Injectors
Old Apr 21, 2017 | 02:05 PM
  #46
MTP55's Avatar
MTP55
Truck runs really well just have to replace a couple o rings on fuel bowl. One question I do have is what is the deal with when it starts I see what's in this picture? It goes away within 30-45 seconds of startup but my bosses truck does not do it. His also has a busted exhaust. It has been cool and damp here though so I don't know if that's it.
Old Apr 21, 2017 | 06:36 PM
  #47
hydro man 17's Avatar
hydro man 17
White smoke is usually oil. If it clears quickly you probably have some worn valve guides/ seals that allow oil to be sucked in while sitting or cold.
Old Apr 21, 2017 | 06:39 PM
  #48
Rikster-7700's Avatar
Rikster-7700
I thought blue smoke was oil and white smoke was raw, unburnt fuel?
Old Apr 21, 2017 | 06:46 PM
  #49
MTP55's Avatar
MTP55
In either case is it forewarning of a major issue, or a simple solution? I couldn't tell if it was white or gray. My bosses 6.0 does it as well and it has a new exhaust and was just in the diesel shop.
Old Apr 21, 2017 | 06:51 PM
  #50
Walleye Hunter's Avatar
Walleye Hunter
Mine does it when cold, the colder it is the more smoke for longer but never longer than a minute or so. I never really checked exactly what temps it starts at. Not a big problem IMO.
Old Apr 21, 2017 | 07:17 PM
  #51
MTP55's Avatar
MTP55
Alright. I wasn't overly concerned because it disappears but didn't know if there was a problem I needed to catch before it costs more money.
Old Apr 22, 2017 | 08:46 AM
  #52
andym's Avatar
andym
I'm not being a smartass for once... I thought black smoke was unburnt fuel?
Old Apr 22, 2017 | 09:00 AM
  #53
Walleye Hunter
My understanding is that the white smoke is emitted when diesel is not completely burnt due to cold conditions and black smoke is cause by unburnt diesel due to an overly rich mixture in the combustion chamber. I don't know the scientific reasoning behind it.
Old Apr 22, 2017 | 09:08 AM
  #54
Rikster-7700
My understanding is white is raw, unburnt fuel, blue is oil and black is partially burnt fuel usually caused by an imbalance of air to fuel mixture or incorrect timing on the combustion process.
I could be wrong, it wouldn't be the first time....
Old Apr 22, 2017 | 10:31 AM
  #55
coax9952's Avatar
coax9952
And Purple Smoke meant Barney was around doing burnouts on your block........
Old Apr 22, 2017 | 11:01 AM
  #56
SaintITC's Avatar
SaintITC
Simple Green on your tires gives you green smoke!!
Old Apr 29, 2017 | 06:44 AM
  #57
MTP55's Avatar
MTP55
Riffraff Diesel has Alliant and Full Force injectors. Just curious as to what the background is on these? If I do need to replace injectors in this truck I want to know which ones to get. And so far I like dealing with this company. Or do you buy Motorcraft Remans?
Old Apr 29, 2017 | 07:46 AM
  #58
Tugly's Avatar
Tugly
I think there is a very useful injector link in my signature - fully covering your very question. Yeah.... my 160/100 injector link.
Old May 1, 2017 | 08:45 PM
  #59
MTP55's Avatar
MTP55
How abouts do I get to that link?
Old May 1, 2017 | 08:50 PM
  #60
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
If you look in his signature (will not show up on a phone) you will see 160/100 Injectors. Click on that, or click on the direct link to it below in case you are on a phone.
https://www.ford-trucks.com/forums/1...l#post15066018
