'07 axles under the '01 Excursion - Conversion Thread
Old May 10, 2019 | 06:21 PM
  #556
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I will leave it to Camo to comment on the planes of control on radius arms. Glad what I put together here is of service to you.
What power plant are you using in the M715?
Old May 10, 2019 | 06:35 PM
  #557
Grendel's Avatar
Grendel
Nah, no comment needed, already analyzed it. Stock Ford is better for my application. I don't even need the washers, as I am drilling every hole for the brackets. I also plan to use a Ford engine crossmeber to pick up the pan hard bar mounts.
This is where we step away from Fordville. Using a GM 8.1L to a 6 speed Allison to a divorced Ford 205.
And that's the end of my thread high jack .
Thanks again for all the info.
Old May 12, 2019 | 02:38 PM
  #558
Grendel's Avatar
Grendel
So dumb question:
18" rim minimum diameter to fit over these brakes?
Google fu is failing me here.
Or is that the later model brakes, that we're still waiting for Camo to figure out if we can adapt to these earlier gen SD Dana 60's?
Old May 12, 2019 | 03:25 PM
  #559
Skip1970's Avatar
Skip1970
Originally Posted by Grendel
So dumb question:
im interested in a rear caliper redesign with older calipers that dont stick in the bores and wear pads uneven.
Old May 12, 2019 | 08:17 PM
  #560
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Grendel, it is a 17" minimum rim to clear your '05-'10 calipers.
Old May 13, 2019 | 11:36 AM
  #561
Grendel's Avatar
Grendel
Pefect info, thanks.
18" for the next generation of calipers? Did anyone find out how to go bigger in the brake dept?
I am not sure I need to, my new 2013-2016 rear e-locker axle just showed up. I think I am going 18" just to be safe. It does look like I could use the rear calipers on the front 2005 vintage abutments. They appear to be the same. It would mean the fronts are much larger. I am hunting for front 2013 abutments and calipers.
Old May 13, 2019 | 12:04 PM
  #562
Grendel's Avatar
Grendel
So I just took an early front (2005 caliper) and stuck it on the rear 2016 vintage axle.
Old May 13, 2019 | 12:21 PM
  #563
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
Grendel
this guy is as close as we have over here to a proper salute, but you get my drift. lmao
cool project. :flipoff2
Old May 13, 2019 | 01:45 PM
  #564
Grendel's Avatar
Grendel
Originally Posted by pirate4x4_camo
Grendel
Does that mean I should use 2005 calipers on all four corners? Haven't heard about 2016 caliper issues. I bought this particular axle for the e-locker and 4.30 gears and it was low mileage.
Camo, you already replied on my facebook when I linked you and your pic for all the rebuild parts for the 2005 front axle
seems odd.
Old May 16, 2019 | 11:16 AM
  #565
Davidtlawson's Avatar
Davidtlawson
if you can live with 3” the procomp 22415 will eliminate the stock rear block. you will need a 2* shim to correct drive line angle.
Thank you for the lead on these springs. I have a few questions that you may or may not know the answers.
There is a spring on the stock Ex pack that only goes forward that seems like a traction bar. Does that need to go on the new spring pack?
Removing the block also removes the bump stop. Should I fab a bracket for that or is it of no concern?
The 2 degree shims are to tilt the nose of the gear up? So I would install the shim with thick part towards the rear?
Thank you!
David
Old May 17, 2019 | 01:13 AM
  #566
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
You get to lose the anti-wrap bar with those pro-comps, I believe.
The two degree shims are to replace the angle that was lost on the tapered block you are taking out. The stock block is tapered if you look closely. Yes, thick part to the rear.
I'm not sure on that bump stop... I'd think you wouldn't need it anymore.
Old May 18, 2019 | 04:19 PM
  #567
pirate4x4_camo
FTE Remembers
the odds are you will not be driving your Ex in a manner that will put the spring at full compression and require the bump stop but I will suggest you incorporate it into your suspension anyhow, an unexpected adventure into a road side ditch or the urge to jump a curb is know to happen and the bump stop serves an important function.
Ford installed the anti_wrap bar when during initial product testing it was discovered in 4 low axle wrap was an issue in low traction situations like snow, sand or loose gravel
my experiance has been that removing the block eliminated the leverage which caused this and the anti_wrap leaf is not required.
Shims, It depends which drive shaft you have. with my rear non CV style shaft I need a 2* shim with the fat part forward to roll the pinion down. with a front and rear level stance this put the Transfer case output shaft and the rear pinion shaft within a 1/2* of parallel.
with a CV style shaft you are not wanting parallel you want the pinion shaft pointing straight inline with the driveshaft and that may require a 2 or 3* shim rolling the pinion UP or the fat part in the back.
recently somebody posted pics of their CV setup and no shims and the alignment "looked" good but I would still measure it when you get to that point.
Old May 28, 2019 | 06:47 PM
  #568
Dan V's Avatar
Dan V
Get your track bar bracket and hardware together.
They look pretty for now...
I used a 1/8 drill bit for a pilot hole. When it started to break through on the first hole, it snapped off in the hole. Grrrrrrrr....
I moved on to the next hole. I'll have to come back and deal with the broken bit later. What a pain...
With exception of the hole with the broken bit in it, it is all done.
The other frame rail bolt I succeeded in getting in.
I don't have the hardware for the track bar bracket....just wondering how you nut the front bolt? Even with the OEM hardware, there isn't any access.
Old May 29, 2019 | 12:53 AM
  #569
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I don't recall having much trouble. I think I fished it in from the front after taking off the tow hook. A long magnet-on-a-stick works well in situations like this one.
Old Jun 26, 2019 | 11:40 AM
  #570
Dan V's Avatar
Dan V
My solution was using the wirefeed, stick the wire to the end of the bolt....leave 20" or of wire on it, use the wire to fish the bolt through the hole.
