'07 axles under the '01 Excursion - Conversion Thread
Old Feb 28, 2020 | 08:50 PM
  #601
Davidtlawson's Avatar
Davidtlawson
Got the buckets, axle and track bar installed.
Old Feb 28, 2020 | 08:52 PM
  #602
Davidtlawson
Anyone interested in a BD caster kit, Moog track bar ball joint & bushing?
Old Feb 29, 2020 | 07:24 AM
  #603
Grendel's Avatar
Grendel
Which radius arms are those?
Old Feb 29, 2020 | 07:49 AM
  #604
Davidtlawson
PMF radius arms and the build quality is amazing! I have the Baja Customs Tracinator which is top notch quality as well.
Old Feb 29, 2020 | 08:03 AM
  #605
Grendel's Avatar
Grendel
Thanks. I am doing a SD60 under a 2wd 78 Crew Cab soon. Building the plan now, will start acquiring parts soon.
Already have the front and rear axles. Thought about using factory stuff, but seems like aftermarket makes packaging easier.
Old Feb 29, 2020 | 08:14 AM
  #606
Davidtlawson
Not sure about easier for the arms but definitely on the brackets. The arms are pricey compared to the Ford ones that typically come with the axles off the donor. The brackets were reasonably priced compared to the cost of removing them from a donor. Most of my local yards won't allow you to harvest parts yourself and those that do don't really have anything worth getting.
Old Feb 29, 2020 | 08:46 AM
  #607
Grendel's Avatar
Grendel
I have them already. I plan to use late model rear suspension, too. My apologies, I meant acquiring the aftermarket parts. I have a complete front and rear suspension and 2 frame cuts.
Old Feb 29, 2020 | 12:19 PM
  #608
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
Bitchen
have you considered using a coilover shock instead of separates ?
Old Mar 6, 2020 | 05:35 PM
  #609
Davidtlawson
Originally Posted by pirate4x4_camo
Bitchen
I haven't but willing to listen to pros and cons!
Old Mar 6, 2020 | 05:51 PM
  #610
Davidtlawson
On her way to be aligned. I didnt have any of the original steering gear so basically I eyeballed it and trailered to the alignment shop. Should be completed Monday afternoon. After that I'll throw on the sway bars and dual steering stabilizer which will complete this project. Will give an update next week.
I bought (from my local Parker store) two 24"x1/4" OD teflon lined stainless braided lines with male 1/8" pipe thread ends and then added female 1/8" pipe to 3/16" barb ends on one end to use for the vacuum hub locks. Will post some pics of that setup when I get her back.
Old Mar 12, 2020 | 11:39 AM
  #611
RPhil's Avatar
RPhil
I have been patiently waiting and perusing Facebook marketplace and Craigslist for a 4.30 front axle. They are significantly more rare than the 3.73. I have entertained the idea of regearing, but you can get an entire used axle for the cost of new gears and a rebuild kit, so it is difficult for me to justify.
For now I will live vicariously through everyone else's swaps.
Old Mar 12, 2020 | 02:58 PM
  #612
Davidtlawson
Got her back today and went for an hour drive... Such an amazing improvement.
I do have a couple of issues... first is a small vibration from 25 to 55mph. I'll start checking nuts, bolts and changing one variable at a time until I have the culprit. Second is the vacuum hub locks don't engage. Have vacuum at both wheel ends. They turn manually from auto to lock easily. Hub locks are new. Is there a vacuum spec?
Old Mar 12, 2020 | 03:17 PM
  #613
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Start here for vacuum troubleshooting:
Old Mar 12, 2020 | 03:25 PM
  #614
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
More answers in here for specs on vacuum system:
https://www.ford-trucks.com/forums/1...-question.html
I don't think the vacuum pressures changed with newer, bigger hubs, but I could be wrong. The pulse Vacuum Hublock solenoid is the same up to 2010.
Old Mar 12, 2020 | 05:54 PM
  #615
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Another very good trouble shooting video with good system info in it:
