S. California Chapter Join Chapter, Leader:
June All Topic
Old Jun 15, 2012 | 11:34 AM
  #211
bpounds's Avatar
bpounds
Bummer! Probably won't happen this season, if he can swing it at all.
How far is it from existing homes?
Old Jun 15, 2012 | 11:40 AM
  #212
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Morning SoCal FTE! Have a great day! TGIF
Jim
Old Jun 15, 2012 | 11:45 AM
  #213
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
There's some stuff across 395 on the West side, but it's been there for many years. Cal-Trans has a facility a little ways up 395 on the East side and there's another structure that I'm not sure of in between the two, but other than that there's nothing. That may be the first clue.
The lot is at 37.60073/-118.80012
I think the foundation is certainly doable this season. The question is whether or not he wants to proceed.
Old Jun 15, 2012 | 11:48 AM
  #214
bpounds's Avatar
bpounds
Granite Construction is the big dog up there for that kind of work, as I'm sure you know.
Old Jun 15, 2012 | 11:55 AM
  #215
bpounds's Avatar
bpounds
Well shoot, that's practically on the highway. I wouldn't have guessed the soil would be bad there. The roadbed seems to be holding up fine.
When you mentioned this job I assumed it was on the west side in that existing housing development. But he's going to be out there by himself in the open. Just down the road from the Little Green Church.
Is that a creekbed about 100' south southwest of the coords?
Old Jun 15, 2012 | 12:09 PM
  #216
SteveBricks
FTE Emeritus
There's an active spring in the Northwest corner of the lot, which I'm sure doesn't help.
Old Jun 15, 2012 | 01:14 PM
  #217
Jetcopterpilot's Avatar
Jetcopterpilot
What Area Of Crowley is this....I used to live there, and this sounds Like the Juniper drive area... or the Juniper Springs ranch area. Most of that area is dotted with natural springs, and that is pretty much the norm....
Old Jun 15, 2012 | 01:20 PM
  #218
SteveBricks
FTE Emeritus
2 or 3 miles South of the airport. On the East side of 395 @ Crowley Lake Dr.
Old Jun 15, 2012 | 01:26 PM
  #219
DieselHardware's Avatar
DieselHardware
Sounds like it could be a 20-30k ooops depending on the size of the house etc. Might even be easier to just over ex the entire thing instead of just the footing. A lot of times spending a lil more on bigger equipment will save a lot of money in labor and time.
Old Jun 15, 2012 | 01:29 PM
  #220
Jetcopterpilot
Never mind I looked up the coordinates..... yes I know that area.... it is a cow pasture.. and always has been... that is all it is good for... the other side of the road is is a lateral moraine from an Old Glacier. it is basically a debris field but it is suitable for building if you don't mind a lot of shifting... but the east side of 395 is nothing but cow patty swamp. It is the Sierra's and the philosophy is ...If you don't like the soil... move 5 ft, if you don't like the weather wait 5 minutes. I looked at buying a house on the West side of 395 quite a few years ago... two things bothered me .. one was all of the cracks in the Foundation, two was the insane amount of Pests...flying and Rats... lots of rats there....
Old Jun 15, 2012 | 01:36 PM
  #221
bpounds's Avatar
bpounds
To a rank amatuer like myself, seems like it would be cheaper to build on pilings.
Old Jun 15, 2012 | 01:37 PM
  #222
Jetcopterpilot
I almost forgot.. this is where Dave McCoy set up his first rope tow, before moving to and Building up Mammoth Mountain... his rope tow back then consisted of a rim from a Model-T way up the hill set up like a pulley and the Model-T at the bottom with a rope stretched Between the two. it worked for a few years. A few years later, that same Model-T was used to build Chair #1 at Mammoth Mountain where the current high speed Quad chair stands now... I remember when I worked on the mountain riding the old Model-T Powered chair
Old Jun 15, 2012 | 01:49 PM
  #223
SteveBricks
FTE Emeritus
Glad you chimed in Nathan, being this is right up your alley. I've never had to deal with this on such a large scale.
That was my suggestion.
The footings are a 40 x 20 box, but there are piers to support the roof trusses 8' out from the perimeter of the footing on the two long sides, so basically it needs to have 13' x 5' removed along those sides and 8' x 5' removed front and rear. The garage is a 24 x 40 slab on grade/w 3 piers in the center for roof support columns, which will also need to be over ex'ed.
Old Jun 15, 2012 | 02:51 PM
  #224
DieselHardware
That small of a footprint, if the rest of the lot is big enough for the spoil pile would be pretty quick with a loader and a skilled operator. If they are only requiring 90% for the recompaction, you could probably get that with a medium size loader if you put the dirt back in in small lifts. Otherwise a ride-on sheepsfoot would be the ticket.
Old Jun 15, 2012 | 03:11 PM
  #225
SteveBricks
FTE Emeritus
To you that's a small footprint...it's huge to me
According to the report the native soil isn't suitable for support of engineered fills or structural foundations so there won't be a spoil pile...it all has to go bye bye, and be replaced with fill that will pass a Proctor test. I don't know too much about all that stuff...I'm sure you do...but from what I can gather from the report the expansion index of the native soil is 78 and the design expansion index is 80.
