Si, made that connection when the 6" bar from Tuff had 4 LEDs across lol I wish they had a 4" bar in flood pattern though I need those for my bumper and the Rigids for for $250 a piece vs $38 each lol.
That would work however I need the side mounts like on the normal bars because the bumper has those mounts built in...makes things so difficult when you need something specific lol. I am going to get these if Fusion cannot make 6" LED bar openings and move the 6" bars to the Expy's grille.
Hey guys am I crazy or with 3/8" hardware the hole drilled should be done with a 3/8" drill bit? I just drilled the spare holes for the rear shackles and the bolts are still too big.
Also the front hangers use 1/2" hardware and the 1/2" hole I drilled is fine.
Unfortunately I don't have the bolt sizes so maybe I will just file the hole out a little to make them fit. They fit perfectly in the original rivet holes.
