Injectors
Old Mar 3, 2018 | 08:25 AM
  #151
00t444e's Avatar
00t444e
Originally Posted by MTP55
On injector hold down bolts. Are there one or two per injector? It looks like there's an identical one on each injector closest to the center of the engine. But they are under the spigots.
There are two hold down bolts but you only remove the bottom one then you push up on the bracket and it slides out over the top bolt.
Old Mar 3, 2018 | 08:32 AM
  #152
MTP55's Avatar
MTP55
So if I'm just torquing them do you do both ot just the exposed one?
Old Mar 3, 2018 | 08:51 AM
  #153
AllaboutMPG's Avatar
AllaboutMPG
Just the exposed one
Old Mar 3, 2018 | 08:52 AM
  #154
Wes444's Avatar
Wes444
Just the one below and centered of the injector solenoid. The top one you see is for the oil deflector. The top injector bolt can't be accessed without pulling the injector. 👍
Old Mar 3, 2018 | 08:55 AM
  #155
MTP55's Avatar
MTP55
Got it! Thanks. I'll warm the truck up and then check them again. Funny thing is the only ones that weren't tight were the ones I suspect of making noise. Maybe it will fix the problem.
Old Mar 3, 2018 | 09:03 AM
  #156
AllaboutMPG
how loose were they? Did you start at 50 lbs?
Old Mar 3, 2018 | 09:07 AM
  #157
MTP55's Avatar
MTP55
Yes. All but two "broke" the wrench right away. The two that didn't took maybe a quarter turn. I still appear to have the noise though.
Old Mar 3, 2018 | 09:25 AM
  #158
Wes444's Avatar
Wes444
Not sure I understand your description.
Did you start off at 50 inch pounds to check if you needed to replace the injector orings, and 6 of them were below 50 before the torque wrench clicked, then you progressed up to 120 or 130 inch pounds? Or were 6 of them below 120?
Old Mar 3, 2018 | 09:29 AM
  #159
MTP55's Avatar
MTP55
Sorry. Everything broke at 50. I then moved to 120 and it took under a quarter turn to get the wrench to break. When I ran it before tightening anything there was no oil in fuel filter or coming out of the hole where the injector is. Only out of the spigot. Same as right now. A few weeks ago I ran CCT, rotational velocity, buzz test and checked ICP and IPR values. Everything passed or fell into the normal values. The only thing that was odd was number 8 cylinder but I read that scanners normally read number 8 as something wrong. Is it possible that it's just a noise this truck makes normally and I'm not used to it? I've heard a similar noise in the 6.0 at my work as well as the international 9400i semi we have there.
Old Mar 3, 2018 | 10:02 AM
  #160
brian42's Avatar
brian42
Veteran: Navy
On my truck when I torqued mine I did 50, 80, 100, then 120 in-lbs. None of them were below 100 and I got 1/8 to 1/4 turn out of each when I did the 120.
Old Mar 3, 2018 | 10:45 AM
  #161
MTP55's Avatar
MTP55
Alright. I think I'll start putting the covers back on and then finish cleaning some stuff off the engine. I have to drive it tomorrow and get my u joints done this week. I'll see if I can get someone more familiar with the 7.3 than myself to listen and see what he thinks. I could just be over exaggerating a "normal" sound. I don't have the replacement parts on hand to remove the injectors right now but if I do that it should be easier to get everything apart next time around thanks to this experience!
Old Mar 3, 2018 | 03:19 PM
  #162
Wes444's Avatar
Wes444
Sort sorry it didn't quiet it down for you. doing the H&H and RR FRx mods will make it much quieter if you haven't already
Old Mar 3, 2018 | 03:55 PM
  #163
Wes444's Avatar
Wes444
Freaking update keeps putting replies on different posts
Old Mar 3, 2018 | 05:56 PM
  #164
MTP55's Avatar
MTP55
It's all good. I gained experience and learned about the truck. There could still be setting there but I'm going to hope it's nothing that could be catastrophic withing the next couple weeks. What are those mods? Hopefully my seals for the CCV seal up for me. If they don't can I temporarily seal them with a silicone or other non hardening sealant?
Old Mar 5, 2018 | 10:46 AM
  #165
brian42's Avatar
brian42
Veteran: Navy
You got movement out of the injector hold-down bolts so it was worth it for that too to make sure they're not loose.
