Injectors
Old May 7, 2017 | 09:39 PM
  #76
MTP55's Avatar
MTP55
I was looking at that. Looks like a fun time to remove everything. I appreciate the help that is offered up on this site. Best informational resource I've found yet.
Old May 7, 2017 | 10:18 PM
  #77
schlepprock250's Avatar
schlepprock250
You can remove the passenger side valve cover with removing anything else. You just have to turn the valve cover until you find the correct path lol.
Old May 7, 2017 | 11:19 PM
  #78
BBslider001's Avatar
BBslider001
Most people get that pesky rear passenger bolt from the top, but if you crawl underneath and look up, here is a way to reach up with your arm and get it. IMO, it is MUCH easier that way.
Old May 8, 2017 | 07:17 AM
  #79
Tugly's Avatar
Tugly
I use a deep socket and a U-joint with about 18" of extensions on a cordless drill to zap that back one out. The two by the heater core are easy either with a 13mm flex socket or through the wheel well. If you have an Excursion, it's flex socket only - no accessibility through the wheel well.
I remember the first couple of time pulling the passenger VC, I practically stripped the engine bay to get that bugger out. Now I just grab the oil filler neck and play with the puzzle for a few seconds.
Old May 8, 2017 | 05:42 PM
  #80
MTP55's Avatar
MTP55
This isn't on topic but everyone says to use Rotella T oil in this truck. I plan to use a Motorcraft filter along with the John Deere oil we use in our machinery. It's cheaper because I buy it in drums and it would be much more convenient. Deere's specs are pretty high so does anyone think there is an issue with this?
Old May 8, 2017 | 05:46 PM
  #81
Walleye Hunter's Avatar
Walleye Hunter
If it's got CJ-4 rating go for it, if it's not I wouldn't and that Rotella T6 is no longer CJ-4.
Old May 8, 2017 | 06:29 PM
  #82
andym's Avatar
andym
If it's CJ-4 oil you're good to go. If it's CK-4 then make sure it's on Ford's approved list.
Old May 8, 2017 | 07:04 PM
  #83
MTP55's Avatar
MTP55
It is indeed CJ-4. What's the trick to removing the pesky plastic cap off the fuel filter. Mine is smooth with a 1" bolt head type fixture. I tried it with the engine both warm and when it was cool. No luck or I would have stripped that fitting right off.
Old May 8, 2017 | 11:12 PM
  #84
andym's Avatar
andym
You just have to get something to unscrew it. There are a bunch of different styles of fuel filter lid.
Old May 9, 2017 | 12:03 AM
  #85
BBslider001
You'll be better off than the rest of us using that JD oil. I'm jealous. Just use a 1" socket on the fuel filter.
Old May 9, 2017 | 12:45 PM
  #86
AllaboutMPG's Avatar
AllaboutMPG
if the top wrench portion strips out you can try a strap wrench
Klutch 12in. Strap Wrench | Strap Wrenches| Northern Tool + Equipment
Old May 10, 2017 | 11:19 AM
  #87
MTP55's Avatar
MTP55
Alright. Is there a way to reset the average mileage on the overhead display in this truck? It seems to be stuck at 15.5 and that's not what the odometer is telling me.
Old May 10, 2017 | 11:50 AM
  #88
Rikster-7700's Avatar
Rikster-7700
Hold both buttons down together IIRC?
Old May 10, 2017 | 12:04 PM
  #89
MTP55's Avatar
MTP55
You remember correctly. I should have thought of that. Thanks.
Old May 13, 2017 | 08:22 AM
  #90
MTP55's Avatar
MTP55
How fast would the oil level rise if fuel was getting into the oil?
