What would fuel in oil look like? Bought the truck, oil was a bit high after a shop changed it from previous owner. I changed it, thought I had it right, was a bit high. So I got under it and pulled the plug a little to drain it down into operating level. I'll see if it goes back up.
My oil level is going up but I have all my coolant. Also do not have smoke out tailpipe, reduced mileage or power. Is it possible that I'm still getting fuel in the oil without those symptoms?
I don't know that fuel in oil would 'look' like anything, unless you had dye in it it would be tough to tell without an analysis. Maybe the smell of diesel in the oil. Usually it's oil in the fuel because high pressure oil overrides fuel pressure. I don't know where fuel comes into contact with low pressure oil. Maybe it does somewhere around the injector.
I ordered the sample kit from Blackstone this morning. Is it unsafe to drive this truck pending results? Like I said there's no other symptoms that I can tell.
This past week I've noticed a knock noise of the passenger side of the engine. Everyone I ask seems to think it's just normal 7.3 noise. But it is noticably louder than the noise my bosses truck makes. Sometimes it dies down as the truck gets warm. It has been between 5 and 9 degrees lately. From looking on here and other videos is sounds like an injector knock. Unless I'm being paranoid again. So my question is, what could an injector knock hurt?
***Disclaimer - I am not a certified mechanic/technician in any way, shape, or form. I am merely someone who enjoys the feel of a combination wrench in my hands (and drinking beer)***
My official un-official response...it depends. There are different possible causes and depending on what is causing the issue will drive how bad (if at all) it could get.
I had the 'knock' for years. To my untrained ear some of the noise went away when I tightened the injectors but some remained. Loose injectors can cause problems (damage injector, cup, o-rings). When I ruled out other things I chalked it up to the injector itself. I wasn't interested in shimming it as I was sure with my high mileage that I was asking for trouble if I pulled the stick out of the hole. My injectors were still running well when I pulled them at 305K due to o-ring issues.
If you've checked that the injectors are seated correctly, the rocker pedestal bolts aren't loose, and that there's no fluids going where they shouldn't (oil in fuel - black fuel filter, something floating on top in the coolant overflow tank) then it shouldn't be much of an issue IMO.
As a preventive measure I would check under the valve cover for issues (bolt torques) to make sure everything's seated and tight. Here's a couple of good threads on that if you're considering the evolution:
Thank you for that response. I'll get it in the shop as soon as I can and pull the covers off to see what I've got. I added some cleaner in yesterday, not sure if it does anything but what the heck.
I have a question that someone on here would probably be able to answer. I was perusing the Riffraff site last night for kicks and was reading the descriptions on the different code injectors. I was curious as to what the differences are between the normal code injectors and the AC code ones were? I think that's the right code. They were in a high torque version of the 7.3. Someone left a review saying they "really woke the truck up." Has anyone put them in their truck? If so what are the differences in power, fuel economy and the like. Just curious. Thanks.
AC codes are 160/0 and as you probably already know they are a popular choice in injectors. Although, most in the know go with a 160/80 because the cost increase is not much, but the customization increase is a lot.
Another big difference is how they work. The AC injector was never available in Ford powerstrokes, but was in International engines. It is a single shot injector, where ours are split shot, for emissions. If you switch to the AC's, or any single shot injector, you will need tunes for proper operation.
Below is a thread that I started when I was extremely confused on injectors. Some good information about them if you have time to skim through it a bit.
