budget LED headlights
Old Feb 23, 2018 | 12:53 PM
  #181
Sterling_47ag's Avatar
Sterling_47ag
Received my beamtech headlights & fogs today! Took less then an hour to swap. Driver side washer nozzle removed and air snorkel out on passenger side. Passenger side pretty easy and plenty of room. Driver side a bit tight and more tricky. Not sure why but I had a harder time getting the top drivers side to twist out. All works and all I can say is wow! Having HIDs on my 14 f150 and LED's in my 16 F150 I knew the yellow halogens wouldn't work. Truck is a week old tomorrow!! Ha!
Old Feb 23, 2018 | 01:29 PM
  #182
st1nn3tt's Avatar
st1nn3tt
So I know with the fogs I would only need 1 set. Assuming these are the correct ones for the headlights
Amazon Amazon
Do you need 1 or 2 "sets"?
Old Feb 23, 2018 | 01:36 PM
  #183
Sterling_47ag
https://www.amazon.com/BEAMTECH-Head...led+headlights
I did the H13 for headlights and yes two sets. As far as fogs I did 9005 and they actually said fog lights in the description. Pic below is the fog light.
Old Feb 23, 2018 | 01:40 PM
  #184
st1nn3tt's Avatar
st1nn3tt
I was looking at the "H11" for headlight and they also have an "H11' for the fogs. I assumed these would match. Any reason you went with the H13 and 9005? (I only see 9006 for fogs on Amazon.
Thanks!
Old Feb 23, 2018 | 01:47 PM
  #185
Sterling_47ag
Thanks!
On page 3 or 4 these are the part numbers I found.
Old Feb 23, 2018 | 02:36 PM
  #186
h20camper's Avatar
h20camper
I thought the fogs were 9140s (H10). No?
Old Feb 23, 2018 | 03:08 PM
  #187
Sterling_47ag
What I took out was 9140's. I might have jumped the gun and was anxious to switch mine out. Someone in pages previous stated 9005. That said the 9005 work on mine. Not sure of the difference between.
Old Feb 24, 2018 | 08:37 AM
  #188
Poncho450's Avatar
Poncho450
Yes, but you can put in other numbers. I did 9145's (H10) for fogs. As explained by someone on another post, 9140=40 watts. 9145=45 watts. Bulbs have the same base and are a fit. I probably would have tried a 9155 if I'd known at the time.
A cross reference in the Amazon listing for my bulbs shows them as replacements for 9040, 9045, 9140, 9145, 9050, 9055, 9155, H10 & PY20D.
Old Feb 25, 2018 | 04:31 PM
  #189
1atalbot's Avatar
1atalbot
Has anyone found a fog light as powerful or equal to the SuperNova V3's by HR? The Beamtechs seems almost to good to be true, however I can't find a matching Fog Light?
Old Feb 25, 2018 | 04:59 PM
  #190
felix4's Avatar
felix4
Has anyone done an LED conversion on the rest of the lights? I'm trying to find bulbs that fit and work in our trucks, preferably from the same company, to replace the regular bulbs in a Lariat. Some are regular, others are LED. I want them all LED and not have hyper flash or radio problems. Some LEDs are cheap and flicker, come DOA, are too bright or not bright enough. I've only used OPT7 and a cheapo brand from Kmart previously, both worked well however.
Old Feb 25, 2018 | 07:52 PM
  #191
BillyE's Avatar
BillyE
Thank you Poncho et al.
I installed the Beamtech headlights and went ahead with full LEDs all around. About $200 spent but well worth it in my opinion. Used FORScan to fix the hyperflash. The difference is really remarkable. I was driving around tonight noticing that not only is the light much brighter, but the beam pattern is actually much better too. I had to adjust my headlights to point lower. When I first put them in, low was straight forward (should be slightly down) and high was in the trees. After adjusting them slightly, they are perfect. Some people commented that the highs didn’t seem much better. If this is the case, I suspect you need to adjust them. Also, learn from my mistake: I got the white led W5W bulb for the front side marker. That bluish LED shining through the yellow reflector doesn’t match the rest of the yellows on the truck. It looks almost greenish. I’ve got some yellow W5Ws on order now. I got the Auxbeam reverse lights and they are insanely bright. Love it. I’m not sure if I’ll keep the front turn signal switchbacks or if I’ll go to all amber. Overall a great investment in my opinion. Thanks everyone.
Old Feb 25, 2018 | 08:39 PM
  #192
felix4's Avatar
felix4
I've read that even though the regular bulbs may be just white/clear, with LEDs we should go with amber or red even with a colored housing. Don't think we need switchbacks??
Old Feb 25, 2018 | 09:22 PM
  #193
BillyE's Avatar
BillyE
The brake lights work fine with the white leds. I’m sure red leds would work also but the white leds through red lenses match the stock CHMSL. When I say switchbacks, I mean the white/yellow dual colored front turn signal replacement bulbs. Stock is all amber. I got the dual color and I’m not sure if I like it or not.
Old Feb 26, 2018 | 06:13 AM
  #194
Poncho450's Avatar
Poncho450
Every light on my truck is LED now. Mixed bag brand wise. As everyone knows, I started with Beamtech headlights. Then went as follows:
• Alla 9145 fog lights
• SuperBright red tail/brake light bulbs
• Some Amazon generic T10/194 for the license plate lights
• Alla switchback for front signal/parking lights. (White when in the running or parking lamp mode, they flash amber when using the turn signals)
• Headlight Revolution reverse lights
• SuperBright front side marker lights
• The truck had factory LED for cab marker and 3rd brake/cargo lights.
I killed the hyperflash with FORScan after replacing the signal lights. There are 2 individual spots for front & rear to edit.
I wasn't concerned about all being the same brand, as I didn't do it as an all in one project. I also discovered that sometimes the lower priced or off brands do the same job as more expensive alternatives.
As far as colors, SuperBright's website and their email support people recommend using the same color LED bulb as the lens it will work with.
Old Feb 26, 2018 | 07:01 AM
  #195
BillyE's Avatar
BillyE
There's actually three values that need to be changed in Forscan. "Outage" to "No Outage" for Front, Rear, and I think the third one is ABM? It tripped me up the first time because I just did front and rear and then hyperflash returned after driving for a couple of minutes.
