Bill i dont know if you would want to do this or not, but you could use my spare 95 ipr until you get one. But im with Gleen, new is better, thats why i put a new one in when i put the t500 in.
I'm somehow just now finding this new thread. Lol. I deleted this pic off the other thread and am adding it here since this is the build thread.
FYI, I've been running a newer non edge filter IPR in my truck for a few years now. I've been meaning to change it back to one with an edge filter, but it hasn't given me any problems so I haven't bothered with it.
i'm curious - what does the edge filter do? is it a physical filter around the edge of the regulator? for some reason I always imagined it as some sort of fancy electronic internal element.
Here's big red's new turbo.
Thanks Travis! I appreciate you picking that up for me. If I can ever do anything for you just let me know bud. I'm prettt excited about getting started on the mount and pipes for it. I'm hoping they turn out ok.
No problem. It was actually a nice little drive and once I got out there we decided to crash a ricer meet and see if they had anything that would run. LOL
I'm sure your mount will turn out fine. If you need anymore ideas on how to set it up, call me.
Here's a few links for you. The turbo comes with a T4 flange gasket, oil return gasket, and a 90* fitting screwed into the oil feed. You'll probably want something different in the oil feed though. I thought I had a downpipe flange/clamp and an oil return flange on the shelf that I was going to throw in the box, but it turns out I don't... You'll need a -4 oil feed and a -10 oil return. You can step up to a -12 oil return if you want/can.
I appreciate that Gabe, but Joey, Rick and Travis all say mine will be fine, and it's supposed to be fairly new, so I'm just gonna put new o-rings on it and put it back in.
Oh come on!!!! Just think, while you're at work I could be lounging around the shop piddling with my race truck! I guess I could wrench on Big Red for you every now and again also. I mean it's only right to help out a little bit right? I'll change your batteries or something. LOL
I'm just afraid you'd be piddling with my hot wife
