Speculation:
Years ago off-road diesel had higher sulphur and that messed up engine, NOT the red dye.
Now i believe even offroad is ulsd, so other than the dye and a hefty fine is the same fuel as at the pump.
I seem to remember reading there were some small changes in lift/duration but they should be interchangeable. Hopefully one of the Tech's will be along shortly.
I think that shot is looking down the lifter bore at a cam lobe. The pics kinda blurry but it does look galled. Not that it's going to matter if that's a couple of cam lobes in that pair of vice grips.
It doesn't smell like diesel that I can tell. And it doesn't look to be runny either like fuel filled oil.
I am trying to figure out as well if it was fuel where did it all come from? Surely one dead hole for a little while didn't dump that much fuel?
It doesn't take long at all to fill the pan with diesel from a bad injector. My first truck had 6" of diesel in the pan at 491 miles. When I got the truck back 6 weeks later it had another 2" after 150 miles. Those were the EARLY days of learning about the 6.0's
You'd better check the front cover first. It may be trashed and give you a chance to upgrade to the 100mm water pump cover.
Yeah I will get into it more before I order the pump. I wanted to get at the lifter to see what I would be needing for that. I have a pretty good idea of my parts list now, just a couple more things to check out and I'll be spending all my money. lol
You may want to look into other motor options at this point (don't remember the mileage on this one). It could get pretty expensive to replace all those parts.
