Engine Rebuild Part 2
When I ran the Summit carb it had 67 primary jets and my engine loved it and did not run rich! I now have 58's in my 1848, and the carb is a step down in performance. My engine wants the flow of a 600 cfm. And with the ridges shrouding my valves, the lower lift of my cam, and my runners not being ported, I KNOW your engine wants to breathe more than mine. I know you don't want to hear it, but I think that to unleash that monster you need a carb with higher flowing primaries.
Sorry, I don't mean to tell you how to spend your money, ha ha. I'm very happy you're driving it.
PS. Ordered a LUK clutch. It seemed like a toy. I'm sending it back. I should have listened to you. What brand did you recommend? Sorry to hijack.
Probably about $500 for the whole project with the R.R.s, different length push rods (if they change much), and the spacer for the valve cover.I've checked the spark plugs a few times and there's barely any tan on them. I'm thinking the 57s are still a touch lean.
I'm thinking that if the 450 (or your 465) feels too small, the secondaries should be adjusted to open sooner to give it that air flow it needs. A smaller carb is going to give a lot better throttle response, and 450 cfm should be plenty for the 300 up to about 5000 RPMs! Fortunately, I do have a 600cfm Holley sitting in the garage that is tuned pretty nicely (at least for the stock engine). Maybe I'll play with them both.
The perk of the QF is being able to change the air bleeds and power valve restrictions. A bit more complicated, but so much tuneability.
I'm not super familiar with the LUK clutch, but I remember seeing pictures of them, and they looked like they were trying to use flashy looking stuff to try to sell stuff. It looked too colorful and techy. I'd rather it just work.
The one I got is a Sachs, and it seems to be really nice. It's what I had on it previously, too, and never had an issue with it.
I'm getting a noise in the engine that I'm not liking. There's a squeal/chirp coming from what sounds to be the valve cover. It's very persistent, as in, it's there ALL the time. It doesn't come and go, it doesn't quiet down, it changes with engine RPMs, and is audible at all RPM ranges, etc.
I started by taking all of the belts off and running it for a few moments, but the sound was still there, so it's not a pulley.
My first fear, of course, was a lifter/cam lobe, so I pulled the valve cover and pushrod cover off last night. All 12 of the rockers were well covered in oil (I head read about someone getting the noise from a dry rocker arm).
Of course, my brain took the chirping sound and imagined it as the horrid visage of a bad lobe scraping metal off of the bottom of the lifter. So, I turned the engine over by hand and examined how far each lifter rose up above the bore with a feeler gauge. All 12 of them rose the exact same amount, so that definitely put me at ease. I would think that after 150 miles, if a lobe had gone bad, I would have been able to see some discernible difference in lifter height.
So, other than that, I have no idea what the sound is. Any ideas?
If you are getting a squeal/chirping on the top end, there are three places I can think of to check:
#1. Did you make sure to get hardened push rods? You need the hardened pushrods if you are running the head with push rod guide slots. I would pull a couple push rods out and check them for scrapes/scuffing/scratches.
#2. Check the cup end of the rocker arms to make sure they are getting enough oil from the push rods.
#3. Check the pivot ball area of the rockers. I'd also check the slots to see if the ends are hitting the studs. That won't cause your chirping but could be the ticking noise you've got ( if it's not the lifters ) .
5 of them are from Trend Performance and cut to length. They have a 0.080" thick wall. They offered 0.105" thick, but those stop at 9.8" and the shortest I needed was 9.9".
Whether or not they're "hardened", I'm not sure. I'm not seeing anything on it.
I did pull them out recently (when I broke in the second set of lifters), and on the black ones (much easier to see than the silver ones) the ends of all of them were already silver and the sides had some scuffs. This was before the noise started so I didn't pay much attention to it and I just figured it was due to normal wear/tear taking the black finish off. Nothing looked galled or damaged, though.
These are the guide slots that I have.
But, that doesn't mean they're getting sufficient oil. How would I tell though?
Overall, the chirp sounds like it's coming from a single source, so if there's an issue, I think it's only with one of them. It sounds like it's one time per engine revolution.
As for the slot, I thought about this when it was first ticking and checked it. It'd make sense since the slot is designed with a much lower lobe lift than what I have. However, at full tilt, there was still about 1/8" of clearance at the end of the slot before it hit the stud.
Oh, and for what it's worth, I put a magnet in the oil under the valve cover and it was clean. No metal flakes of any kind as far as I could tell.
Any info on what I should look for? The noise has not increased/decreased/subsided/etc.
Also, now (unlike when I first started started breaking it in) the oil pressure is getting pretty high while driving it. Idle is 50 - 60% on the gauge and driving is around 80%. On the L of NORMAL.
It's the same gauge I've had for the last few years, and it's always been fairly consistent, so this is concerning me.
Also, with the spark plugs out, turn the engine over with a ratchet and listen for any squeaks that way.
Mine sounds the same, and I only have .450 lift. I think it is cam/valve motion/rocker arm noise. I didn't notice it because I'd never heard mine run stock. But someone said it sounded diesely. I think it is simply a by-product or result of running oem rockers with high lift cam. They're not designed for the range of movement we're putting them through. And, btw, my buddy with that roadster with the black 300, his sounds the same, and he runs chebby oem rockers.
You have a great great engine.
However, one thing I did notice, and I don't know if this is it, but it almost looks like there's a "burn" area on the rocker arm (both had it). Maybe it's from the break-in lube not flushing it out and getting glazed? It was on there really well, and I couldn't scrape it off. I didn't want to get too heavy with it since I didn't have anything that wouldn't damage the mating surfaces.
You can really see the black on the ball on this one.
Would this cause it?
I know it's the stock gauge, but it's NEVER been that high before. When I first broke the engine in, and first 30 - 50 miles, it never went above half. So it should have actually gone down after things broke in and loosened up. Going up makes me nervous.
However, I do agree about the stock rockers, and I might start saving up and collecting parts for some aftermarket rollers.
I took it to the machine shop and had my builder listen to it.
They definitely thought it was a weird sound, but they had no idea what it was.
So... I guess that's good and bad.
Bad in that we don't know what it is.
And good in that it's not one of the big issues that they're familiar with and something that means we have to tear it down.
But it's extremely annoying. I've gotten used to the rocker arm noise, but this CHIRP CHIRP CHIRP is driving me crazy. I can hear it over everything, especially from in the cab.
They actually thought there was some credence to the idea that the glazed on break-in lube was still on the rocker and ball, so I'm going to disassemble them all and try to gently get that stuff off with some scotch-brite or something. He then gave me some other engine grease/paste that he wants me to put on it before firing it back up.
If nothing else, even if it was just quiet for a minute, I could isolate it to the rocker arms. If it's not the rocker arms/valve train, then it's still coming from deeper in.
If it is the rockers, I think it might be time to start looking into upgrading them. I think that'd alleviate a few issues.
Decided to do my first compression test:
1 - 160
2 - 160
3 - 165
4 - 155
5 - 168
6 - 160
Really nice numbers. Of course, I'd like them to be a tad more even, but I'm only around 250 miles on the engine, so it's got a bit more to go before it's fully broken in.
These numbers are also on a completely cold engine.
I just can't tell where it's coming from.
Going to keep digging.
Who knows, maybe it's something as simple as a bad fuel pump.
