BIG RED's build thread
Old Oct 6, 2013 | 07:41 PM
  #136
fordpride's Avatar
fordpride
I think in normal conditions it would be fine. But in a off road situation I could see it flexing and breaking the IC.
Old Oct 6, 2013 | 07:42 PM
  #137
stainlessstroker95's Avatar
stainlessstroker95
You dont mess around Bill. Parts arent safe sitting around at your shop. Now you get that e fuel on yet? Haha
Old Oct 6, 2013 | 08:01 PM
  #138
ReBilld's Avatar
ReBilld
Originally Posted by oldbird1965
Looks great Bill, a good days work for sure!
Thanks Glenn.
Originally Posted by 427 fordman
That is how I originally mounted mine, then before I put it back together had that same thought and rigged the bottom mount to go to the core support also. I'm not sure if its necessary Bill, but a thought.
Ya know, I never thought about the frame flexing, but honestly, once that bumper is back on there, I don't think it could flex much if any. It bolts to the original bumper mounts, and there is also a piece of channel that goes up inside the frame and is bolted with two 3/4" bolts on each side. But, I think you guys are right, I'm gonna cut those back loose from the frame and make a mount that bolts to the core support. Thanks for pointing that out guys! I tell ya, I've never had one of these trucks with a perfect rust free core support before. I had to work up the nerve to start hacking on it with a cutting wheel! LOL!
The turbo should be here tomorrow Gabe. I think I'll start on the mount and pipes for that when it I get home from work!
Old Oct 6, 2013 | 08:12 PM
  #139
fordman67's Avatar
fordman67
He couldnt wait for me to leave to get started lol...im just glad he is gonna get thatbeast in tip top shape.
Old Oct 6, 2013 | 08:19 PM
  #140
ReBilld's Avatar
ReBilld
Nahhh, I just didn't have anything else to do after you left! LOL!!
Old Oct 6, 2013 | 08:29 PM
  #141
ReBilld's Avatar
ReBilld
I gotta go back out to the shop and look at those mounts now......that's on my mind
Old Oct 6, 2013 | 08:45 PM
  #142
fordpride's Avatar
fordpride
I also wouldn't bolt it to the bottom mount.
Old Oct 6, 2013 | 08:53 PM
  #143
fordman67's Avatar
fordman67
I sure dont blame you ....it would be eating me up too....
Old Oct 6, 2013 | 09:29 PM
  #144
martin72's Avatar
martin72
Looks good Bill keep up the good work.
Old Oct 6, 2013 | 09:34 PM
  #145
ReBilld's Avatar
ReBilld
OK, after going out and looking at my goof up, I think I have come up with a way to use what I already have there, but make it into an isolated rubber mount. It will still be bolted to lower mount on the IC, but it will be bolted through 1" thick rubber, not anything mounted solid to the frame. The reason I drilled those holes and bolted the lower mounts on the IC is because it came out of a wrecked truck and the sides of those mounts are broke off, so I didn't want it to move back against the condenser and rub on it. I think I have it figured out though.......maybe.....
Old Oct 6, 2013 | 10:02 PM
  #146
fordpride's Avatar
fordpride
That sounds like it'll work.
Old Oct 6, 2013 | 10:07 PM
  #147
ReBilld's Avatar
ReBilld
I hope so. I don't wanna mess up that IC. I don't think I could get another one! LOL! I'll fix it tomorrow when I get home and show you guys.....see what you think.
Old Oct 6, 2013 | 10:27 PM
  #148
fordman67's Avatar
fordman67
Not hand delivefed to your door by a handsome devil such as myself anyway lol
Old Oct 6, 2013 | 11:22 PM
  #149
Awitte58's Avatar
Awitte58
Looks good Bill! Was the trucks core just that clean?!
Ive always been scared to look at mine lol
Old Oct 7, 2013 | 06:46 AM
  #150
fordman67's Avatar
fordman67
Yea alex..not even a spec of any rust.its insanely clean.
