Engine Rebuild Part 2
Old Feb 5, 2017 | 04:10 PM
  #331
AbandonedBronco's Avatar
AbandonedBronco
Thanks for those links. I'll get one of those ordered here soon.
Next question, for the nuts on the rocker arms, I have stock rocker arms, but I also know that the stock setup was a torque-to-spec setup where you didn't have to adjust for valve lash, etc. So, as such, only one nut came with the rocker arms.
Now that I have screw in studs and my rockers are going to be adjustable, is the single nut going to work?
Or will it move after time?
Do I need a second hold-down nut?
If so, will any nut work, or is it something special?
Thanks.
Old Feb 6, 2017 | 11:18 AM
  #332
The Frenchtown Flyer's Avatar
Originally Posted by AbandonedBronco
What's the best way to tell what length pushrod I need? Thoughts?
Ideally, when the lifter is situated at the midpoint of the cam's lobe lift a line drawn through the pivot point of the rocker arm to the tip of the raised valve will be at a 90 degree angle to the valve stem.
Trend Performance makes off-the-shelf pushrods in .050" increments.
Old Feb 7, 2017 | 08:45 AM
  #333
img]
Look closely at the nut pictured. It is known as a "torque prevailing nut". You can tell this by the three indentations on the top of the nut, where the top thread has been "smashed in" to create an interference fit on the stud. It will not loosen. The torque required to tighten it is immaterial as that torque is engineered into the interference design. Another more familiar type of torque prevailing nut is the type of locknut with a nylon insert at the top which does quintessentially the same thing as your torque prevailing nut, but is not appropriate in the environment under the rocker arm cover. You are good to go without an additional nut.
Be aware, however, those torque prevailing nuts do not have an infinite life and will eventually get sloppy with repeated use, negating their locking feature.
Old Feb 7, 2017 | 01:25 PM
  #334
AbandonedBronco
Thanks FTF, that makes sense.
And I had heard before that the rocker arm nuts do fatigue over time, and one of the reasons they went to pedestal rockers. Is the slop/fatigue from repeated adjusting? Or just miles?
Old Feb 8, 2017 | 09:36 AM
  #335
Repeated adjusting
Old Feb 10, 2017 | 11:28 AM
  #336
TheDudeAbides's Avatar
TheDudeAbides
you may want to consider running her up to temp, making your adjsutments, then shut it down after all fasteners are torqued. then snag some extras from a local fastenal and run them down to lock against the stock supplied "crimp nuts." might be a bit more insurance that they wont walk on you over time.
Old Feb 10, 2017 | 01:09 PM
  #337
F-250 restorer's Avatar
F-250 restorer
I would like those rockers better if they said FoMoCo on them.
I've run the oem rockers and nuts for over five years without an issue.
Old Feb 12, 2017 | 08:53 PM
  #338
F-250 restorer
Stop teasing us, AB. We want sound clips and vids, photos and descriptions of the power!!
Fire that baby up...please. We're waiting, dying to hear.
Old Feb 13, 2017 | 11:21 AM
  #339
AbandonedBronco
It's getting closer. I'm still collecting things to put it together, and that's on a budget as well.
The head gasket and ARP studs arrived a few days ago, so I'll be bolting that all together here soon. I'm also waiting on the paint I ordered to show up.
Once I get the head bolted to the block, things'll speed up a bit. But I still need to track down a few odds and ends like a water pump, oil sump screen, thermostat housing, etc.
Plus measure for pushrod length and get those on order once I get them zeroed in.
I'm anxious! But only so much money coming in at a time.
I'm starting to get a little cranky about how long it's taking though...
Old Feb 13, 2017 | 04:24 PM
  #340
AbandonedBronco
Originally Posted by The Frenchtown Flyer
If you end up with a set of V8 pistons make sure that they have ZERO PIN OFFSET or you will have a very noisy motor. At least two holes will have the pin orientated in the wrong direction.
Can you elaborate on this? I used 351 pistons in mine and don't ever remember any mention of this, nor do I know whether mine do or not.
Some engines have the pin offset by about .050" to make the engine a little quieter by putting a little preload on the thrust side of the piston to prevent piston slap on compression as the piston rocks across TDC. The preload on a six should be toward the left hand (drivers) side of the engine. Since V8s generally use the same cylinder head on both sides of the engine the valve orientation, valve notches, dishes and domes will be mirror imaged from side-to-side. In the case of a V8 piston with no valve notches, dishes or domes - i.e. a true flat topped design - it would matter little and all pistons could be oriented correctly in the six. But with a dish or a dome if you wanted to keep the dish / dome alignment with the six's combustion chambers it would be necessary to turn two of the V8 pistons around, thereby not only negating the effects of an offset pin but making the piston slap worse by offsetting the piston in the wrong direction.
Another consideration is effective rod length. Pin offset affects effective rod length and piston speed through its travel, especially influencing the accel rates as it approaches TDC. So it has a slight effect on scavenging in the overlap phase.
So, this came up in another thread and I wanted to address it here (so as to not derail the other thread too much).
This is quickly making me nervous, since this is the first time I'm hearing about this. I would rather find out now that there's an issue with my pistons than after I get it all installed and fire it up.
I am using 19cc pistons from a 351w V8.
These, to be exact:
https://www.summitracing.com/parts/s...view/make/ford
I don't see anything about pin offsets, and I don't know the more intimate details about a 351w. However, is this something I need to be concerned about? How would I know? How can I check?
Old Feb 13, 2017 | 05:05 PM
  #341
fordman75's Avatar
fordman75
You have to check information for the pistons you got. I'm going with the Keith Black KB181 pistons. They are listed as a centered pin.
Old Feb 13, 2017 | 05:17 PM
  #342
AbandonedBronco
This is the only site I can find that lists any specifics about the pistons I got (H653CP).
https://www.fmmotorparts.com/fmstore...0#.WKI8wfkrKUk
It says that they have a 0.060" offset.
After reading about it, I can definitely see why having some offset would be beneficial. However, how do I find out if they're mirrored, or, if they're all the same, that they're installed correctly?
They do use a dish that's non-biased to one side or the other:
Old Feb 13, 2017 | 06:22 PM
  #343
fordman75's Avatar
fordman75
Nevermind, You beat me to the info.
You might want to contact your engine builder and see if knew about the offset and if they were installed correctly for the offset.
Old Feb 14, 2017 | 11:05 AM
  #344
AbandonedBronco
Alright, so I unwrapped my present last night so I could look at the pistons. I wanted to keep it wrapped as long as possible to keep dirt and such out of it, but I needed to dive into this piston issue. Plus, I've just been wanting to look at it.
I noticed that all of the pistons had an arrow on them. I'm assuming pointing toward the front of the engine. However, I didn't find any other distinguishing marks that would state whether they're for the left or the right bank of cylinders on a V8.
No markings on the underside either. And it was too difficult to tell if a pin was 1/16" to the left or to the right.
Now, one thing I did forget to do was grab one of the two surplus pistons I have sitting in the box and look at them. They might tell me something, so I'll do that tonight.
Old Feb 14, 2017 | 12:45 PM
  #345
fordman75's Avatar
fordman75
Well you've got 6 arrows pointing forward. That means your builder didn't flip two of them. So he probably didn't know about the offsets.
