Engine Rebuild Part 2
Old Feb 20, 2017 | 10:15 AM
  #376
AbandonedBronco's Avatar
AbandonedBronco
I now have all my paint and started in on the prep work.
Due to how long this build has taken (started it March 2016) the block had a bit of surface rust on it. I sprayed it down with some degreaser and then spent about 30 minutes or more with a wire attachment for my drill.
It worked really well. Definitely glad I did. I had that lazy "it'll be fine" moment, but once I started, there was a good amount of rust dust filling the air.
A base coat to get it started.
After the base coat dries, I'll spray it down with the red, and then do the other side.
I also got the head prepped a bit, but no paint yet.
I need to get some spark plugs to plug the holes so I can paint that side too.
Old Feb 21, 2017 | 08:56 PM
  #377
AbandonedBronco
My phone camera did terrible justice to just how nice the red looks, but the block is painted a nice Ford Red. Next, I need to get some spark plugs so I can block up the head and paint it. Then, assembly!
I put vaseline over the freeze plugs, so once it dries, I'll clean those off.
Old Feb 22, 2017 | 10:42 AM
  #378
AbandonedBronco
Since my phone did such a horrid job of capturing the red, this is what it looks like!
Old Feb 22, 2017 | 11:34 AM
  #379
F-250 restorer's Avatar
F-250 restorer
Lol, I'm laughing because of my remark in the PM, where I mentioned the pink that the engine appeared to be, would make onlookers wonder what side of the fence you were on, made you clarify by quickly posting another photo of the red the engine really is.
Lol, "I just want to set something straight ..."
Old Feb 22, 2017 | 03:10 PM
  #380
AbandonedBronco
Haha, well, you're not the only one. My brothers had some interesting comments on my "pink" engine.
I'm going to have to go out and snap some much better pictures to replace the ones above.
On a side note, does anyone know the thread pitch on our spark plugs? I'd like to get some cheapie bolts to use instead of going and getting actual spark plugs.
Old Feb 23, 2017 | 08:26 AM
  #381
1986F150six's Avatar
1986F150six
Spark plugs are probably just as cheap! Especially if just the regular ones [non-platinum].
Autolite Copper Core 45 - Spark Plug | O'Reilly Auto Parts
Old Feb 23, 2017 | 09:45 AM
  #382
AbandonedBronco
I thought about that. But I have a place to get some pretty inexpensive hardware. Could probably get a set of 6 bolts that would fit the holes for the same as one or two spark plugs.
Old Feb 23, 2017 | 10:08 AM
  #383
1986F150six
Additional Details
  • Center Electrode Design: Standard/Regular
  • Ground Electrode Tip Material: Copper
  • Hex Size (In): 13/16 Inch
  • Hex Size (mm): 21mm
  • Insulator Type: Projected
  • Resistor Plug: Yes
  • Seat: Tapered
  • Thread Size: M18-1.50
  • Thread Reach (In): 0.468 Inch
  • Insulator Material: Ceramic
  • Center Electrode Core Material: Copper
  • Center Electrode Tip Material: Copper
Old Feb 23, 2017 | 10:21 AM
  #384
AbandonedBronco
Sweet, thanks!
Old Feb 24, 2017 | 09:04 AM
  #385
AbandonedBronco
Got some more painting done last night.
Put another coat on the block, and then finished up the head. (Now time to bolt them together!)
I wasn't able to find bolts big enough to fill the spark plug holes, but while I was at the store, I found something even better.
Plus, they were about 35 cents a pop. Can't argue with that.
One thing that I found that was a nice perk of ordering parts for your engine online is that all the boxes have to be long enough for the parts, which makes them long enough for the engine. They made for a great splash guard.
Laid down a base coat and then painted. These pictures also do a MUCH better job of capturing the red I used, even though they're still not quite there. The fluorescent lights really screw with the photos.
I'm planning to pull all the tape off and bolt it together, as well as put on the oil pan this weekend. Then, I can measure for pushrods and get the valve train done.
Old Feb 24, 2017 | 09:26 AM
  #386
1986F150six
Keep up the work and thanks for the photos!
Old Feb 24, 2017 | 02:00 PM
  #387
fordboy300's Avatar
fordboy300
Awesome AB!!! keep up the good work man!
Old Feb 25, 2017 | 01:05 PM
  #388
F-250 restorer
Is that Alice Cooper's signature on the lower left?
Ha ha. Hate the color, but that's okay.
I would use studs for the fuel pump mount, run a braided line from pump to carb, and allow the engine to utilize all the mods you paid for by ditching those efi manifolds and using headers, and top it with a good looking v. cover.
Old Feb 25, 2017 | 07:01 PM
  #389
AbandonedBronco
I like the idea of studs for the fuel pump. And I'm goin gto throw away all the vacuum and fuel lines and start them over from scratch. Some braided fuel line would be nice to get and use.
So, I think I actually got pictures that captured the darn color. It was sunny out today so I was able to open the garage door while I was working.
Got the ARP head studs installed. They were really nice to work with. They had a hex wrench fitting on the top for easy installation, and then came with fastener lubricant to help them turn easier. Their torque spec is 80 ft/lbs instead of the stock 85 ft/lbs, which I thought was interesting.
Here is the Fel Pro 1024 gasket.
Here's the more generic Fel Pro 8168 that came with the rebuild kit.
The last time I'll see the chambers on the head in a while. (At least it better be!)
The ARP head studs / nuts.
Installed the oil pump and screen.
Set the oil pan in place to get a look at the color combo I have picked out (red and black).
I like it.
Next is to borrow the solid lifter from my machinist so I can measure push rod length. Also going to bring him all my covers and get them sand blasted so I can paint them. I'd love a nicer valve cover, but Clifford is about the only one who makes one, and they charge a pretty penny for them, so, stock it is.
Old Feb 25, 2017 | 08:27 PM
  #390
F-250 restorer
Wow, you are right. It looks so different in the light. Quite a change. I might even have to stop razzing you about it. Ha ha.
All joking aside, it looks great. What a beauty. What a shame you had to install that head. I just love every photo you took of it and the chambers.
Eighty pounds torque on the head studs? I don't recall torquing mine, but it's been years since installation. Nice work. I do remember being told that studs torqued different than bolts, applying more torque, so maybe that is why the different amount of torque. Guess.
Quite an engine.
