Injectors
Old Apr 1, 2017 | 11:17 AM
coax9952's Avatar
coax9952
That's a good price, agreed, But the ***** in your court now, A new set of injectors are around $1600, give or take, remans are cheaper, ALITTLE bit, Your going by someone elses statement of facts. Are You going to do all the work on it? If you mechanically adept with tools, and machines, and such, have the time, etc. then It's starting to look like a good deal, But at 250,000 miles+ these rigs are getting to the Fix Me Now stage... So....See where I'm going?
At The end of the day, I repeat, Nothing about these trucks are easy or inexpensive. But we all Love ours, hell or High water.....
Old Apr 1, 2017 | 11:33 AM
MTP55's Avatar
MTP55
I would do it myself. If that's an issue. He has receipts for all work done.
Old Apr 1, 2017 | 11:41 AM
coax9952's Avatar
coax9952
Cool, ultimately, the decision is yours, if you're comfortable with what you see, $5000 is good, but don't forget, you've got a front end to think about, rattle the drive shaft, bounce the shocks, look down in the valley for oil leaks, water drips, etc, but if it runs, that's half the battle.
P.S. Service mechanics ALWAYS say the injectors are toast.....Most the time it's $4.00 worth of O-rings....
Old Apr 1, 2017 | 11:43 AM
MTP55's Avatar
MTP55
That's the next cool thing. He's already replaced all that.
Old Apr 1, 2017 | 11:45 AM
coax9952's Avatar
coax9952
"Trust But Verify"
And start going thru the Tech links on top of this page, The work is only beginning.......
But what do I know, I'm a Heretic.....
Old Apr 1, 2017 | 11:59 AM
MTP55's Avatar
MTP55
My question is how different are the 7.3 engines compared to farm equipment engines. I work on John Deere tractor and other equipment daily so I know my way around those.
Old Apr 1, 2017 | 01:07 PM
hydro man 17's Avatar
hydro man 17
I don't know about JD engines but the 7.3 has an HEUI injection system. Injection pressure is provided by high pressure oil, not by a high pressure fuel pump. That being said fresh clean oil is a high priority. I imagine that there may be other significant differences. Like I said I don't know much about how a Dear runs.
Old Apr 1, 2017 | 01:11 PM
coax9952's Avatar
coax9952
I'm an IH man myself, (old ones anyway). It's 50/50. Tractor diesels are simpler, especially to work on. But 7.3's are a different animal....Stuff is hard to get at, everything has got a pile of O-rings that are hard and crunchy at this age. injectors are driven with HP oil. tractors not so much. Hell the hardest thing with tractors is keeping the Hydro's running, not the motors. 7.3's, properly maintained will go 1,000,000. But that doesn't include the things attached to it. (Water pump, Wiring, Computers, alternators...you know, the cheap stuff......
Old Apr 1, 2017 | 01:15 PM
coax9952's Avatar
coax9952
Man I'd love to stick a 7.3 in one of my M's....The stumps I could pull.......
Old Apr 1, 2017 | 04:36 PM
MTP55's Avatar
MTP55
I feel like if it's getting better it's working bad fuel out. Injectors normally get worse not better. If need be I can replace the injectors but I feel like that's not an issue. In my budget I won't find a truck that someone is this honest on that's all stock. How long does the trans in those trucks last under normal highway use?
Old Apr 1, 2017 | 05:19 PM
hydro man 17
Is it manual or auto trans? Have any records related to trans maintenance? Like anything else it is totally dependent on how it was treated.
Old Apr 1, 2017 | 05:22 PM
MTP55's Avatar
MTP55
Auto. This guy babies his trucks. One of the few I've ran into that keeps it stock and sends it in at every maintenance interval. Also has the rear end cover replaced and new fluid. Whole truck was inspected and he had the paper work to verify it.
Old Apr 1, 2017 | 05:47 PM
  #28
coax9952's Avatar
coax9952
Well that's a Hot-Button Topic too, Some fellas here get to 190-200K on their trans and consider themselves lucky (myself included) before needing some sort of major repair. Some barely get to 100K before giving up the ghost. Depends on maintenance. My opinion is they quit building things to last when my Moms 46 year old Fridgidaire Freezer died in 1978. My statement still stands. The Motor will probably get you to 1,000,000. Nothing attached to it will. Just my opinion
Old Apr 1, 2017 | 07:30 PM
  #29
MTP55's Avatar
MTP55
Thanks for your input. I'd probably agree with what you said.
Old Apr 1, 2017 | 07:50 PM
  #30
Dan V's Avatar
Dan V
I've read all the posts...you are talking yourself in to buying it. And at $5k you probably should.
