. For $50.68 The picture shows it has the right vacuum advance, but since the picture doesn't show the right cap or adaptor, so why would I believe it has the right advance.
But the idea of having a new dizzy for $19 is intriguing so I think I'll order it and see.
I'm going aftermarket simply because they are easier to find here, believe it or not. So many old fords are still running out here. I also think the Duraspark upgrade may have already been done to this truck.
As Jim said, my theme is "Ford, another way" and when it'll work I want to use Ford. Bill Vose/85Lebaront2 assures me the DS-II system is up to the task, and he should know as he ran a carb & ignition shop for decades. (And don't get him started on MSD.) So I'm going that way unless it doesn't work.
I've done a little bit of that myself, with a Taurus alternator and an E350 power steering pump etc...
MSD takes the 'shotgun' approach to ignition below 3k where it is relatively easy to ignite the charge and there is time for it to burn.
You're back to a single spark when the engine is spinning and working hard.
My truck loves to cruise at 3k.
Why is that???
Wow! That's a huge steal! And, I'll bet coming from a stop in 2nd you shift pretty quickly. With my 3.50's with the M 3rd is the do-anything gear. You can take off from a stop if you want, it is the gear for city corners, etc. but I'll bet with your torque and 4.10's 4th is pretty useful.
