V/Modified B codes, step-by-step
Old Feb 8, 2012 | 12:35 AM
  #31
robert_l_ross's Avatar
robert_l_ross
Originally Posted by Stewart_H
IIRC, that was me, based on info provided to me by a bud who worked at Ford.
Speaking of which Robert, do you remember which thread that was in? I don't remember if I corrected the bad info.
Stewart
It was this post:
https://www.ford-trucks.com/forums/6...ml#post5095806
  #32
EX40's Avatar
EX40
Yeah should be sans the overload. I think I can get 'em from elsewhere. If not I'll go with 3.5" blocks & do the modded later.
Old Feb 8, 2012 | 12:46 AM
  #33
robert_l_ross
Are you sure it's without that bottom leaf? The center spring pack bolt goes through it, so to get it without would be very unusual - they would have to take it apart to get that bottom leaf off...
Old Feb 8, 2012 | 12:47 AM
  #34
robert_l_ross
This is how mine came...you can't see from the angle, but the center bolt is on the B codes holding that bottom leaf to the pack (top spring in the photo):
Old Feb 8, 2012 | 12:56 AM
  #35
EX40's Avatar
EX40
That's what was reported. They came off the truck with 800 miles for a lift. For whatever reason the overload was removed. Figure I could get 'em for a steal and mod at my convenience. Haven't had much luck in my area finding used.
Hope to have the set for around $250 practically new. Got a line on Hellwig rear bar also. Hopefully I'll have a nice riding vehicle for under $400 when it's all said and done. That included getting new U-bolts. Already have Rancho 9000XL's on there. Just hope my poor spring haven't caused premature wear.
Old Feb 8, 2012 | 01:03 AM
  #36
Stewart_H's Avatar
Stewart_H
Originally Posted by robert_l_ross
Thanks. I edited the wrong info out.
I have other resources now. Here's info I uploaded to my Google doc page: Torque specs for 2000 F series trucks and Excursions - https://docs.google.com/document/d/1..._J9NG1p2w/edit
Here's a small screen grab of the doc:
Stewart
Old Feb 8, 2012 | 01:21 AM
  #37
WE3ZS's Avatar
WE3ZS
And I had the other version of the B codes, with both a top and bottom overload leaf. As you can see the stock B code (top spring in photo) has both, the bottom (thick) one you will want as Robert said but if you have the top (thin) one it has to be removed along with that little 1" block that separates it from the rest of the pack.
I didn't have many toys as a kid so I have to play now. The center spring in the photo is my X code front as it came stock, the bottom spring in the pic is the other X code with that top B code overoad leaf (the one that has to come off) added to it. Firms up the ride a little bit and gives another 1/2" or so of lift.
Old Feb 8, 2012 | 02:50 AM
  #38
robert_l_ross
That's usually the overload leaf they talk about being removed before you get the pack...I think the guy that's telling him the bottom one has been removed is just wrong. If you take off the bottom leaf, I'm not even sure there is enough threads on the spring pack bolt to put them back together again.
EX40...see if he can take a pic of the springs and e-mail or text it to you...
Old Feb 11, 2012 | 09:01 PM
  #39
twtcad's Avatar
twtcad
WOW.....what a difference! and man that was a workout! My front end was almost 37" driveway to top of wheel well....now it's 40 1/4" and the ride is so much better! I have not taken it very far yet; I have a road I drive everyday that would bounce the hell out of the truck....looking forward to driving it tomorrow.....hopefully with a smile on my face! I have not confirmed with the guy I got the springs from which code they were, but they came off an '04 4x4 4dr F350 6.0 diesel.......hopefully talk to him tomorrow.
I do have to say I could not have imagined doing this upgrade w/o removing the bumper....I would suggest anybody planning this job to do that! Also, not sure if this was the right way or not.....but when installing the new springs I connect the rear shackle first (bolt loose w/ nut) then my axle shifted (like most I assume) so it was one heck of a work out trying to get the pin lined up. I got both pins lined up (each side) w/ the jack supporting the axle, but I had to use another jack on the back of the differential (4x4) to rotate the axle a little because it also twisted. Then I snugged the u-bolts to hold everything together. Now I started working on the front eye bolt; with a little jack pressure and a pry bar I was able to get the bolt in.
I started about 10:30am and I got most everything taken apart by 11:30/12pm when my helper showed up and we had everything back together by 3:30/4pm.
Again....THANK YOU to all those who have paved the way for us a little late in the game!
Old Feb 11, 2012 | 10:08 PM
  #40
robert_l_ross
Thats how we did it - partially. Since the rear spring shackles flex, we did the rear spring to shackle bolt, then lined up the front spring to frame bolt by using a prybar between the upper shackle to frame bolt and the lower spring to shackle bolt to flex the spring forward to line up the front spring bolt hole.
We then used jacks to compress the springs, and used the OEM jack between the jack stand holding the frame up (placed the jack stand just aft of the aft front spring shackle) and the sway bar link (at an angle)...opening up that jack slid the axle forward to line up the spring pack bolt with the axle.
I didn't have the "twist" problem you had with the axle, but that jack solution sounded like it made quick work of fixing it.
My axle shifted (to the rear), so if I had to do it again, I'd use straps to tie the axle to the jacks, then chock the jacks so they couldn't roll fore or aft...that (I think) would have kept the axle in the same spot relative to the frame, and since the V codes and stock springs both have 6" of arc uncompressed, IN THEORY they should have lined right back up.
Old Feb 12, 2012 | 09:36 AM
  #41
twtcad's Avatar
twtcad
I laid my stock springs next to the new (used) ones and the new ones where @ about 6", but my stocks were about 4 1/2".....they were really shot!
I think your strapping the axle idea might work; mine shifted aft and to the passenger side....not sure why but it did.
As was mentioned before somewhere....don't over think this procedure.....the basic steps are laid out and everything comes together as your doing it.....by the way this is the first time I've ever dropped and axle or replaced leaf springs so if I can do it anybody can.....lol
Old Feb 12, 2012 | 04:00 PM
  #42
robert_l_ross
When I misspoke...the 6" of arc is just the new V codes. I got used ones and was worried they didn't look very tall, and a member who bought New ones measured his so I could compare, and they were both 6".
I wonder if it's the order you do them in...bumping the jacks slightly, etc. that causes the axle to slip one way or the other?
Old Feb 12, 2012 | 04:23 PM
  #43
wpnaes's Avatar
wpnaes
Here's a pic of my tired Ex springs vs. some tired (with fresh paint) V springs.
Old Feb 13, 2012 | 03:50 PM
  #44
twtcad's Avatar
twtcad
Was that a Homemade lift you had on there Sean?
Old Feb 13, 2012 | 11:02 PM
  #45
wpnaes's Avatar
wpnaes
I think Daystar made it.
