V/Modified B codes, step-by-step
Old Aug 10, 2012 | 12:40 PM
  #106
outlw's Avatar
outlw
what is the modded b code part numbers?
Also would it be wise to put new B springs on or go with a new spring pack to match the front?
Old Aug 10, 2012 | 12:48 PM
  #107
jwronski's Avatar
jwronski
You will want to read the steering wander thread or even this entire thread. There are not part numbers for a modded B. You purchase the B codes and then either mod them yourself or have someone do it for you.
Old Aug 10, 2012 | 02:49 PM
  #108
outlw's Avatar
outlw
I ordered all new springs for the truck today new V and new B Code with 4" blocks from the F-250.
Old Aug 10, 2012 | 03:36 PM
  #109
jwronski's Avatar
jwronski
Are you going to mod the B's ? The B's and the 4 inch blocks are going to really raise your rear end. Are you going to do the work yourself? Where at in MI are you? Down in southern MI myself close to IN border.
Old Aug 12, 2012 | 08:48 PM
  #110
outlw's Avatar
outlw
If you are going to mod the B's How and whats the part numbers you need to use?
I was gonna have a few friends put it on at the dealer..
Old Aug 12, 2012 | 08:59 PM
  #111
Stewart_H's Avatar
Stewart_H
This has been covered many, many times. And in fact, if you were to go to the very first post in this very thread, you would get your answers, with pictures and directions on how to mod the B's, no less.
Stewart
Old Aug 12, 2012 | 09:18 PM
  #112
outlw's Avatar
outlw
I get confusded to what I need.. I only want to have it torn apart once..
where do I get the parts to mod the b springs?
Old Aug 12, 2012 | 09:36 PM
  #113
Stewart_H's Avatar
Stewart_H
Wow.
Ok, here, lemme emphasis in bold print for you.
Stewart
The title of this thread is kind of a dead give-away. It's a picture tutorial on HOW TO MOD A B CODE SPRING.
So, for the third time, please see the first post in this thread.
Stewart
Old Aug 12, 2012 | 11:54 PM
  #114
wpnaes's Avatar
wpnaes
Stewart
Master Kan: Quickly as you can, ****** the pebble from my hand.
[Young Caine tries to do so and fails]
Master Kan: When you can take the pebble from my hand, it will be time for you to leave.
Some are destined to ask and not read.
Old Aug 13, 2012 | 06:58 AM
  #115
Pitcrw6's Avatar
Pitcrw6
Subscribed
Old Aug 13, 2012 | 07:53 AM
  #116
white Buffalo's Avatar
white Buffalo
Nice thread Robert......I haven't been online much lately, between back surgery and the house remodeling there hasn't been enough hours in the day. But I'm feeling the FTE pull
Old Aug 13, 2012 | 08:31 AM
  #117
outlw's Avatar
outlw
what I am totally confused about is I am taking the stock springs off the excursion and ordered new B Springs for the rear and V's for the front..
Where do I get the extra springs to add to the B Spring that is what I am totally confused on.
Old Aug 13, 2012 | 08:59 AM
  #118
TrdLtly's Avatar
TrdLtly
TreadLightly
Not to sound completely sarcastic....
Go to here (like Stewart said): https://www.ford-trucks.com/forums/1...l#post11391676
Scroll to here: MODDING THE B CODE SPRINGS: and then read every word. You will pull the old pack apart and put a couple of leaf's in the new Modded B pack.
Old Aug 13, 2012 | 09:01 AM
  #119
Pitcrw6's Avatar
Pitcrw6
You take one spring off of the old springs you take off the truck
Old Aug 13, 2012 | 10:15 AM
  #120
outlw's Avatar
outlw
If I put the 3.5" block do I have to add the other spring from the old?
