Well I think it is some "rare" variant. I mean, I guess that's what it is ... collectors. Still it's just a single mantle lantern when you get right down to it.
Had a look. I have plenty of 200a. None from 52-53 with a black center. Plenty from 60's to 70's.
even have some with yellow lens
I'll keep looking.........
Here's another interesting item. Filler caps (Amish made!) modified to accept a Bicycle tire air pump. I asked the seller about these, and he helpfully replied they are designed to save time and effort. I guess so. Does this make sense?
I have on I use occasionally. Stop pumping at 30psi. There is little advantage to going higher. New founts should open a seam at 200psi? Older ones, who knows.
