Going under the valve covers
Old Nov 17, 2011 | 12:19 PM
trekbasso's Avatar
trekbasso
Hi all,
I am a little ADD and every time I do the search for the 50cent mod I spend an hour or two looking at all the other posts that pertain to my truck. Great info, but TMI !!
What is the direct link to the 50cent mod, Please?
Thanks,
Tom.
Old Nov 17, 2011 | 02:09 PM
PaysonPSD's Avatar
PaysonPSD
Here's the video.
2001 F350 7.3L Turbo Diesel, UVCH - YouTube
Here's a post by Chris (F350-6) with a couple of pics.
LINK
Don't forget to retorque the injector hold down and the rocker pedestal bolts.
Old Nov 17, 2011 | 03:17 PM
trekbasso's Avatar
trekbasso
Perfect. Thank you, and now I can go back to acronym school. I noticed UVCH a lot but didn't snap!
After watching the several pages of DemonRace6's issues with noise (which I have also), I am a little aprehensive, but it has made noise since I bought it (10k ago), and doesn't miss, at least not bad, so we will see this weekend.
Thanks again, great video. And torque specs.
Tom.
Old Nov 17, 2011 | 03:41 PM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by trekbasso
And torque specs.
If you have an in/lb torque wrench use it for the injector hold downs. It should be more accurate.
If you have a late 2002 or 2003 you may have the upgraded UVCH harnesses and the quarter may not fit right In that case you just need to cut more material off the quarter.
Old Nov 17, 2011 | 05:13 PM
trekbasso's Avatar
trekbasso
Thanks for the note. Yes I do have inch lb torque wrench, but my truck is a Jan '01 build.
But nice to know in case the quarter didn't fit.
I am guessing the valve cover gaskets are re-usable? From the pictures they look like o-rings?
Tom.
Old Nov 17, 2011 | 06:52 PM
guitarpicr's Avatar
guitarpicr
Tom -Yes vc gaskets are reusable
Old Nov 17, 2011 | 06:54 PM
trekbasso's Avatar
trekbasso
Great, thanks.
Old Nov 18, 2011 | 12:47 AM
kawcrasher's Avatar
kawcrasher
Start it up with the VC's off and take a look and make sure everything looks ok. It is also a good way to make sure you plugged everything in before it is all back together.
Old Nov 18, 2011 | 12:57 AM
Bonanza35's Avatar
Bonanza35
Off tread, where to get a in/lbs tork wrench. I can't find on. I checked Sears, and other places and knowbody carries them. Thanks a head of time,
Chet
Old Nov 18, 2011 | 01:11 AM
ChunderDownUnder's Avatar
ChunderDownUnder
1/4" Torque Wrench - 20-200 in. lbs.
Old Nov 18, 2011 | 01:31 AM
BigAlsPSD's Avatar
BigAlsPSD
Since you mentioned sears, Sears: Online department store featuring appliances, tools, fitness equipment and more
http://www.sears.com/shc/s/p_10153_1...&blockType=G23
Old Nov 18, 2011 | 05:48 AM
trekbasso's Avatar
trekbasso
I would agree Sears should, or a good auto parts house. The inch lbs is more accurate for smaller numbers, but a lot of 3/8 drive go as low as 5 lbs ft. I have always had access to Snap On or Matco.
Tom.
Old Nov 18, 2011 | 11:00 AM
PaysonPSD's Avatar
PaysonPSD
See this LINK about burned center pin and plug.
Old Nov 18, 2011 | 04:12 PM
trekbasso's Avatar
trekbasso
Thanks a bunch for that extra note. I will double check the pins when I take the vc off tomorrow.
Tom.
Old Nov 18, 2011 | 09:24 PM
Bonanza35's Avatar
Bonanza35
Originally Posted by ChunderDownUnder
Thanks Brain, and Alan also. I have a Sears tork wrench already in ft lbs and it doesn't click most of the time. Its funny because I still have the box and it says sears best right on it. I went back and they won't exchange it, so I'll try the harbor Frieght one this time. Hope calibration is good because of inch pounds. Again thanks for the help!
Chet
