Coleman lantern
Old Apr 24, 2018 | 06:59 PM
  #736
wpnaes's Avatar
wpnaes
Too true!
$10 200a
the cheap deals are still out there.
https://ventura.craigslist.org/for/d...568511045.html
Old Apr 26, 2018 | 01:24 PM
  #737
wpnaes's Avatar
wpnaes
Posted from CCF. "Scientists from Defence Research and Development Canada and Natural Resources Canada are starting to examine whether technology, such as batteries that can be recharged from a snowmobile, could help make life easier for the troops when it comes to light, heat and cooking. But for this exercise the troops had to keep to a tried-and-true method. In the 10-person military tent, the Coleman gas stove and lantern was kept going all night. While it may be -55 C outside, the heat from the stove and lantern had the temperature inside the tent around freezing. Soldiers took turns minding the stove throughout the night."
Frostbite and fuel shortages: The logistical challenges of a military operation in Canada?s Arctic | National Post
Old Apr 26, 2018 | 03:17 PM
  #738
Tedster9's Avatar
Tedster9
Interesting article but it kind of sounds like a mistranslation or an editorial problem. Not to split hairs but what most people think of or call a "coleman stove" - generally some flavor of green box with open flame burners - could not legally, and should not, ever be used as a heat source in an enclosed space.
Stoves used for heating by regulation must ordinarily be vented to the outside, via stovepipe, to prevent carbon monoxide (CO) poisoning. If you look at the pictures at the article in fact they do just that.
For years the U S Army used the GI stove or M1941, it is most likely even now still in service. Pot bellied, with several sections of single wall stovepipe, it could burn wood, coal, diesel, or gasoline. A square variant M1950 was termed the Yukon. The rule has long been a fire guard must be posted if the stove remains lit during sleeping hours. Canadites probably have something similar, or does Coleman have a .mil contract?
Old Apr 26, 2018 | 04:45 PM
  #739
skuzzybucket's Avatar
skuzzybucket
I have 1 mil lantern, and one 2 burner multi fuel stove.They are from the 80's
Old Apr 26, 2018 | 04:51 PM
  #740
skuzzybucket
Frostbite and fuel shortages: The logistical challenges of a military operation in Canada?s Arctic National Post
Here is the lamp they speak of
Old Apr 26, 2018 | 09:17 PM
  #741
wpnaes's Avatar
wpnaes
A classic.
Old Apr 29, 2018 | 01:05 PM
  #742
skuzzybucket
Today's find. Cost me $85
Old Apr 29, 2018 | 05:53 PM
  #743
Tedster9's Avatar
Tedster9
Nice haul!
Say while I'm thinking of this thought I'd axe a question about a symptom of the stoves and how to remedy. The 425 and others, probably. You know there's the tank and generator tube assembly right, that is inserted into the burner for operation. Sometimes it will have a small flame appear there at this point. What causes this, and how to fix? I'm about to test everything out here.
Old Apr 29, 2018 | 06:03 PM
  #744
skuzzybucket
Make sure the ends are clean where they go together.
sometimes a little dust, or sluge sits where the nozzle goes in, and it doesn't seat, allowing a slight pressure leak.
Old Apr 29, 2018 | 06:32 PM
  #745
Tedster9's Avatar
Tedster9
Huh. You mean the 3/8" threaded brass fitting at the end of the generator tube?
Aha! I get it now, have some fuel & heat resistant Permatex I could use to try to seal it off. Here's a pic, not my stove, tho just so we're clear on the problem.
Old Apr 29, 2018 | 08:37 PM
  #746
wpnaes's Avatar
wpnaes
I know that flame well. Finally sold my 425B and it’s not been a problem (for me) since.
http://www.colemancollectorsforum.co...pid=1276268049
Old Apr 29, 2018 | 09:42 PM
  #747
Tedster9's Avatar
Tedster9
Lol, well that's one way to solve it.
If this doesn't work, anti-sieze will I betcha. It's one of those things that isn't really a big deal though it is annoying. Fixed now! Thanks
Old May 3, 2018 | 08:22 PM
  #748
Tedster9's Avatar
Tedster9
Well I shouldn't have said anything about "Fixed!", it appears I have a new problem, though not with the stove.
The check valve (I think) in the 200A lantern, symptoms are it won't hold a pump. It will pump up, but leaks air through the thumb hole. Can sort of get it to run by closing it, but that will never do. &@!?!?$&!!
Old May 3, 2018 | 09:42 PM
  #749
wpnaes's Avatar
wpnaes
Yeah, the check valve ball gets all kinds of junk down there; oil, leather bits, dirt... it need to be removed and soaked in cleaner. Then she’ll be right as rain. Do you have a check valve removal tool?
Old May 3, 2018 | 10:23 PM
  #750
Tedster9's Avatar
Tedster9
No I do not. The Ford tire iron from my slick of all things, fits pretty well but that thing wouldn't budge. Put it back together, and it works OK, though every once in a while it fails to catch a pump. It sure works nice though now that the cap holds pressure with the new gasket.
