BIG RED's build thread
Old Oct 11, 2013 | 11:23 AM
  #226
BBslider001's Avatar
BBslider001
Originally Posted by DIYMechanic
You've got skills Bill! Skills indeed. Looking great!
Originally Posted by stainlessstroker95
I think Bill needs to quit his day job, and open up a powerstroke shop. After you tackle this project, you should start rebuilding injectors.
Originally Posted by Awitte58
Id support him! Bill's customer service would be epic!
Bill wouldnt be able to make much money tho. Hes too nice of a guy and would end up giving away at cost. Lol
He could call it "ReBilld's Rebuilds" lol.
I second what these guys said!!!
Old Oct 11, 2013 | 03:00 PM
  #227
ReBilld's Avatar
ReBilld
Originally Posted by oldbird1965
"start rebuilding engines"!! I'll be the guinea (sp?) pig for the first one.
Thanks guys. I may have to do that LOL! There were only three of us left in the shop where I work, and they laid one off today, and cut the other two of us back to 4 days a week. They said it shouldn't be for long. Hopefully just until the end of the year at the longest.
I was gonna section the up pipes with v-band connectors up by the collector, but I think I will just do them all in one piece now.
Old Oct 11, 2013 | 03:04 PM
  #228
ReBilld's Avatar
ReBilld
Originally Posted by El Camino Man
Iv gotta question. If I ever decide to do a s366 on mine (which will more than likely happen... someday) couldn't you move the turbo forward some and rotate it so the cool side blows directly into the manifold? Or is there a reason to keep it back some? I think this would be worth a few extra ponies since the air wouldn't have to travel as far and turn as much lol.
On my IDI, they have the turbo mounted somewhat backwards. The air coming through the intake has to make a turn that's somewhere between 90-180* lol. That's a pretty big turn
Maybe I think too much lol
The only reason you would do a bigger turbo would be if you have bigger injectors, and with bigger injectors you are going to have higher EGTs, so you would want an IC to lower EGTs, so the turbo would be piped to the IC and not straight to the manifolds.
Old Oct 11, 2013 | 09:49 PM
  #229
DIYMechanic's Avatar
DIYMechanic
Sorry to hear this, Bill. One fully it's July temporary and toy can find enough (paying) side work to keep you going.
Old Oct 12, 2013 | 12:53 AM
  #230
ReBilld's Avatar
ReBilld
Got the up pipes fitted and tacked together tonight. I didn't use as much of the stock pipes as I thought, but I had the combo bends that I bought, so it worked out pretty good. The funny looking crook in the pass. side pipe is my attempt at leaving enough room for the 3 1/2" down pipe. I'll take them off the engine on the stand and put them in the truck tomorrow before I weld them up solid to be sure they fit.
That's all I got done tonight. I put this together for my grandson's birthday this weekend..........
Old Oct 12, 2013 | 12:58 AM
  #231
oldbird1965's Avatar
oldbird1965
Man those look good Bill. Your grandson should be a happy kid. Don't let him run you over! LOL
Old Oct 12, 2013 | 01:01 AM
  #232
ReBilld's Avatar
ReBilld
I will definitely have my steel toe boots on! LOL!
Old Oct 12, 2013 | 03:35 AM
  #233
stainlessstroker95's Avatar
stainlessstroker95
That sure is neat Bill. I'm glad someone figured out how to do this on a cheaper scale. I know it's only been a year ago, but it seems like Jake had to dent in one of the up pipes for some reason. Darin or Glenn, do you guys remember why it had to be dented in? I'm just wondering if Bill will have to do the same thing.
Old Oct 12, 2013 | 05:57 AM
  #234
427 fordman's Avatar
427 fordman
I don't remember that Gabe. It's possible one of mine was dented and I didn't notice though.
Looking real good Bill! You aren't far away from mounting that thing!
Old Oct 12, 2013 | 06:08 AM
  #235
DIYMechanic
The pipes look great Bill! Keep up the good work. And now, I'm off to install a fuel pump.
Old Oct 12, 2013 | 08:41 AM
  #236
tshrager's Avatar
tshrager
Just plain awesome Bill!
Old Oct 12, 2013 | 09:21 AM
  #237
fordman67's Avatar
fordman67
It sure is looking good! If you want...ill take the vbands off your hands for mine.
Old Oct 12, 2013 | 09:29 AM
  #238
oldbird1965
I also don't remember any denting it in. I do know mine split on top of the auto on the drivers side. Its laying on the edge that angles down after the flat top section of the trans. The trans is covered in soot. I bet Bill's up pipes are tougher then that!!
Old Oct 12, 2013 | 10:17 AM
  #239
ReBilld's Avatar
ReBilld
LOL! I didn't order the v-bands. There was some money from selling some parts that I was counting on, but I guess that deal has fell through because I haven't heard from the guy, so I'm running out of $$$. I think it would be hard to get one on the pass side pipe any way. I'l just make the collector and pipes one piece and be done with it. Maybe later when I'm bored and don't have anything to do (LOL) I can pull it out and add those in.
Old Oct 12, 2013 | 10:20 AM
  #240
ReBilld's Avatar
ReBilld
Was it the down pipe that was dented?
Thanks guys!
