Dad's Engine
Old Jan 26, 2014 | 05:51 PM
  #151
bruno2's Avatar
bruno2
Jim is having connecting rod envy I see. I knew this was going rear its ugly head sooner or later.
Old Jan 26, 2014 | 06:12 PM
  #152
first today's Avatar
first today
Gary, I was doing some surfing and saw this article about the "Mutt".
Have you seen or read it? 500 horsepower 565 torque for $5,000.00. They used Eddie heads. It may not be very informative though... it only goes 6 pages deep before conclusion.
The Mutt - Tech - Parts Used - Hot Rod Magazine Page 2
Old Jan 26, 2014 | 06:18 PM
  #153
bruno2's Avatar
bruno2
Kyle, I don't know what to say about the article. The F 100 never had a 400. They had the 351M. So they may not even know what they did. The cranks are different in the two motors.
Old Jan 26, 2014 | 06:39 PM
  #154
Gary Lewis's Avatar
Gary Lewis
Ok, I've read the bit in the link on rod length and cam timing. And they summarized by:
In general, to achieve the same piston position timing with short and long rods, the engine with longer rods should have a cam with slightly less duration and with a smaller lobe separation angle.
And, in their example the change from a 5" rod to a 6.2" rod was only 1.7° in intake valve closing, so that isn't a huge change with a large change in rod length. But, what it doesn't say is whether two engines having cam timing determined by "piston position" will cause them to run the same. Or, did I miss that?
Old Jan 26, 2014 | 06:57 PM
  #155
bruno2's Avatar
bruno2
Do we assume they know it was a 400? Gary, just going by what you went through to identify yours makes me wonder if it was a 400 or an M.
Old Jan 26, 2014 | 06:58 PM
  #156
first today
I can remember them in the 77 to 79 models. Then again they may have just been 351m's.
I also found an older thread here at FTE with some feuding, but an interesting link from member William William.
M-Block 351M/400 History
I am sure Gary has read most of this in some of his books already, but it is some cool history to learn.
And Gary I still vote for the Aussie heads.
Old Jan 26, 2014 | 07:10 PM
  #157
Gary Lewis's Avatar
Gary Lewis
Kyle - I have read that one several times. They got lots of power, that's for sure.
However, by leaving the pistons down in the hole .030" they killed the quench they could have had from the Eddy closed-chamber heads. So the M/400's propensity to ping or clatter is still there in that engine. The problem they had was they couldn't find pistons with the proper dish to give them the right CR when zero-decked. Fortunately in the 6 years since they did that Tim has come along and provided pistons that fit most of our needs on the 400. He has pistons that give essentially the same CR they had, 10.5, while coming right to the top of the block, thereby giving good quench. The best of both worlds.
Anyway, while I'm not going to have quite as many cubes (408 vs their 431), and probably not as much cam, I do expect to make lots of power! Thanks!
Old Jan 26, 2014 | 07:11 PM
  #158
Gary Lewis's Avatar
Gary Lewis
Yep, Bubba's site is one I have bookmarked. Lots of good info there.
Old Jan 26, 2014 | 07:13 PM
  #159
Gary Lewis's Avatar
Gary Lewis
They being Hot Rod? Yes, they had the crank ground to 4.2" so it had to have been a 400 as you can't grind a 3.5" throw M crank to get to 4.2".
Old Jan 26, 2014 | 07:26 PM
  #160
bruno2's Avatar
bruno2
OK, I didn't see that part. I was thinking in the back f my head that Hot Rod wouldn't just throw something into their magazine w/o making sure it was accurate.
Old Jan 26, 2014 | 07:45 PM
  #161
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
There's no replacement for displacement.
Try boring your block to 4.36"
The difference in that graph is 1.7"-1", or... 0.7"
Are they saying ~'have the same amount of overlap with a tighter LSA'?
(sorry if I am not following closely. either the FTE server or my Gmail is having an issue. Seems notifications are held up for hours)
Maybe it's the NSA?
Old Jan 26, 2014 | 09:16 PM
  #162
CarolinaCanes's Avatar
CarolinaCanes
Most definitely the nsa. It always is. Sneaky *******s
Old Jan 26, 2014 | 09:35 PM
  #163
bruno2's Avatar
bruno2
Maybe it's the NSA?
If I took my cylinders over that far I would just have two long channels on both sides of the block.
My email hasn't updated the threads at all tonight. The only way I know if there is a reply is by actually logging on and checking the threads.
Old Jan 26, 2014 | 10:11 PM
  #164
Gary Lewis's Avatar
Gary Lewis
In the example they said the piston on the 6.2" rod would be at the same place at 53.3 degrees. That put it at the same place as the one on the 5" rod when it was at 55 degrees. Ergo a 1.7 degree diff due to the rods.
Email up dates? You are getting them? I think I'm getting yesterday's. Chris knows about and has alerted the proper folk, so hopefully they can find the plug and fix it.
Old Jan 27, 2014 | 12:11 AM
  #165
Brad from Oz's Avatar
Brad from Oz
Na, Obama just said they'd wind back on the sneaky action didn't he?
I'm sure the NSA handed back the keys to the candy store
My notifications are about 6 hours late, so it must be the Eschelon system
